Question about Dryers
Wascomat td75 e14 - Dryers
2 Suggested Answers
  • 205 Answers
SOURCE: wascomat TD75 gas dryer is
HI- If it is electric (220V) you may have a bad plug or outlet that is shorting the circuit breaker. Usually when there is a short in the unit it does not blow the breaker. Leave the breaker off and take the plug out and have a look for any burt or melted parts. If that looks ok then have a Tech look at the dryer, something is shorting or going to Ground and putting enough load to trip the fuse. Wouldn't keep trying to start it. I know, not much info but someone really need to be there to look at it in person. Best regards.
Posted on Sep 24, 2010
Wasco td 75, error code E-15
Although I cannot find anything that explains what error code E-15 means for the TD75, I did find an exchange with a technician that explains what the error code means for a TD30/30. If it is similar, the exchange also describes the areas of machine to check for issues.
Wascomat Dryer td 3030 15 Error Trouble Shootings
Jun 30, 2017 | Office Equipment & Supplies
Dryer shows error 8-overheating in or out air. I run thru the reset sequence but it continues to show the error code.
Your thermocouple is reading high, which could be a multitude of factors. We'll go through them from easy to hard:
First, check your dryer vents and make sure they are clean and that you have proper air flow coming in and out of the dryer.
Next, make sure that your motors in your dryer aren't running too hard (check for how easy it is to rotate the drum and the fans when the dryer is off).
If you're still facing problems, try cleaning your heating element, and finally replace the temperature sensor. If none of those things work, you're facing an internal computer issue which isn't likely user serviceable.
Nov 02, 2015 | Wascomat Parts Wascomat 986918 Washer...
My Wascomat TD77 dryer keeps shutting down after 5 minutes and shows E 14. What is wrong with it.
Taken from the following: https://www.wascomat.net/pdfs/487032981.pdf
This is for a different model, but the codes are likely the same.
It is related to non-ignition of gas. You may need to switch on your gas supply, or service your ignition coil.
Resetting gas error
When the ignition control fails to detect a flame a error code E14 is displayed. When this condition occurs, the gas valve is shut off and the ignition control must be reset manually.
Resetting
Open the operating panel and press the gas reset button on the back of the user module board for one second.
See the picture of the gas reset button section 21
NOTE! When resetting the system the dryer must operate on a program with heat and when the heat indicator is on.
Error code
Error code 14 is a normal occurrence when first starting up a dryer, since air in the gas line must be purged.
Aug 26, 2014 | Dryers
Wascomat w655s what is error code E13 ?
www.teetersproducts.com/.../Used%20Equipment/.../Wascomat%20-%20...
Jul 13, 2014 | Wascomat Parts Wascomat 973957 Washer...
Wascomat 16n4 front of drawer broke off. how can
I have a Wascomat W655CO,
This morning I got a screen message, Wait doors is locked?
I waited but the door never unlocked?
Oct 26, 2013 | Wascomat Parts Washing Machines
Need programming manual for wascomat w655co
Got a Wascomat W655CO and I got a screen message, Wait door is locked
Door never unlocked?
Oct 15, 2013 | Wascomat Parts Washing Machines
Wascomat TD75 gas dryer is not starting, just blow the fuse on the board inmediately
Sep 24, 2010 | Dryers
Dryers Logo
556 people viewed this question
Top Dryers Experts
