Hard reset for vizio l42 keeps powers on then off again
3 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: vizio L42, wont turn on
Usually when this happens, the TV is in Protection Mode. When the TV detects something has gone wrong inside, the TV will prevent itself from turning ON.
Try leaving the TV unplugged for 30 -45 minutes so the TV can discharge and reset itself. If this doesn't fix the problem, most likely it's a power supply board related issue. At that point, you may want to get a price quote from a local TV repair shop. The cost of fixing the TV may exceed the price of a brand new TV.
Posted on Aug 07, 2009
SOURCE: Vizio L42 - sound set to 0 and still loud distorted sound
I unplugged the TV and let it sit for about an hour and now appears to be working as before. Still strange, have never experience this before. I could understand no volume.
Posted on Sep 03, 2009
How do I fix my Vizio TV model E421VA? Details are below. It has a black screen and no audio.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Nov 01, 2016 | Vizio Televison & Video
My Vizio flat screen tv won't power on sporadically! The Vizio name lights up bright and the Vizio icon appears in the middle of the screen but sometimes that's all it does.
http://electro-medical.blogspot.com/
Apr 01, 2016 | Vizio M3D470KD 47 inch Class Theater 3D...
I own a Vizio VF550M and all I'm getting is the "Vizio" logo is lit orange and won't turn on, nothing. I ordered in a new power supply, put it in, and still the same results. What could be causing th
A corrupted firmware can cause this. Just do a hard reset to this TV, and check. If it do not help you, contact the authorized service centre for Vizio. The firmware to Vizio is not available by internet.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Dec 09, 2014 | Vizio VF550M 55 in. LCD HDTV
Unlock it but forget pattern
So don't shove it up. Instead of that pull out the battery and it will turn off your tablet. Then follow this: Press volume up and down at the same time, when you have it press the power button as well until you can see the lights turning on. It might take a minute but keep waiting. When you got that release the power button BUT keep pressing the volume up and down if you are doing it right you gon see the Vizio logo and then it will change to a triangle with an exclamation sign it it. When you got that you can release the volume buttons then tap the home button and you gon have a menu what we call Recovery Menu. You will find the instructions there how to hard reset your tab. You will loose all your info but you can use your tab again :) If you got any questions, let me know :)
Feb 22, 2012 | Vizio Tablet VTAB1008
Sep 03, 2009 | Vizio L42HDTV 42 in. LCD Television
Vizio L42, wont turn on
Aug 06, 2009 | Vizio L32 32 in. LCD HDTV
My remote wont work with my tv
The receiver for the remote is on the right side. Do you have something in front of it? My remote will not work if there is an object on that side of the TV.
Apr 09, 2009 | Vizio GV42L 42 in. LCD Television
I have a 42 inch vizio plasma t.v. and I have power but no sound or picture, I've unplugged it all night and still doesn't work! It's
For the 42" plasma, you need to change your sustainer boards or your main board to fix the problem. If your TV is still under warranty, call 877-MY-VIZIO and they will have a technician go to your home and fix the problem for free.
For the L42 HDTV, you need to change the inverter boards or the main board. If your TV is still under warranty, call 877-MY-VIZIO and they will have a technician go to your home and fix the problem for free.
Jan 26, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Device code for my Vizio TV
OK. here is the code '0030' try that. it work on me.
Dec 21, 2008 | Motorola Mobility DRC800 Universal Remote...
Lcd screen is broken
U need to get a replacement Screen. There is no other way.
Dec 18, 2008 | Vizio L42HDTV 42 in. LCD Television
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
