Question about Home
Kohler 84499 adjustments
Level in toilet bowl
  • 653 Answers
SOURCE: raising water level in the toilet bowl.
The water level in the bowl is limited by the height of the internal trap down stream from the bowl. There is no adjustment possible. If the problem is odors, you can either flush more often, turn on the exhaust fan, or buy a different brand or model of toilet.
Posted on Apr 04, 2009
miket756
  • 2702 Answers
SOURCE: Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Posted on Oct 24, 2009
  • 37 Answers
SOURCE: How can I adjust the water level inside my Saniflo
you cant it is set by the bends in side the bowl all toilets are this way it is a trap design that keeps fumes from septic from comming in
Posted on Nov 28, 2010
SOURCE: water in bowl. water level almost below where bowl
If I understand correctly, your water level inside the bowl is 3 or 4 inches from the top of toilet seat?
Sounds peculiar to have that water level since you would get splashing etc.
That is not sanitary, and would be a code violation.
Look at side profile of tank.
Look at porcelain behind bowl and you can see outline of "s trap."
This is the internal trap that each toilet has built in.
Purpose of trap is to a) set water level inside bowl and b) just like a sink trap, seal pipe from sewer air from entering home.
Photo shows trap on sample toilet, with line showing approximate level of water inside bowl.
Since photo is at an angle, the line appears to go downward instead of level. Again the line is approximation, and photo intended to show where you can look on your toilet.
Your tank should have similar s-trap feature. From the feature on your tank, you can see what level water is intended to be inside bowl.
Some more expensive tanks, outline of s-trap is not apparent.
If the water level is so high that you experience unsanitary conditions, this is a code violation, and toilet should be replaced.
Quick web search turned up Kohler contact page: http://www.us.kohler.com/general/contact.jsp
KOHLER Customer Care at
Phone: 1-800-4KOHLER (1-800-456-4537)
Hours: 8:00 AM - 5:00 PM (Central Time) Monday to Friday
You can refer Kohler to this link on Fixya so they can clearly understand issue.
Posted on Jan 10, 2011
SOURCE: The water level is too low in my Kohler toilet
check the (white) tube in the tank. it should connect to the top of the black reservoir. mine came loose and had the same problem. you can check the diagram on the inside of the tank lid.
cheers
Posted on Jan 27, 2011
I have a Koehler model 703 84679aa. The seat bolt is loose and you cannot get to the but without pulling the toilet. Does anyone know how to tighten the seat without removing the whole toilet?
Kohler Rialto / San Raphael toilet problems # 84499 ...
? 13:04
www.youtube.com/watch?v=Hmhb4H4HYMY
Mar 31, 2012 - Uploaded by Dino Pinch best kohler rialto / san raphael toilet repair video on youtube. ...the kohler brand rialto model wisks away the offending lumps of ur behind product, never to be seen again. .... 'can't screw a lightbulb in'. .... How to Install Toilet Seat on Kohler One-piece ModelK3434 - Duration: 7:10. by emf4kv 20,891 views.
Jul 26, 2015 | Home
I have a 2yr old Kohler K4634 toilet. After flushing the water level drops about 1 inch in the bowl after the bowl filled. This causes a lower level in the bowl than is recommended. The main issue
check to see if waster continues to run into the bowl after the plunger has returned to stop water flowing. If it is a slow leak then replace the flush washer on the stopper plunger.
Oct 01, 2014 | Kohler K-4634-RA-0 Cimarron Toilet Tank...
After installing a new flush valve, the water level in the toilet bowl seems to be much lower than it was with the old flush valve. Is there any adjustment for the water level in the toilet bowl?
Yes,there it is!You can adjust your water level at the flush valve..You can see the ball there you need to adjust that so that the water level of your tank goes to your desired level.
Jul 29, 2011 | Kohler 3386-6 Rialto Skylight Round Front...
The water level is too low in my Kohler toilet bowl. Level in the tank is fine. How do I adjust the bowl level?
cheers
Jan 25, 2011 | Kohler Home
Water in bowl. water level almost below where bowl saris to widen! , Kohler cimmarron - Toilet tank is full, all water flushes out of tank when flushed it's been this way since we installed it
Jan 09, 2011 | Kohler - Toilet - Two-piece - Highline -...
My kohler toilet is only about 1 year old. no problems with the flush but the bowl only fills up with about half the amount of the normal water. I looked inside an all seems to be connected. Thanks
You might follow this link to see if you can adjust the water level:
http://www.acmehowto.com/howto/homemaintenance/plumbing/toilet/filllevel.php
Hope that helps.
Aug 21, 2010 | Kohler Home
Oct 24, 2009 | Kohler K-11470-0 White Wellworth Complete...
Home Logo
59 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
