Huawei Problems B660 modem
Hi, i have used this modem for more than a year, without any issues, but removed the data sim and used it in a MIFi device. When I changed it back to the B660, the normally green light turned to orange and I cannot get it working, the WAN if off...... What am I doing wrong, is it because the MiFi APN settings is different, and now is confusing the B660? Kind regards
5 Suggested Answers
SOURCE: What router will work with my Huawei EC228 USB modem?
The Huawei EC228 is compatible with the Cradlepoint MBR-1000 and the CRT-350.
Posted on Dec 21, 2008
SOURCE: How do I hook up to Xbox Live with VZAccess MiFi 2200
I can connect using mifi2200 and play as long as I want. However I do receive the message about NAT. Says mine is set to moderate. I have no idea how to change it to Open. I did have a regular usb modem and was connecting using it. My main problem is I cannot party up with friends on xbox live because my NAT is not OPEN. But for an answer just set up and internet connection sharing through your mifi and you will be able to connect to xbox live.
Posted on Jan 01, 2010
  • 18 Answers
SOURCE: I want instructions to connect my verizon mifi to my xbox.
you need to buy a wireless reciever, after you connect it you go to system settings, then networ settings, scan for networks, and you should be good. a wireless adapter runs about 100 bucks
Posted on Jan 21, 2010
  • 119 Answers
SOURCE: Unlock Idea Net Setter, Unlock huawei USB Modem
http://eazy-unlock.webs.com/
FREE you get unlock code FREE VISIT NOW
Posted on Jul 10, 2010
How do i unlock the wireless modem huawei e586
Hello. You can unlock your Huawei E586 modem safer and easier using unique unlock code. You can get the unique unlock code for a Huawei E586 modem from ProUnlocking.com at affordable cost with an easy unlocking guide. Good luck.
Dec 10, 2014 | Huawei Technologies Huawei E586 White Hspa...
My device Huawei E586 Wifi has worked for years on both mine and husbands iPads for years, now not connecting, shows connected but keep getting unable to connect, no internet connection message?? What has...
You can always reset/restore the device. If it has a sim card, remove it and try putting it back again. The normal reboot will usually fix the problem. If the problem continues, contact your service provider for more troubleshooting options and/or possibly replacing the device.
Nov 02, 2014 | Huawei Technologies Huawei E586 White Hspa...
How to insert sim card
Probably nowhere. A desktop is not made for that, so I have a Mifi (MobileWifi)
Mine is from Vodafone and is a Huawei enclosure with SIM card slot. this Mifi sends out a Wifi signal I can connect up to 5 computers, tablets or desktops with Wifi-card to.
so for this solution you need:
1. A Wifi-networkcard in your desktop. Laptops do have it standard, because they are meant to be mobile devices.
A Wifi- network card for desktops to be installed inside the desktop.
You will need to install also a driver from a disk or download from support site from the manufacturer.
http://www.tomshardware.co.uk/forum/24164-43-whats-wireless-adapter-desktop
2. A Mifi where the SIM can be inserted.
Do a Google search for mobile hotspot to find a Device for that.
Jul 25, 2014 | Dell Optiplex 755 Desktop Desktop Computer...
PLEASE help unlock my device E5331s-2 IMEI::860667017553111
Hi. You can unlock your Huawei E5331S-2 safer and easier using unlock code. You can get the unlock code for a Huawei E5331S-2 from SimpleUnlocking.com at affordable cost.
..............UNLOCKING INSTRUCTIONS..............
If your Huawei Device is a mobile phone:
1.Switch on your Huawei Phone using another networks SIM card.
2.Your phone should ask for an unlock code(NCK Code).
3. Enter the unlock code we sent you.
If your Huawei Device is an USB modem, please follow these instructions:
If your modem software asked for an unlock code when you tried using another network's SIM card, directly enter the unlock code we sent you when prompted by the software.
