Question about Watches
How do I reset my timex expedition 820 watch after changing the battery?
2 Suggested Answers
SOURCE: watch battery replacement
I have a Timex Expedition Indigo with a metal case. Not sure of the exact model number but on the back there an M6 below Expedition. Anyway, I had the same problem of snapping the back back on. I found a "battery" website that had some suggestions that should be typical of any snap back case watch. http://www.online-batteries.co.uk/whichbattery.shtml specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment. The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even. Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it. Good Luck, Richard
Posted on Sep 28, 2007
I have timex expedition watch model T49664 with altitude. It works well for last 3 years then battery died. Twice i change CR2430 even once in timex showroom. But the battery dies in 15 days. Plz help
After changing the battery press and hold all the buttons at the same time to reset this will make the watch and battery works properly so that the battery wont drain easily. I hope I have been helped you.
Nov 09, 2014 | Watches
CHanging battery on timex expedition, cover says
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you.
Apr 09, 2010 | Timex Expedition 84601 Wristwatch
I have a Timex Expedition and I use the automatic restart timer for work. When I got the battery changed I no longer had the feature. I have to reset each time.
If you haven't got any instructions you can get a copy from their web site.
If you have instructions and they are of not help, I suggest that you contact Timex and tell them of your problem.
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Feb 22, 2010 | Timex Expedition C45981 watch
HOW DO I CHANGE THE BATTERY ON MY TIMEX 40691
http://www.timex.com/info/Product_Instruction_Guides_Downloads
There are so many applications use of the manual will be mandatory.
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
Feb 01, 2010 | Timex Expedition Camouflage 40691 Wrist...
I have a Timex expedition chronograh. Every thin
The nice thing about Timex is they have a 12 month warranty that covers just about everything. If you have had the watch longer....
Get the batteries checked. Battery life is typically about 2 years.
If the battery is fine then you can try having the watch reset but in most cases the LCD board or circuit board is damaged the watch has to be replaced to have it function correctly.
Sep 16, 2009 | Timex Expedition 84601 Wristwatch
I recently had my battery changed on a timex expedition adventure tech altimeter watch, now the chime doesn't work and the alarm doesn't beep. Please help. Thank you.
You can attempt to have the circuit board reset if it has an "AC". This may or may not fix the problem. Usually when a sound board goes out you have to replace the whole circuit board or movement.
Sep 14, 2009 | Timex Expedition Adventure Tech Altimeter...
Adventure tech doesn't have chime
could be following reason
1, you did not put case back correctly,
2, small spring which connect watch movement from caseback for chime lost during battery change ,
3, may be required reset of AC & Battery plus ,, by twizer
hope this help
AmFix Jewelry & Watch Repair
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
email: info@goamfix.com
web: www.goamfix.com
Sep 14, 2009 | Timex Expedition Adventure Tech Compass...
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
May 12, 2009 | Timex Expedition 84601 Wristwatch
Expedition Indiglo Waterproof 50m
how much is this worth my uncle gave it to me
Jan 17, 2008 | Timex Expedition 40141 Wristwatch
Resetting Watch
Here's the inside of my Timex Expedition Dive watch. To reset the watch after replacing the battery, press down with a small screw driver on the metal tab that the red arrow is pointing to.
Nov 20, 2007 | Timex Expedition 84601 Wristwatch
Watches Logo
35 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
