Question about GE 29484GE2 Corded Phone
Both Lines wont work
Main line(1) works fax line(2) won't. When I reverse the cords the opposite happens. Either way only one line will work at a time. HELP !!!
2 Suggested Answers
  • 8 Answers
SOURCE: intercom feature not working
Is one of the 2 phones transformer plugged into a power strip? If so, try putting it directly into the wall, most power strips do not pass the signal properly
Posted on Jun 03, 2009
  • 713 Answers
SOURCE: Good Morning! I work for a
Hi,I had exactly the same problem. I tried re-registering the handset several times with no change. In desperation, I took the battery out of the handset for 5 minutes or so and unplugged the transformer from the wall. I reinstalled the battery and plugged the transformer back in and voila!all the phone line now works perfectly.
Thanks and goodluck
Posted on Apr 12, 2010
0 characters
1 Points
I have two phone lines one for phone and one for fax is there any way i can connect my fax machine to the fax line only and not have to use an adapter
You can have the single out jack replaced with a dual outlet jack. To rewire it yourself, use the Blue/Blue White wires for Line 1 and use the Orange/Orange White wires for Line 2. If you older wiring then the colors are Green/Red for Line 1 and Yellow/Black for Line 2.
Jul 08, 2014 | RCA 25201RE1 Corded Phone
Line 1 and two not splitting
You can find the combiner at Radio Shack Model: T07843 ' Catalog #: 55034722. It may only be online not in the stores.
Dec 03, 2011 | RCA 25414RE3 Corded Phone
I just want to make sure that I am shopping for the right product. We have a dental office with 1 phone#, but we have a rollover line. Our fax has it's own# which "was" what we called line 3 but as of...
Yes, you can use a regular 2 line cordless phone with your 4 line corded systems. The only concern is when you put someone on hold. The on hold function may not release if you have different makes of phone. If you already have Panasonic get a Panasonic 2 line cordless phone with the on hold feature.
Yes, you can just take line 3 and plug it into your new fax. I might suggest looking into a fax to email service instead of buying a new fax. If you receive more than send it's a great way to save on the phone line and paper.
Digital phones are pretty secure, no one will accidentally hear your conversations. It is not encrypted but I think it would be perfectly fine in your office.
Feb 18, 2010 | RCA 25205RE1 Phone
Meridian M7310; just installed replacement phone (used); line 3 disconnects when answered. Lines 1 and 2 work fine. They are in the loop. Line 3 is dedicated fax incoming but can be used as outgoing phone.
Normal 0 Hello, Gary.
Disconnect power and cables from all phones and faxes on the line 3. Wait 15 minutes and reconnect the line again, one at a time. See if the Meridian works. If not, it could be faulty.
Hope this helps.
Feb 01, 2010 | NorStar M7310 Corded Phone
Stop ringing at main phones when outside calls come in.
Here is a link to program line ringing.
It sounds like your extension is forwarded (confirmed by the one beep you hear on an incoming call.
From any display phone, press Feature 11
then enter your extension number 2 times. So if you are extension 20, do this:
see if that does it.
May 28, 2009 | Lucent PARTNER18 Corded Phone
What do I buy to use 2line phone and separate fax?
You can buy a 2 line phone, but to use the fax/dsl line for voice, you will also need a line sharing device.
"The stick" is a good brand....
All it does is recognize if an incoming call is a fax or a voice call. If fax it would go to a fax port on the stick. If voice, it comes out the voice port which you can call on.
The same rules apply to this line....if something is using it, the next call will get busy......But now you could have the phone company "Hunt" your line 1 to line 2 (fax/dsl) if line 1 is busy.......hence...2 incoming lines....
Apr 14, 2009 | RCA 25201RE1 Corded Phone
Need to connect phone and fax machine to one phone jack
You have the wrong adapter probably. Most common types are single line splitters and will not work like you want. They only split line one and 2 gets blocked out as they only have 2 copper connector on the plug centered to get line 1 only. If you want to use an adapter you will need a 2 line splitter like this one:
A simpler solution is to plug your fax into your phone. On top of your phone are multiple jacks labeled L1/L2, L2 only or L2/data. Plug your phone into the wall using the L1/L2 jack then plug your fax into the L2 jack and this will work fine and still allow you use of line 2 on your phone. If you don't want to hear the ring then set your fax machine to auto answer. Hope this helps you.
Mar 29, 2009 | RCA 25201RE1 Corded Phone
How to connect the telephone lines
Please let the fax line be connected to computer itself do not remove , In the DSL line you get a splitter which the lines for phone and ADSL modem connect the splitter to DSL Line and from the Splitter you 2 o/p ports with phone marking or symbol connect the phone line to it and to line port connect the main 8957and then to ADSL line to ADSL modem from the ADSL modem connect to lan port which is behind the computer (not to dial up modem
i.e is fax line ) or the usb port in the computer ...
Good luck...
Feb 02, 2009 | RCA 25201RE1 Corded Phone
2 line phone rca 25205re1 only 1 line works not the rollover line
Most likely the problem is the cord from the wall to the phone. There are two types of cords and they look almost identical. Look closely at the connector. A single-line cord will have only two gold pin at each end. A two-line cord will have four gold pins at each end.
You need a two-line cord to get both lines from the wall to your phone. Since you have had the problem with several phones, that is the most likely cause.
Jan 14, 2009 | RCA 25205RE1 Phone
GE 29484GE2 Corded Phone Logo
22 people viewed this question
Top GE Phones Experts
Are you a GE Phone Expert? Answer questions, earn points and help others
