Question about Intex 2000 GPH Salt Water Filtration Pump with Saltwater Chlorine Generator
Service light comes on for just a second then goes off
My klv-21sg2 sony LCD color tv red light blinks 1 second and off for 2 seconds
OCP ( Over Current Protection ) . Your TV need a thorough checkup. Contact any experienced service technician.
Sep 04, 2012 | Sony WEGA KLV-21SG2 21 in. HDTV-Ready LCD...
The light comes on for A few seconds amd goes out. The back light comes on for A few seconds dimly and goes out how do you open the monitor and fix it?
Here are the free service manuals: http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL1917&kategoria=&kat2=schematics
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
May 10, 2010 | Acer AL1917W LCD Monitor
When I press power, light blinks for about 15-20 minutes, then goes off. Press power again, on solid for 30 seconds, then goes off. Press power again, TV finally comes on.
Your television is in need of repair. Hard to tell what exactly needs to be repaired but when the power light blinks in that way then this is the TV's way to tell you it needs to be serviced.
Apr 25, 2010 | Toymax Magnavox 37MF331D 37 in. LCD TV
The yellow light in the top left hand corner of my Toyota Corolla Verso (2004) has come on - Why????
I believe it is the "SERVICE" light. Try this:
1. Turn the ignition all the way on.
2. Turn the ignition off.
3. Press in and hold the trip meter reset button.
4. Turn the ignition all the way on. I noticed the service button blinking
5. After about five seconds, turn the ignition off. Then release the trip meter reset button
6. Turn the ignition all the way on. The service light comes on and then goes off after a few seconds.
GOOD LUCK > > > >
Nov 25, 2009 | 2004 Toyota Corolla
Delll Inspiron 2200 Laptop does not power on
You have all the simpthoms of an overheating laptop.
For starters, get a vacuum and **** all the dirt from the fan or fans on the back/ bottom of your laptop.
Then turn on your laptop. It should stay longer than 5 seconds.
If this solves your problem, then you are lucky.
If not, you'll need to have your laptop serviced, and clean the heat sink, and have reapplied the heat transfer compund on the processor.
Not a big deal, and not that expensive either.
If this answer helps, please don't forget to rate.
Jun 22, 2009 | Dell Inspiron 2200 Notebook
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Service reset for S80 2002 2.9 liter
Press and hold the odometer reset button. Turn the key one position and pause for one second. Then turn the key once more until all the dash lights come on. Hold the button until the SRS light (picture of a guy with a air bag in front of him) goes out. As soon as it goes out release the odometer button quickly. It should be about fourteen seconds. Then turn the key off and start the car.
I can't remember if it's the 2001 or 2002 that is changed. One is like this, but the other is the triangle will flash of the "service due" light will come on. If you've tried the others I hope this will fix it.
Mar 10, 2009 | 2002 Volvo S80
Intex 2000 GPH Salt Water Filtration Pump with Saltwater Chlorine Generator Logo
20 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
