Question about InSTEP Safari TT Single AR165 Jogger
Fold down need a vedio - InSTEP Safari TT Single AR165 Jogger
How to fold down back seats in a ford courier 2000 model pls
How to Fold or Adjust 2nd and 3rd Row Seats In Your Ford
https://www.holidayfordusa.com > Home > Tips & Tricks
  1. Cached
How to Fold Down Your Ford's Rear Seats. By blogsadmin ' Posted in Tips & Tricks on Friday, February 3rd, 2017 at 3:25 pm. How to Fold or Adjust 2nd and 3rd Row Seats In Your Ford. Your Ford vehicle is designed so that you can get the most out of it regardless of what your driving needs might be. When it comes to the ...
Ford Explorer REAR SEAT won't fold down FIX!!! - YouTube
2q==? 1:07 https://www.youtube.com/watch?v=Ey84DueibLE
  1. Similar
Feb 2, 2013 - Uploaded by apeman63 Many people with a later model Ford Explorer have experienced an issue with the REAR SEAT not folding ...
How to Fold Down A Super Crew Backseat - Ford F150 Forum ...
https://www.f150forum.com > Late Model F150s > How-to Section > Interior
  1. Cached
  2. Similar
Jul 26, 2010 - Interior - How to Fold Down A Super Crew Backseat - To Fold Down a Super Crew Backseat 1. Fold up the lower portion of the seat. (This moves the seatback forward a little, to get your hand between the seat back and the truck wall) 2. With your left hand palm facing toward the back of the truck and thumb ...
Ford Courier Service Repair Manuals on Motor Era
Mar 02, 2018 | Ford Cars & Trucks
07 corvette top will retract but deck lid makes no effort to close, then top will not go back up. Need to release pressure in block lift top up about 1/4 of way then top will go back up
Manually Moving the Folding Top from the Down Position
Important: Allow the system a minimum of four minutes to bleed down pressure after the last cycle.
Manually release the folding top cover latch using the emergency release cable.
Raise the folding top stowage cover.
Manually raise the folding top, holding the 5 bow up.
Manually lower and latch the folding top stowage cover.
Manually unfold the top and latch per normal procedure.
Manually Moving the Folding Top from the Up Position
Manually release header latch per normal operation.
Manually lift front of roof off of the header and raise the #5 bow at the same time.
Manually release the Folding Top Cover latch using the emergency release cable.
Fold the roof down into the well.
Manually close and latch the folding top stowage cover.
Power Folding Top System Components
The power folding top system consists of the following components:
• Folding top control (FTC) module
• Body control module (BCM)
• Folding top control switch
• Serial data communication
• Folding top cover latch actuator
• Folding top cover pull down actuator
• Folding top pump motor with valve manifold
• Position switches and limit switches:
- Pin receiver switch
- Luggage barrier switch
- Folding top cover open switch
- Top open switch
- Top closed switch
- 5 bow raised switch
- 5 bow lowered switch
• Tonneau release relay
• TONNEAU PULL DOWN ACTUATOR Fuse 20 A
• TONNEAU RELEASE Fuse 10 A
• BATT 2 Fuse 40 A
• REAR FOG/ALDL TOP SW Fuse 10 A
• Folding top mechanical components:
- Folding top
- Folding top cover
- Folding top valve 1
- Folding top valve 2
- Folding top valve 3
- Hydraulic lines and cylinders
Folding Top Cover Latch Actuator
The power folding top system includes a folding top cover that is powered open and close by a hydraulic system that is controlled by the FTC module. A power unlatch motor is used to unlatch the folding top cover before the folding top control (FTC) module powers the top cover open. The folding top cover unlatching is requested by the FTC module via class 2 message, but is executed by the body control module (BCM). When requested, the BCM applies battery voltage through the folding top cover release relay control circuit to the tonneau release relay. The relay is energized and battery voltage is applied through the folding top cover release control circuit to the latch actuator. The actuator is energized and the latch releases the folding top cover.
The electronics on this are very complex ,
System Operation
Before any movement of the power folding top is allowed, the folding top control (FTC) module must be aware of the following conditions:
• Unlatch the header. The FTC module reads the pin receiver switch is Inactive.
• The windows must be normalized. Refer to Power Window Reinitialization.
• The ignition must be placed in Accessory or RUN.
• The transmission must be placed in PARK, or with manual transmission, the park brake must be applied.
• Trunk status must not be ajar.
• The luggage barrier must be in place.
• The pump motor temperature must be within the operating range.
After the last cycle of power folding top operation, allow the hydraulic system a minimum of 4 minutes to bleed down before attempting manual operation of the top.
Your best bet take and have it checked for DTC'S - diagnostic trouble codes .
DTC B3666 Rear Tonneau Position Error
DTC B3667 Tonneau Release Circuit
DTC B1011
DTC B1291
DTC B1420
DTC B3602
DTC B3666
DTC B3667
DTC B3670
DTC B3971
Jan 23, 2017 | 2007 Chevrolet Corvette Convertible
2nd Row Headrest Stuck in Upright Position and will not Fold for Stow n Go
You will need to take the seat apart to determine what is not fastened to release it.
Apr 09, 2014 | 2011 Chrysler Town and Country
I can't into my trunk there is something stuck therefore i need to fold down my rear seats and move it but i don't know how to fold them down I trie but i got nowhere
Be sure that your model has fold down rear seats...you should see the seperation around both rear seats...if equipped, the fold down release is located at the top corner of each rear seat...pull the lever up to release...if your model does not have the fold down option...you will need to remove the rear seat...remove the lower cushions first...look on the lower front of the seats for hold down bolts...second you will need to remove the top of the rear seat...hold down bolts are at the bottom of the top cushion...after removing the bolts (one each side) you need to push up on the cushion to remove...this will then allow access to the trunk...find the trunk latch and try to release by twisting the latch cable...Hope this helps...
Jan 20, 2011 | Pontiac Sunfire Cars & Trucks
Stylus - Morocco Travel System Stroller: how do you fold stroller down to fit into car?...
please help me i really need your help on how to fold it down i am only 9 and i need to fold it down . i have this pram cause i have a dolly called sophie
May 05, 2010 | Graco Stylus Morocco Travel System...
Need to get an old toshiba 50" rear projection out of basement...do they come apart?
on most rear projection tvs there are two screws that hold the mirror in the back portion in the out position they are normally located on the flat part of the back next to the curved plastic they are removed and the mirror is hinged to fold in to allow to fit through doorways if that is the problem if weight is the issue they can be dismantled farther would reccommend
take digital pictures or vedio to allow you to put back together if you are going to reuse
Dec 10, 2009 | Toshiba 50H81 50" Rear Projection...
PC SHUTS DOWN WHILE WATHING VEDIO ON INTERNET
while starting. press F8 thne disable windows autorestart. ask more
May 07, 2009 | Computers & Internet
InSTEP Safari TT Single AR165 Jogger Logo
22 people viewed this question
Top InSTEP Baby Gear Experts
Jennifer Rock
Jennifer Rock
Are you an InSTEP Baby Gear Expert? Answer questions, earn points and help others
