Question about Fish
Blue wave standard skimmer NA323 - Fish
I have a blue wave inflatable spa. the ground fault blows when I turn the heater on. Is it possible to replace the heater element? If so, where can i purchase the part?
Mark
I am not familiar with the Blue Wave inflatable spa however the ones we sell are replaceable so I would imagine that the Blue Wave one would be.
Rod
www.uspartscenter.com
Jan 23, 2013 | Blue Wave Pool & Spa
What are the main types of aquarium skimmers?
The main types of aquarium skimmers are: Air Driven CC skimmers, Venturi skimmers, downdraft skimmers, and aspirating skimmers. For more detailed information about these skimmers, check out this website: http://reefkeeping.com/issues/2002-06/fm/feature/index.php.
Sep 05, 2012 | Fish
What are the top skimmers picks?
The five most recommended aquarium skimmers are: Aqua Medic Turboflotor 1000 blue hang-on skimmer, Aqua C Remora protein skimmer, AquaticLife internal mini skimmer 115, Eshopps hang-on tank protein skimmer and the Lee's Counter Current protein skimmer. Each has its own benefit.
Aug 30, 2012 | A H Fabrications Fish
How do I use pool pulse?
From the users manual for these pool cleaners:
The Pool Pulse is a flow meter that measures the volume of water flowing through your Zodiac cleaner. It must be used to properly set the flow and can be used as a diagnostic tool when the cleaner isn't running properly.For the following steps, using 2 people is recommended; one poolside and the other at the plumbing manifold. Vacuum and skimmer valves are located at your plumbing manifold.
• Remove the cleaner head.
• Attach the Pool Pulse® to the end of the hose and keep it under water as shown in Figure 1.
• Turn on the filtration system.
• For pools with one skimmer, flow is automatically regulated by the Flowkeeper Valve. Insure the blue indicator of the Pool
Pulse is in the ideal range (when viewed from the side).
• For pools with two or more skimmers, leave the selected skimmer open and slowly close the other skimmer(s) until the blue
indicator of the Pool Pulse moves into the ideal range (when viewed from the side).
• For pools with a wall vacuum fitting, leave the wall vacuum fitting fully open and slowly close the skimmer valve until the blue
• Keeping the hose under water, remove the Pool Pulse. Submerge the cleaner head, and when the bubbles stop coming from the
extension pipe, attach the hose end. Your installation is now complete.
Apr 30, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
I copied some music to a disk with 4 different formats but the bose radio wont play any of them.
The Bose Wave Radio doesn't have a CD player. The Bose Wave Radio/CD does.
It will only play standard music CD's with standard CD Audio on them.
The manual is available at Bose.com.
Mar 15, 2011 | Bose Wave Radio
When I turn on the pool, the pacer works for about 5 minutes then just gets stuck on the wall. If I turn off the pool and reset, it starts again then stops. How can I decrease the suction or adjust the...
You need to use the Pool Pulse feature to control the flow of water through the cleaner. Here is a brief overview, but if you need more details, consult page 6 of the users manual for this pool cleaner (below if you don't have it).
"Remove the cleaner head. Attach the Pool Pulse to the end of the hose and keep it under water. Turn on the filtration system.
• For pools with one skimmer, flow is automatically regulated by the Flowkeeper Valve. Insure the blue indicator of the Pool Pulse is in the ideal range (when viewed from the side).
• For pools with two or more skimmers, leave the selected skimmer open and slowly close the other skimmer(s) until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side).
• For pools with a wall vacuum fitting, leave the wall vacuum fitting fully open and slowly close the skimmer valve until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side).
Keeping the hose under water, remove the Pool Pulse. Submerge the cleaner head, and when the bubbles stop coming from the extension pipe, attach the hose end. Your installation is now complete."
http://www.baracuda.com/resources/manuals/PacerW83410.pdf
Dec 05, 2010 | Zodiac Pacer Pool Cleaner
I have an Eagle Fisheasy fish finder & need to replace transducer do not know witch one to get. All i know is,it is a wide angle skimmer with a two prong connection
You can find out which one is serving the device you wish to repair by waving a small spade or wide metal object about a foot from each of the existing transducers and have someone else monitoring the insruments on the concole.
Sep 07, 2009 | Boating
Blue Yellow Wave
I believe what you have is a convergence problem and it is usually caused by two Integrated Circuits going bad which also opens up one or two resistors associated with them. Replacing the Convergence Ic'S - (Ik04 & Ik05) and Resistor Rk62 a 1.8 Ohm .5w. Metal Film type should take care of the problem. As far as costs involved, I would guess about $350-$425 to get repaired. With it only being about 4 years old, it should have that many more years left of good use for you.
Mar 11, 2007 | Hitachi 43FDX01B TV
Blue wave shadowing
The convergence Ics need replaced. In Hitachi, resistors and sometimes a coil needs replaced as well. The convergence/deflection PCB is available, but, the cost of that board is higher than having a servicer come to your home and repair the unit to component level. If you are not familar with this circuit, then call a servicer. Have them replace both ICs not just one. Make sure they are repairing to component level and not replacing the board. Hope this helps.
Feb 08, 2007 | Hitachi 43FDX01B TV
Fish Logo
98 people viewed this question
Top Fish Experts
Richard Lindsey ...
Tom Chichester
ThothMer
ThothMer
Level 1 Expert
Are you a Fish Expert? Answer questions, earn points and help others