Otherwise try one of the following
Method 1:
This method requires your PC to have a software called Hyperterminal which can be found on the Start Menu in Windows XP, 2003 and other older versions of Windows:
Start - > Programs -> Accessories - > Communications - > Hyperterminal
1.Remove all other modems, printers and other devices connected to your PC other than your monitor, keypad and mouse.
2.Start your pc, connect your USB modem and open Hyperterminal.
3.Enter any name and select any icon and click OK to continue.
4.Set Connect using to your modem port, Huawei Mobile Connect - 3G Modem or the right COM port.
5.In the properties window that opens, without changing any values, click OK to continue.
6.Type the following command(replace the word UnlockCode with the unlock code we sent you):
AT^CARDLOCK=UnlockCode
and press enter.
7.Your modem should now be unlocked. Close Hyperterminal, disconnect your modem and connect it again.
Method 2:
Use this method if Method 1 does not work or if you are not able to follow method 1.
If your PC does not have Hyperterminal or if your using Windows Vista or Windows 7 you can use the following method.
1.Download our Modem Communicator Application. This application has been scanned by Mcafee and contains no virus. For your safety, please scan the application again after you download it.
2.Switch off your PC, remove all other modems, printers and other devices connected to your PC except your monitor, keypad and mouse.
3.Start your pc, connect your USB modem and open the application you downloaded(mc.exe).
4.Click on the Check for Ports button and wait for the response.
5.Click on the Check for Modems button and wait for a response.
6.Click on the Send AT Command button and make sure you get the response "OK".
7.In the text-box next to the Send User Command button, type the following command(replace the word UnlockCode with the unlock code we sent you):
8.Click on the Send User Command button.
9.Your modem should now be unlocked. Close the application(Modem Communicator), disconnect your modem and connect it again.
Jul 14, 2014 | Huawei Unlocked E5331 Wireless Hspa 21m...
NO INTERNET CONNECTION
Hello Here is the website for instructions: Huawei B660 modem dhcp settings
May 26, 2014 | Computers & Internet
I forgot my sim number and lock code
Hi Reyton,
Please contact your service provider and provide them the IMEI number of the MIFI device where in turn they should provide you the unlock code of the device.
May 10, 2014 | Novatel MiFi 2200 Mobile WiFi Hotspot...
I need to get my alcatel one touch link y800 unlocked
Hi Guys,
You can get instant & free online firmware flash code from here http://unlock4modems.com/huawei-gsm-firmware-flash-code-password/
Unlocking Solution for Huawei Latest USB Dongle Modems, USB Wingle Modems, Mifi Clouds, CPE Routers, Wireless Gateways is available on this website. Just Visit Now and Get a Lot More.
Unlocking Solution available for Huawei E8372h, Huawei E8377, Huawei E3372H, Huawei MTS827F, MegaFon M150-2, Huawei E3372h, MTS 8211F, 8210FT, 8210F, 8211F, Huawei E5573Bs-320, Huawei E8372H Wingle Altel, Huawei E8377, 827F, MTS 827F, MTS 829F, MegaFon M150-2, Huawei E5573s-606, Huawei B310, Huawei B310s, Huawei B310S-22, Huawei B310S-925, Huawei B310S-927, Huawei B315S-22, Huawei B315s-607, Huawei B593, Huawei B315s-936, Huawei B593s-12, Huawei B593s-22, Huawei B593s-31A, Huawei B593s-42, Huawei B593s-82, Huawei B593u-91, Huawei B593u-501, Huawei B593u-513, Huawei B593s-516, Huawei B593s-601, Huawei B593s-931
You can also get Latest Firmware, unlocking services and buy unlock code for your device from our home page http://unlock4modems.com/#pricing
Sep 17, 2013 | Alcatel Cell Phones
How to unlock huawei EC150 SO that another sim card can be use
how to know IMEI no? i also have the huawei EC150 but dont know how to know the IMEI no. plz help meMEID- A000002DD0EF32RSN- RHWCDD230174168S/N- BVA9MB1142105252SKU- CDHW12Z2My E-mail id is janakalpa@yahoo.co.in
Mar 09, 2011 | Computers & Internet
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
