Borg warner Is the old round York Borg/Warner thermostat incompatable with a Honeywell? I just replaced my old round mercy switch thermostat with a Honeywell RTHL111 thermostat. The air conditioner service man says it is hooked up right, but the fan on the unit will not run on auto (it must be in the on position on the thermostat [thus the fan runs all the time]). He also replaced a relay switch inside the unit. We are using air conditioning only on this unit. Red to R (strapped to Rc), green to G, Yellow to Y. The only conductors available from unit to thermostat. Has worked great in the past. The new thermostat cycles the compressor as it should.
motor1258
  • 6674 Answers
SOURCE: Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Posted on Aug 14, 2008
  • 726 Answers
SOURCE: 93 Grand Am 3.3, engine dies when hot
check the airflow meter sensoe,could be distributor also if the fuel pressure is going down on acleration could be a blockage in the injectors on injector might be getting to much fuel or the airflow meteris playing up thats the best bet
Posted on Sep 02, 2008
koolbreezes
  • 540 Answers
SOURCE: got a honeywell t8400c thermostat
R--- rc or rh y--yellow g---green w--white red is power yellow is cool g--fan white is heat
Posted on Sep 03, 2008
co7196
  • 3433 Answers
SOURCE: coleman rv rooftop unit, fan runs in on but in auto nothing works
R = HOT 12V
W= WHT- GND
Y = YELLOW / POSSIBLE THERMOSTAT
G= GRND FOR THERMOSTAT
f = FAN
F=FAN
aSSUMING THIS IS A TWLVE VOLT SYTEM- The two f's Would be fan control intake and exhaust - fan direction
White is always ground and so is green.. green is more of a static ground where white is a load grnd.
Red is always hot. in low voltage
I hope this helped. No instructions in kit?
Posted on May 18, 2009
  • 340 Answers
SOURCE: Replacing Old York TS to HoneyWell RTH230B
rh is hot for heating rc is hot for cooling looks to me like ya need a heat pump stat some thing to control the reversing valve.Tom
Posted on Jun 18, 2009
Resistance specs on borg warner E 262 coil packs
I don't know if this is feasible, but connect two in series for 12 kilohms?
Feb 11, 2015 | Ford Cars & Trucks
How can I install an AMC 360 engine into my 1965 rambler classic with a 287 engine?
what I did was removed the 287 engine installed an AMC 360 .In order to do this you have to get an borg warner m11 bell housing from 67 to 71 .amc used borg warner transmissions until than. So you put the m11 bell housing on to the m8 transmission and get the motor mount for the AMC 360 engine
Feb 10, 2015 | AMC Cars & Trucks
I would like to know if I can install an borg warner m8 tail section onto an borg warner m12 transmission that way I would not have to change from the torque tube subsention
I just found out that all that you have to do is . You have three options to go with one change the bellhousing from a borg warner m12 transmission. two use and borg warner m12 transmission but use the yoke head from the m8 onto the yoke of the m12 yoke .Three use a chryler/amc tf727 torque command transmission.Use the yoke from the m8 weld the head on to the spline of the 727transmission weld the m8 tail section onto eather transmission and that way you can keep the torque tube suspension on your classic 770 with the 287.Your rear end should be an AMC 20 to stand the torque from the AMC 360 engine with about 350 hp .last but at lease get the trany mounts.
How to change gearbox oil
gear + BOX
so is the transfer case, box. or the 5 speed stick box or?
what?
we drain it then fill it, to the mark.
on all gear boxes.
if A/T we RTM read the operators guide. for how to do it right,
most dont and wreck the tranny. the #1 reason they removed the filler.
when posting car issues, stated what it is.
like this.
95 Trooper, 4wd M/T , i want to change the 5speed box lube.
what do i need to do that.?
ill spin the wheel of fate, and land on 5speed box.
and answer for TR5 and NV1500 boxes.
