Hp 2000-369wm laptop won't start
Replaced keyboard, now after it is all back together it won't start. When you plugin the light shows power but that's it
  • 3 Answers
SOURCE: coke spilled on to the keyboard for my laptop.
Hi
The keyboard has to be taken to service centre, As the coke becomes gummy substance after dried up and the whole keyboard membrane track has to be cleand with isopropyl alcohol and the keyboard controller strip cable leads and connectors has to be cleaned with isopropyl alcohol or with any component leads cleaning solution
Posted on Mar 18, 2009
  • 2567 Answers
SOURCE: hp nc4200 won`t start
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Posted on Dec 28, 2009
  • 11800 Answers
SOURCE: My Acer Aspire One Netbook
Massive hardware failure on the motherboard - the netbook will have to be opened and its components tested by a repair shop. Take it to one.
Posted on Jun 05, 2011
SOURCE: HP Elitebook 2530p won't start, power
had the same problem - press and hold th power button without the battery connected for 30sec
refit battery and try again - it worked for me
Posted on Sep 01, 2011
byteguy
  • 2229 Answers
SOURCE: I bought a new charger
The first thing to do is check that the charger is putting out the correct voltage, which should be ~18 volt. Then try to start it without the battery.
If your voltage is OK and the battery out makes no difference, then I would suspect that you have a motherboard problem that must be fixed. If the computer starts up if you wiggle the DC plug where it goes into the computer, then it's the DC jack that is looks and must be re-soldered.
Posted on Sep 11, 2011
G62 won't boot up
Take out the battery and wait a minute, then put it back and try again.
Mar 03, 2017 | HEWLETT-PACKARD HP Laptop / AMD Turion II...
Screen won't turn on/Power stays on
To do a power reset, unplug your laptop, remove the battery and hold the power switch down for 30 seconds.
otherwise it may be problem with your screen back light...
Apr 10, 2013 | HP G60-535 Laptop Notebook Netbook...
Hp nx6310 won't power up though the power indicator light shows that it is receiving power from the adapter
Usually is because the battery of laptop is damage or don't hold a charge. Please remove the battery and try turn on the laptop. If it run you only have to replace the battery.
Regards!
Feb 21, 2013 | Computers & Internet
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
Battery won't Charge
Hope this helps
Nov 04, 2012 | HP Computers & Internet
HP Pavilion dv6448se Notebook PC Won't Boot.
it restarts on booting screen or else at start up screen itself?
Jun 08, 2012 | HP Computers & Internet
I spilled liquid on my HP Probook 4320S (with spill resistant keyboard). Dried it up straight afterwards. Now it won't power up
Take it to a service shop asp, key board will need to be replaced, and the laptop will need to be assessed for motherboard damage.
May 06, 2012 | HEWLETT-PACKARD ProBook 4320s C Notebook
My hp pavilion 1260 won't re power up after removing the battery
Hi, go to you tube and write: hp pavilion 1260 and you will find the instructions to fix it. i just did it with mine hp dv6000.
Jan 30, 2012 | HP Pavilion dv7-1260us Notebook PC
Unable to type
Flip the unit on its back and remove the battery.
Next remove the memory and hard drive.
In the memory area, you will find a lit. battery with a white 2 wire plug. Disconnect this plug and flip unit over.
Open the cover and hold down the power button for 30 seconds.
This will clear the BIOS and CMOS settings on the Laptop.
Flip the unit over and install the Hard drive and memory.
Next, plugin the battery connection.
Close unit up and plugin power connection.
Power up the 9000 and see if the keyboard is seen.
Note. You may have a defective or dammaged keyboard and may need to be replaced.
You can use a USB keyboard temp. About $20.00 USD at any Walmart
Hope this works for you.
Oct 04, 2009 | HP Pavilion dv9000z Notebook
ACER ASPIRE WON'T TURN ON AND RED LIGHT FLASHING
acer aspire 5315 wont turn on, but the battery led lights up when the ac adaptor is connected..pls help.
Dec 20, 2008 | Acer Aspire 5315 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
