Question about Refrigerators
Hoover contour fridge HE423
Our hoover contour upside-down fridge-freezer is hinged on the left. We wish to hinge it on the right. Is it possible to reverse the doors? What happens to the handles?! Thank you! Julie
ginko
  • 19396 Answers
SOURCE: May Tag Referigerator
The MBR1952KES Has the hinges on the right only, you need to order a custom made door to move hinges on the left.
Here is picture
Posted on Jul 27, 2008
jyackle5
  • 8197 Answers
SOURCE: Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Posted on Dec 17, 2008
aborcass
  • 2651 Answers
SOURCE: How to reverse door on kelvinator fridge?
Im unable to look up htat particular model number for you, looks like my FRT18, which is made by the electrolux company, in which case, YES you can easily switch the door swing form one side to the ohter, whats on the left goes to teh righ and right to the left, not a problem
Posted on Jan 11, 2009
  • 59 Answers
SOURCE: do i need special hinges to change this refrigerator from left hand door to right hand door?
NO YOU USE THE SAME HINGES
Posted on Apr 29, 2009
woodchuck789
  • 4059 Answers
SOURCE: hoover contour fridge leaking
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 30, 2009
Testimonial: "thanks, all fixed!!"
Door slams open Maytag Fridge MZD2766
Human error may have resulted in the hinges being installed incorrectly. To confirm your suspicion, check a similar Maytag on display in a store.
May 26, 2017 | Maytag MFD2561HE Bottom Freezer French...
Here is picture
Jul 27, 2008 | Maytag Refrigerators
Both the freezer and fridge doors hinge on the right, and the left hand side has sagged a little so neither neither door is sealing properly. How do I adjust the doors to raise the left side of the...
The lower hinge on each door may have a door closing cam. It raises the door up ΒΌ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
May 04, 2011 | Refrigerators
We have this model westinghouse fridge which currently opens to the right but are moving house and the fridge needs to open to the left. I can see holes on the left side with white plugs in them so it...
Yes depending on age. once changed doors never seal properly. because cabinet warps and seals flatten on one side. suggest to sell and buy another. you will never be happy if converted.
Aug 30, 2010 | Refrigerators
Change doors of fridge freezer from right opening to left opening needless to say cannot find instructions after 10 years
tilt unit backwards,and under hinge side you will see a bracket,undo bolts and transfer to opposite side leaving loose,slide door down ,then on top of door transfer plug to opposite side(if needed)slide door back up and refit bottom hinges/tighten bolts.
handle is just a matter of prising plastic cover of and unscrewing,then refitting to other side.
once you tip it backward its pretty obvious really.
Mar 13, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Need kit to convert my whirlpool fridge from rhs to lhs hinge
hi,
you may not have to buy anything, on most reversible door installations you just use the same hardware, just turn the hardware upside down or the other way around, same with the handles. look at the hinges closely, on the other side of the door is plastic caps, you just remove them and reinstall the door starting from the very bottom hinge. If there is a kit Im sorry, but Ive never had to buy any sort of kit and Ive done at least 10 fridges..
jm
Feb 02, 2010 | Refrigerators
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
We have a fridge/freezer, upright bought some 15 years ago. Works fine, but we wish to reverse the doors to right opening from left. Please advise how to do it.
if you can notice that the doors have plastic plugs to the other side of the hinge then it is design to be reversible.
but if there is no indication that you can transfer the hinge to the other side of the door, then it is not designed to be reversible and there is nothing you can do about it.
i'm not sure if the old fridge are designed to be reversible.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Refrigerators
Fridaire model frt181l6d50
You'll need to remove the top hinge cover from whatever side it is on currently and then lift the door off the hings post ( set the door aside) .. then the top of the fridge will have small removable caps that hide the nuts for where you fasten the hinge to that side. Reinstall those caps to hide the holes in the top of the fridge where the hinge used to be. Next, you will have to transfer the handle on the door to the opposite side ( same process as the hinge) .. You wil find small plastic caps that hide the holes you'll be using to secure the handle to the opposite side,. use the same process for the freezer door too..This process only applies to top/bottom type freezers and not side by side. Hope that helps
Aug 03, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
