Question about Refrigerators
GR-L207QVJA ice tray wont tip
4 Suggested Answers
woodchuck789
  • 4059 Answers
SOURCE: LG fridge freezer GR-L207QVJA.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Jul 01, 2009
  • 6 Answers
SOURCE: ice tray won't tip
there is an arm in the ice dispenser which tells it its empty there will be a bit of ice stuck holding it up put your hand in and clear it away hope it helps ej
Posted on Jul 30, 2009
imufo2
  • 3773 Answers
SOURCE: ice cube tray is full of ice but it is not tipping
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 24, 2011
I have an LG Refrigerator. GR-559FSDR 121T0063 Serial No. 102KRXD00130. It is giving an alarm like the door is open every few seconds. Both lights are off, when you open doors.
Check the freezer doors. Pull the tray out of the top drawer and see if there is ice build-up behind it causing it to not close all the way. I had to defrost my freezer to get rid of it. It also helped the ice fan from icing up stopping.
Apr 18, 2017 | LG Refrigerators
Ice cubes wont come out when the dispenser tips it upside down
The ice mold tray has built up deposits that "glue" the ice cubes to the tray. This usually means you will have to change the mold tray. You could try vinegar or lemon juice to clean it but the trays are not that expensive.
Apr 12, 2014 | Refrigerators
The ice maker does not seems to dispense any ice. It does have ice in the tray but won't tip into the ice bucket. Water dispenser works fine. If you turn the ice maker off and turn back on again, sometimes...
The fix to your problem is to remove the ice, warm up the tray with a hair blow dryer and thoroughly dry it. Then spray it with PAM cooking spray which is an edible lubricant. After that dries, turn on the ice maker again and the ice will dispense. Joe
Mar 08, 2010 | Fisher and Paykel E522BRXUSS Stainless...
Ice tray won't tip
Jul 30, 2009 | Samsung RS2630SH Side by Side Refrigerator
LG fridge freezer GR-L207QVJA. The ice dispenser gives a choice of crushed ice or ice cubes, but has stopped dispensing ice cubes and gives crushed ice on both settings.
Jul 01, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Ice tray wont flip
check the very back of the ice maker and see if the piece that holds the rear portion of the ice maker has broken into little pieces causing the tray not to flip. the piece costs around 12 dollars and should be available for the unit that you are talking about. Thanks for using FIxYa and please don't forget to rate the solutions when thru please. Tahks again and have a great 2009!
Dec 27, 2008 | Samsung RS2630SH Side by Side Refrigerator
I have an lg model=gr-l206cvqa fridge freezer, the ice box keeps freezing solid into one big lump of ice
Ice cube tray needs to be replaced if you are referring to the ice bucket area freezing all up. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Refrigerators
Not getting any ice
test the drive motor for operability. the motor is what tips the tray.
Nov 17, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
