Question about Garden
My craftsman DLT 3000 with Honda Vtwin won't run unless the choke is fully engaged. As soon as the choke is disengaged it dies. It will only run with choke off with the throttle at the lowest possible setting. What is wrong with it?
mighty thor
  • 51 Answers
SOURCE: Sputters & quits at proper RPM for engaging trans or mowing deck
If the choke has an adjustment point, then adjust the choke to a good overall working powerband. If it still doesn't act correctly, look for vacuum leaks. If it is an option, you may want to install a manually operated choke lever.
Posted on Nov 24, 2008
jrw4u
  • 62 Answers
SOURCE: Craftsman Riding mower won't stay running
Well this could be a couple of things first thing first is check the air filter and make sure its clean you can blow it with air or pore gas over it and clean it make sure you let it dry before reinserting
second im assuming this is the first time you have used it this year if so the gas you have in it hasnt been sitting in it all year has it like anything else gas gets old
third alot of times you can let it run for a while with the choke out then slowly pushing it in
fourth you could have water in the gas remove the tank and empty it remove the spark plug turn the engine 4 or 5 times only bumping it dont hold it down this will blow some of the water out then dry the spark plug off and replace it
if this doesnt help it could possibly be carburetor problems
Posted on Apr 29, 2009
  • 153 Answers
SOURCE: Dies when clutch disengaged
It sounds like the seat switch is disconnected or failed. Check it out. If it thinks there is no **** on the seat it will cause your symptoms.
Posted on May 26, 2009
  • 33 Answers
SOURCE: My craftsman mower with a 26 hp kohler dies when choke is in
carb dirty, jets partially plugged, float sticking. Not so uncommon problem and is caused by the fuel left in the carb over the winter gumming up (going bad). You can attempt to clean this on your own if you are somewhat mechanically inclined. Search small engine repair and it will give you a generic breakdown of the parts in a small engine carb. If not the, to have someone overhaul a small engine carb will run you about $120 including parts (at least around VA).
Posted on Apr 05, 2010
  • 19 Answers
SOURCE: Craftsman DLT 3000 18.5HP - Engine Dies
sounds like the choke mechanism is stuck in closed position, causing a overly rich mixture, to check this removethe air filter cover, element and housing, there are two nuts and a 5/16 head screw somewhere that need to come off too, then pull off housing and you will be able to see the choke plate, it should only be closed when throttle lever is all the way up. when you determine if this is the pronlem or not you can email me if you want
thisoldtruck2@yahoo.com
Posted on May 18, 2010
Craftsman dlt 3000 16.5 honda engine will only run if the choke is closed
if it still won't run after cleaning the bowl...you will need to remove the small jet inside the bowl that allows vaporized gas to be pumped into the carb..it is very small you will need a needle or something similar to clear..it usualy is next to the bowl float and is vertical to the carb..good luck
May 31, 2012 | Garden
I have a craftsman mower with the B&S 21hp Intek OHV motor, it starts fine but when you go to engage the blade or go forward or backward or release the parking brake it will die unless you disengage...
Check the switch on the seat, of all places. There's a safety switch on the seat that will kill the engine if it's not engaged when do anything other than start and run the engine.
If the switch checks out, get back with me.
Jul 06, 2011 | Briggs & Stratton Briggs Stratton Intek V...
My Craftsman 42" 18.5hp lawn tractor will start fine but when I disengage the brake or engage the blades it cuts off. It was recently left out in the rain while I was working, did something short out? It...
there is a safety switch under the seat. to stay running after the brake is released or deck engaged you have to be sitting on the seat or it will die. if this switch is bad it will die as soon as you release the brake.
Aug 25, 2010 | Craftsman Garden
May 16, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman blower stalls when choke is disengaged
You need to play with the timing adjustment, either on the spark plug, or the gap between the contact and the magneto.
That'll do it ;)
Don't forget to rate, thanks
Jul 31, 2009 | Craftsman 4 Cycle Blower/Vac
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
