Question about Vacuums
Kenmore upright vacuum power failure
My Kenmore Upright with bag 12 amp model 116 32212200 worked perfectly until the upright handle fell backwards and hit the floor when I was using the hose attachments. This has happened many times in the past. This time the vacuum died and will not turn on. I had an identical model that did the same thing several years ago, found this one in Goodwill and it worked perfectly until this morning. Is there a hidden power reset switch or main circuit breaker / fuse that causes this to happen?
reddevil6
  • 1673 Answers
SOURCE: No vacuum suction during normal floor cleaning operation
That door is called a valve door, and it may have broken, part #38718013. Or the valve arm, rear broke, part number 38719048. The spring part # is 38358001. Usually it is the valve arm that breaks. You would have to take the top cover off, then you can see the parts.
Posted on Jan 29, 2008
  • 6 Answers
SOURCE: Kenmore Elegance Upright Bagged Vacuum Belt Broken and Smelling
It sounds like the brushroll has caused your belt problem and will be the cause of your burning smell as well. What commonly occurs is that carpet fiber,hair,string, thread,etc got wound around the brushroll and some will get caught in the end caps which is where the bearings are.The end caps need to be removed and cleaned so that the bearings can allow the brush to rotate freely.Check that there is no melting of the end caps or the base plate where the end caps fit into the machine._Good Luck
Posted on Oct 26, 2008
erickg
  • 116 Answers
SOURCE: agitator turns but the vacuum doesn't pick up that well
ok it sounds like the vacuum line that goes to your brush is clogged partially. need to remove soem screws and get to it from the underneath. or try blowing through the line with compressed air or blower side of a vacuum. its usaully the smal flat veins that clogg right before it goes up into the tube that you connect to.
Posted on Apr 15, 2009
SOURCE: Kenmore Model 116 upright beltless vacuum, agitator will not turn
I had the same problem. The agitator stopped turning after I sucked up a foreign object (my wife's watch) and it got jammed in the intake. After removal of the watch the agitator did not spin when turning on the machine, and the reset button never deployed (it remained buried in its housing and would not depress with a paper clip). The agitator was not bound and I could manually move it in both directions with ease. Faced with prospect of paying $125 or more for a repair, a good sharp kick to the chassis from the top promptly fixed the problem. I have found that kicking malfunctioning electronics often works.
Posted on Dec 05, 2009
SOURCE: my kenmore beltless upright canister vaccuum doesn't spin anymore
Ensure the agitator is not bound up and can be moved manually by hand in both directions. Clean any string or binding material if you find it. Press the reset button on the top of the chassis. If it clicks, then you should try turning it on and see if the agitator spins. If it doesn't spin, I have had luck giving a sharp kick to the top of the chassis.
Kenmore Vacuum cleaner #175.3866180 bags and belt
I logged into the Kenmore website, entered the vacuum model no. and found that the bag has been superceeded by 20-50004, which appears to be available only from Kenmore. The belt required is #5270.
Aug 01, 2009 | Kenmore Bagless Upright VacuumVacuum
Kenmore vac has no suction in hose or base
Find a Shop that sells these & get them to show you.how it works.
Apr 08, 2009 | Kenmore 31912 Progressive Direct Drive...
Kenmore upright vacuum model 116.35923500. not rotating when on. Easy way to clean without taking apart?
There is a switch that tells the cleaner that the upright is locked upright and the beater bar won't spin until you depress the foot release and tilt the cleaner. This switch mount is poorly designed, its just sitting in a pocket at the pivot of the cleaner. I had to double stick tape it in the pocket to keep it from moving around and put silicone spray on the pivot. The pivot actuates the switch, but its a bad design.
  • Remove front cover, to do this, pull out the bag, remove the screws under the bag and on the outside. 12 screws total.
  • Locate switch on pivot
  • Confirm mounting of switch, re-adjust and use tape or epoxy.
  • Reassemble and test.
  • This is for a Kenmore 35923500 upright direct drive.
Jan 25, 2009 | Kenmore 22812 Bagged Canister Vacuum
My vacuum lost power completely. it will not turn on at all.
Have you checked the screw that holds the handle to the vaccuum?
If it is loose, the power will not go on.
Try it!
Worked for me!
Christina
Dec 28, 2008 | Kenmore 31913 Progressive Direct Drive...
Clogged vacuum - Kenmore 35922 Slate Blue
35922 is not the complete model number, it will be on the back or the bottom of the vacuum. Example: 116.35922****
Sep 02, 2008 | Kenmore 31912 Progressive Direct Drive...
Dirt Devil upright vac
It could be a broken handle release, but it also could be the the clamps where the handle asm, and the base hold together came use, this will cause this problem on some Dirt Devils. The top has to come off to check this out.
Jul 13, 2008 | Kenmore Progressive Bagless Upright with...
My vacuum is not sucking at all.....
I took out the air flow filter at the back of the vacuum and turned it on, somehow the clog cleared. Then I put the filter back in and it works perfectly! Barb
Mar 01, 2007 | Kenmore 35912 / 35913 Progressive Upright...
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
