Question about Black & Decker Jump Start System 450 Amp Instant Starting Power/ Compressor
Endurance 450 amp jumpstart and 260 air compressor end616..can we buy a replacement battery?
MY pEAK 450 BATTERT CHARGER WONT RECHARGE WHY
The internal battery may be too old to be useful any more.
Nov 18, 2013 | RoadPro Road Pro 12 Volt Dc Portable...
Can a Duralast jump starter kit start a car while plugged into an outlet?
The charger to a Jumpstart charges at a low rate (300mA to 500mA) and will not push enough current to start a car. Best to have Jumpstarts recharged every 6 months to be ready for emergency.
Nov 26, 2012 | RoadPro Road Pro 12 Volt Dc Portable...
If you hook up the leads wrong and then get no response of any kind have you stuffed your jumpstarter or is there a fuse you could get replaced
there are no fuses to replace(other than a reset switch on the back) if you get no responce from the unit even when you charge it then the interal circut bord is fried. it will still deliver a charge to jump start until the battery dies. after that its trash because it is not recommened to charge the intermal battery with a standard battery charger it may explode since it is a sealed lead acid battery
Feb 12, 2011 | RoadPro Road Pro 12 Volt Dc Portable...
Hello. I have a duralast jumpstart kit. After
Hi, usually after you drain the unit down it will take up to 4 hours for it to charge up 100%. but do not leave it on the charger all the time when not in use because this decreases battery life.
May 23, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
I have the endurance jumpstart i need to know how to charge it so i may use it
a charger of the wright polarity and volts (12-14.5volts) that can charge at say 500ma and fits the charging scocket in the power pack will charge your power pack up ok
Mar 28, 2010 | Black & Decker Jump Start System 450 Amp...
Black & Decker Jump Start System 450 Amp Instant Starting Power/ Compressor Logo
53 people viewed this question
Top Black & Decker Hammering Experts
Gary Nitowski
Piyal Perera
Piyal Perera
Are you a Black & Decker Hammering Expert? Answer questions, earn points and help others
