Kenwood LS-56 audio leads
How do I turn the volume up and down on a Kenwood tuner KT-56
Hello, according to the information I have, the Kenwood KT-56 tuner is just that. This means in order to have volume control you will need an amplifier. The KT-56 only allows changing of the stations, pre setting stations and may be a couple of more options. But it is only a tuner or simply put a display, now you need to put power behind it to make it put out sound.
Jun 17, 2016 | Kenwood Audio Players & Recorders
How do I set the FM radio stations on buttons 1 to 8
Try tuning to the station you want and then just keep the button pressed down on the preset you want to store it to until it saves
Jan 30, 2014 | Kenwood Kt-56 Stereo Synthesizer Tuner
How do you set the clock?
p.11/56 in the user manual explains specifically how to manually adjust the clock. Here is the manual:
http://dl.owneriq.net/c/c45b01b8-349f-c204-e5a9-fc90617d7c67.pdf
Thank you and enjoy,
Lee
Aug 19, 2010 | Kenwood KDC-138 FM / AM Receiver
Installing a kenwood kdc-135 in a 2001 monte carlo ls
Hello, my name is Israel and I will help you. The following should be able to help you out. Please rate and good luck.
constant 12+ orange
switched 12+ yellow
ground black/white
illumination gray/black
dimmer brown white
Left Front + tan
Left Front -
Apr 13, 2010 | Kenwood KDC-135 CD Player
Where does the rem cable go to on the kenwood krc 443?
If you are talking about the remote lead from the amplifier too the headset, it attaches to the blue/white lead on headset which can also operate an electric aerial
Feb 02, 2010 | Kenwood KRC-394 Cassette Player
How do i connect them
I connected the red & white audio leads to the line out sockets on the equalizer and connected them to the tape rec sockets on the amp..
May 29, 2009 | Kenwood Audio Players & Recorders
Unsure what is needed to install this product myself.
You should just need what you got matey! should just plug and play! the only thing u might need is a lead from the headunit to audi wiring which if you go into your local car audio shop and ask for a iso lead for kenwood to audi they will sort you out. normally around £15
Hope this helps
Upfront Audio
Apr 20, 2009 | Car Audio & Video
Kenwood KDC-MP2032 radio wiring color
YELLOW goes to the battery lead
RED goes to the ignition on lead
BLACK goes to chassis ground
Apr 05, 2009 | Kenwood KDC-MP2032 CD Player
Kenwood kdc516s, cd audio does not work, it can be inserted and removed, it shows track information and elapsed time but there is no sound, is there a fix?
If your car has a factory amplifier, you probably tied the kenwood's antenna turn on lead (blue) with the factory amp turn on wire. That bue wire only supplies voltage when your source is tuner. you need to use the kenwood' amp turn on (blue/white) to get the factory amp to turn on with the cd player and the tuner
Dec 03, 2008 | Kenwood KDC-135 CD Player
Kenwood kdc-128
The remote lead on the back of the radio should be a blue wire with a white stripe. If this wire is not present, then you can use an accessory lead in the car or the accessory lead (red) at the radio harness. Hope this is helpful.
Sep 14, 2008 | Kenwood KDC-128 CD Player
76 people viewed this question
 Grubhead
Grubhead
