Question about Cell Phones
Where do i insert a sim card on a dixon md9901
Hi there i can not find the place where to insert the simcard
SOURCE: insert sim card motorola z8
what made is your phone?..did your phone is open line, so you can insert any sim card?...
Posted on Feb 25, 2008
SOURCE: LG Shine doesn't reconize SIM card
yeah you probably need a new chip due to the 3g network it might work on the other phones because they are older
Posted on Jan 08, 2009
jacko0
  • 159 Answers
SOURCE: where to insert sim card in iphone 3gs
At the top of the iPhone you will see a small hole. Use a paperclip to push in the hole and the sim card try will pop out.
Put your sim card in the tray and put back in the iPhone
Posted on Dec 25, 2009
SOURCE: I have a motorola c168i I insert the sim card when
insert Sim Problem
Posted on Aug 25, 2010
SOURCE: INSERT SIM CARD
m620 insert sim solution
Posted on Feb 20, 2011
How to install sim card
For most of the phone,sim card will be install at the back of your mobile phone. These are the steps on how to: 1. Turn off your mobile phone. 2. Remove the back case gently. 3. Remove the battery as well. 4. Theres instruction at the back of your phone on where to place the simcard and on how to insert it. 5. Make sure you properly inserted the sim card so you wont recieve offline mode error. 6. Plug back the battery. 7. Return the back cover. 8. Turn on your phone,then your good to go. remember that there are some phones wherein the simcard slot is on the side part of the phone. for this kind of phones,all you have to do is just lift the cover of the simcard slot then slowly insert the sim properly then turn on the phone and your good to go.
Dec 05, 2011 | Samsung Cell Phones
Put sim card in and it says insert sim card
Hi,when a phone says insert Sim,it means that the Sim card was not placed properly or the Sim card you are using is damaged ( You can try to confirm the simcard if it works properly by testing it on another phone).
Also thee sim tray that you fix your sim card in the phone might also be damaged.
You can try all,it most be one at of all.
Good luck.
Aug 22, 2010 | Nokia Cell Phones
Insert sim
hi,
check your sim card first ,clean it...next step is clean your simcard interface by eraser or lacquer thinner ...if still not works ,the sim card driver of your phone is need to replace..this simcard driver is small chips that makes the simcard working ,if it is damage the simcard interface did not recognized the simcard...if the first and second solution not works ,go to a cellphone repair shop to change your sim card driver...
i hope it will help you..thanks
Jun 15, 2010 | Nokia 2600
My nokia 3200 restart when simcard inserted.but when simcard no inserted the phone no restart.just showing insert simcard
Hi
This is happening because when the Sim card is not inserted you cannot access the menu of the phone some nokia phones(including yours) are built that way.
Some nokia phones do not need a sim card for you to access the phone menu (e.g 5130,5230), while you can only view the demo of some nokia phones (e.g 1208, 1600) without a sim card
Mar 12, 2010 | Nokia 3200
After inserting simcard ,still it says insert sim card
the problem on it is insert sim, try to check the srews on it and turn it tighter
Apr 26, 2009 | Cell Phones
Insert simcard nokia 7200
hi the only one thing you can try without replacing the sim card reader is do you know when you put the simcard in if you push on the simcard with your finger so your pushing it down onto the contacts is fold up some paper so that it put pressure onto the simcard when you put the battery on as alot of times the contacts dont touch the sim card properly so putting some folded paper on top of sim card pushes it down onto the contacts properly.
This solves the problem in most cases but it can be difficult to get right as if the paper isnt thick enough then it might not push it down hard enough to make contact.
If after doing this it still dont work then this either means the sim cards no good but you could try it in another phone or it could be that the sim card reader is not connecting with the board properly and would need replacing.
Make sure you check the contacts are clean on the sim card and the sim card reader to make sure this isnt problem.
If you have not tried the sim card in a different phone then it could be the sim card is no good.
Did this sim work in the phone before just in case the phone dont accept that network as you can get this message if this is the case.
Let me know how you get on and if you need further assistance ok
Apr 08, 2008 | Nokia N95 Cellular Phone
Sim card
THIS PHONE DOESN'T USE A SIM CARD.....DUHHHHHHHHHHHHH!!
Mar 22, 2008 | Samsung SCH-a650
Nokia 1112
hi
common cause of insert sim is that your sim card doent contact to its sim card terminals. try cleaning its terminal or bending its sim card cover towards the sim terminal or put any small cut or folded paper just like the shape of your sim and place it together w/ your sim.  that makes your sim compress more to its terminal.
if samething happens then its already hardware problem or simcard terminal loss its connections..
try it...
Oct 17, 2007 | Nokia 3100
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
