Question about Craftsman Garden
Craftsman lawn tractor
How do i attach drive control cable to a craftsman 917.376722 lawn mower
5 Suggested Answers
  • 49 Answers
SOURCE: mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Posted on Feb 05, 2009
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Posted on Nov 30, 2009
  • 19 Answers
SOURCE: adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
Posted on Jul 19, 2010
  • 4961 Answers
SOURCE: craftsman lawn tractor cuts off when you engage the blades
You might want to post this in the lawn mower section.
Posted on Aug 19, 2012
I would like to see a diagram of the pully under the engine.
Rod, Check the attached links,manual,instruction and guides for Lawn tractor. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
917288320 CRAFTSMAN TRACTOR Manual Sears PartsDirect
craftsman dys 4500 belt diagram Google Search
How to Change Replace Main Transmission Drive Belt Craftsman Lawn Mower...
May 23, 2016 | Garden
Where is the solenoid located on a briggs and stratton engine model number 282H07/0334
Mary Jo, solenoid is not normally on engine, follow the positive battery cable from battery to where it bolts to a small double terminal device(this is the solenoid) the other bolt has cable attached that goes to battery.
Check the attached links,instruction and guides, Good luck
Mower Starter Solenoid Replacement Craftsman Riding Lawn Mower Repair Part...
Replacing Solenoid on Craftsman Lawn Mower or Tractor
Mar 24, 2016 | Briggs & Stratton Garden
Craftsman tractor how do I engage freewheel control rod?
Craftsman Lawn Mower manuals - ManualsLib
www.manualslib.com/brand/craftsman/lawn-mower.html
. PDF manuals. User manuals, Craftsman Lawn mower Operating guides and Service manuals. ... 28910 - Lt 2000 20 HP 42" Lawn Tractor ยท Operation Manual.โ€ŽCraftsman Lawn Mower manuals - โ€ŽCraftsman 247.370310 - โ€ŽCraftsman 247.37030
Aug 02, 2015 | Craftsman Garden
Release blade engagement attachment lever craftsman #917259330
there sure be a lever to disengage on the fir =e wall of the lawn mower deck or near fire wall o the lawn mower
Oct 16, 2014 | Garden
Attach snowblower yardman lawn tractor
most likely not unless...
Oct 03, 2013 | Garden
How do I install part no.183281 ( engine zone control cable ) onto a craftsman rotary lawn mower model no. 944.366362 ?
Hi Robert,
I'm not usually a Lawn Mower Expert, but I think I may have an answer for you. Assuming your craftsman rotary lawn mower is similar to this self propelled craftsman mower (they should have the same basic parts), this video should help!
Self-Propelled Craftsman Lawnmower Drive Cable Repair
Sep 05, 2013 | Garden
I need to tighten belt for the mower deck, how is that done? it is a 2004 craftsman 17.5HP 42 " deck. Can you help me
Each of the pulleys on top of the deck should have tensioners. These tensioners are usually the type which have a bolt for you to tighten while attached to the pulley. While you tighten the bolt, the pulley puts tension on the belt.
Aug 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Nothing happens when you turn on the lawn mower key for craftsman mower model 917 272072. I put a new battery in the mower, and new switch and a new solenoid switch but the mower don't make any noise when...
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Apr 16, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a diagram showing how the throtel cable attaches to the carb on a Craftsman 17.5 hp, 42 in.,riding mower (NEW 2008)
The throttle cable doesn't attach to the carburetor. The 'z' bend in the end of the cable sticks in the white plastic slide at the bottom of the control plate on the left rear side of the engine and the cable is held in place by a clamp behind it.
Jun 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to replace a clutch cable
i need a picture or explanation, how does the clutch spring attach
Apr 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