For all transmissions except for the Borg-Warner T5R, replace the transmission fluid at the first 15,000 miles (24,000 km) and then every 30,000 miles (48,000 km) thereafter. The Borg-Warner T5R transmission does not require periodic changing of the transmission fluid. (they lie)
  1. Raise the vehicle and support safely on jack-stands. Place a fluid catch pan under the transmission drain plug.
  2. Remove the fill plug from the side of the transmission, then remove the drain plug. Be cautious when removing the drain plug: the transmission fluid can be very hot. Allow the transmission fluid to drain into the pan.
  3. Install the drain plug and tighten to 20 ft. lbs. (27 Nm) for all models except the 1996 Hombre, which requires 27 ft. lbs. (37 Nm).
  4. Refer to the manual transmission fluid recommendations for the proper viscosity of engine oil, or type of transmission fluid to be used for the T5R and NV1500 transmissions. Fill the transmission by pouring the new fluid through the fill plug hole in the side of the transmission. Fill until the fluid starts to dribble out of the filler hole. Install the fill plug to 17 ft. lbs. (23 Nm), then lower the vehicle.
so next you ask, what fluid
sure.
Use engine oil for all of the manual transmissions, except for the Borg-Warner T5R and the NV1500 (1996 Hombre). Make sure to use engine oil of the correct viscosity for these transmissions, as follows:
  • Except 1992-96 Rodeo and Trooper, high temperature-SAE 40
  • Except 1992-96 Rodeo and Trooper, normal temperature-SAE 5W-30SF
  • 1992-96 Rodeo and Trooper, high temperature-SAE 15W-40, 20W-40 or 20W-50
  • 1992-96 Rodeo and Trooper, normal temperature-SAE 5W-30
he Borg-Warner (B-W) T5R is found on Rodeo models with the V6 engine. The 1991-93 B-W T5R uses DEXRON-II automatic transmission fluid, whereas the 1994-96 B-W transmission uses DEXRON- III automatic transmission fluid.
use the highest Dexron number, on the shelf, mark III is not made today.
Jul 03, 2014 | 1995 Isuzu Trooper
Im wondering what different transfer cases came in the 91 4x4 f250? mine has borg warner stamped on it
There were 2 Borg Warner Transfer cases in you years truck. A13-56, and a 1345; both are Borg Warner cases.
Sep 01, 2010 | 1991 Ford F250
Isuzu rodeo manual trans id
cheap truck 4cyl borg warner 6cyl mua
Jan 15, 2010 | 1991 Isuzu Rodeo
Automatic Tranny to 4-speed tranny swap
Ford dealer can with the VIN of both vehicals or only one if your nice to them at the parts dept. They caneven print it out but you need to be nice to them. Bring your pretty sweetheat with you or even have her get it for you of course the parts girl may not care. But it's worth a try.
Aug 29, 2009 | Warner Manufacturing Borg Warner DS111...
What model of transmission does a 1995 Jeep Cherokee with a 4.0 L engine have?
Most common automatic is an AW4...its pretty much based on the old Borg Warner unit (If I remember correctly AW is asian warner or something close to that.)
If it's stick, It could be one of a few but can be ID'd by the vin# or the tag on the unit itself.
Aug 04, 2009 | 1995 Jeep Cherokee
Tranny
Hello rvkenneljmil: My name is Roger I can help you. You did not say what transmission you were asking about. GM used 3 different transmissions. The automatic was a 700Ra. The standard transmissions were a Borg warner and one made by Isuzu. The MW1 was made by Borg warner had a bolt up bel housing.The transmission bolts to it.The Isuzu transmission is a two piece transmission. The bell housing and one half of the transmission case are one piece. Depending on the transmission make sure you use the correct fluid in them. 90wt gear oil in the Isuzu transmission will destroy the bearings.The code numbers for the Isuzu is MG5/MY2/M50. Please rate the quality of the information you received. This is how we track that you received the answer you wanted. Thank You for using FixYa.Roger
May 07, 2009 | 1994 GMC Jimmy
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
