Question about Panasonic CT-2789VYD 27" TV
Video takes i hour to clear-up
When I turn on my TV the picture is dark and the vertical isdistorted. It takes about an hour for the picture to clear-up.
  • 3 Answers
Rhonnhie is right! Replace the CRT socket of your tv. That's the only remedy.
Posted on Sep 26, 2007
    Problem Solver:
  • 15 Answers
YOU R HAVING A PROB TO A CRT SOCKET OF YOUR TV CALL A TECHNICAL PERSON FOR REPLACE
Posted on Aug 27, 2007
We have a Sony Bravia KDL 52 xbr9 tv. It is about 1 1/2 years old. We bought it Nov 29, 2009. For the last few weeks when we turn the TV on, the picture is distorted and dark (there are horizontal...
The board that call the T-CON board it is dying and dead soon.That why it is causing horizontal or vertical lines and distoted pictures.This T-CON board sit in at the bottom in the middle of the tv LCD screen panel and it only job are to decoded pictures pixels before it go onto the tv LCD screen panel.Tries websites Shopjimmmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.
Jul 20, 2011 | Sony KDL-52XBR9 52 in. LCD HDTV
My Sony KDL 46XBR4 when first turned on has vertical lines, or sometimes very dark picture for about half an hour, then the picture clears up fine, as long as I keep the tv on. Now, it is dark, almost...
That is correct. Sony has extended their warranty on panels for this model until Oct. 31st 2012. Just give Sony a call or simply take your set to an authorized service center and you will get your set fixed for free.
May 19, 2011 | Sony KDL-46XBR4 46 in. LCD Television
HDTV picture problems
Does the picture just get dark or does the picture go out completely? Does it do this with both the cable and the DVD? Is the audio affected?
Jan 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Vertical lines
hair line cracks in motherbord on soldering jobs look all over re soilde rthem back togther nicely
Oct 31, 2007 | Toshiba 46H84 46" Rear Projection...
Picture problem
Usually that symptom is caused by cracked solder joints on the vertical output IC. As the IC starts heating up, the picture starts breaking up at the top with several "dancing" dark lines appearing, the top scrunches down and then when the vertical quits altogether, the screen goes completely black. A good slap on the side of the TV might make it happen faster or clear it up temporarily. If you have experience working on PC boards then you can resolder the pins of the vertical output IC but if you have never soldered parts on PC boards then allow a qualified tech to handle it for you.
Nov 20, 2006 | Sony KV-35S42 35" TV
Picture too dark
You didn't say if you are receiving an off air picture or cable or satellite. The reason the commercials look good is because the local station (or source) transmits them "in the clear", that is, without any enhancements to the video signal. Network programing or local newscasts are sent through a device which inserts a reference signal in what's called the "vertical interval". You may have seen this as a series of flashing dots or pulses at the very top of the picture. There's a lot of information packed into the VITS (Vertcal Interval Test Signal). One of the lines contains a reference pulse for video which is set at a certain level. Your TV sees that level and automatically adjusts its circuitry accordingly. What I suspect is that your set is out of calibration and is pushing down the video signal because it is not "seeing" the level properly. A video alignment should correct this and can be done by a good repair facility. Hope this helps.
Oct 31, 2006 | Toshiba 32AF44 32" TV
The TV turns on and you can hear the sound but the picture is dark except for a thin line of blue dots in the center of the screen.
You have whats known in the biz as a cold solder connection on the vertical output IC or on the associated components. Not a job for the handi-man unless you know the issues with safty, and precautions to take with Hi voltage inside of tv sets. Shouldnrt cost much for the local shop to find your problem . Now on rare occations the poor connections are inside the IC and the IC has to be replaced. Good Luck
Jun 17, 2006 | Panasonic CT-25G6 25" TV
Panasonic CT-2789VYD 27" TV Logo
48 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
