Question about Samsung DV218AEW Electric Dryer
My dryer dv218ae Samsung is showing code ts and to I clean the vent and everything else however codes are still coming up help
5 Suggested Answers
  • 5 Answers
SOURCE: dryer won't heat code he and it says the vent is
thermostat thermister damaged
Posted on Sep 12, 2009
  • 142 Answers
SOURCE: I have a Samsung DV210AE
The first thing to check is if you have 240 Volts going into the dryer. The display, lights, and motor run on 120 Volt but you need 240 V for the element.
Posted on May 20, 2011
  • 160 Answers
SOURCE: I am getting a T0 code on my dryer. I have
Thermistor open
Check for restricted vent Replace Thermistor
If you need further assistance please feel free to comment
Posted on Jul 27, 2011
  • 224 Answers
SOURCE: i have a samsung dryer dv218ae it runs but no heat can you help me
Your heater elements may be bad and need replacement. Is it an electric dryer? If so electric dryers run a dual breaker, this means 120 volts on one side of the breaker runs the motor, the other side of the breakers runs the heater coils. Its possible the heater side of the breaker has tripped. Try turning off the breaker for 20 seconds or so then reset. 220 volt breakers can trip on one side and not the other.
Posted on Oct 02, 2012
Samsung vtr error code t5 what is it
"Ts" error code usually indicates restricted air flow in the vent (could be internal or out of the dryer. In some cases could be the thermistor itself that gives out false reading.
Feb 11, 2015 | Samsung Dryers
Tip
Samsung dryer error codes
Samsung Dryer Fault Codes
ts Thermistor shortCheck for restricted vent. Replace thermistortoThermistor openCheck for restricted vent Replace Thermistor
do Door OpenCheck connections. Replace door switch.
FE Power Source Frequency errorCheck power source
dF Door circuit failureCheck wiring to door switch. Replace door switch
hE Heater errorRestricted vent. Replace thermistor.
bE Button ErrorCheck and / or replace PCB
od Over drySensor Bar open. Adjust time up excessively.
Et eeprom failureReplace Eeprom
on Apr 14, 2015 | Dryers
WHAT DOES ts error code on a samsung dryer
A ts error means that there is either a thermistor short or the vent is blocked. First check the entire dryer vent from the dryer to the outlet. Clean any lint build up and make sure that the vent isn't constricted around any objects if you have flexible ducting. Check that the flap hasn't shifted to block the vent outlet. (I've seen this a few times.)
If that doesn't solve the problem, replace the thermistor. It's part 7 on this diagram: http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Dryer-Parts/Model-DV209AEWXAA0000/1482/0151200/50039356/00005?blt=06&prst=&shdMod= . If your dryer is still under warranty, contact Samsung for the repair.
I hope this helps.
Sep 05, 2014 | Samsung Dryers
I have a samsung dryer dv218ae it runs but no heat can you help me
Sep 30, 2012 | Samsung DV218AEW Electric Dryer
I have a code poping up when i start the drying cyle the code is E5 but when it showes the code yhe top bar of the E dose not show so im guessing its an E
I believe you are describing a tS code.
If it is tS showing it is an indication that the termistor is shorted. The thermistor is the temperature sensing device used on this dryer.
Before replacing the themistor check for a clogged lint screen or dirty vent pipe.
If these are clear and you are still getting the code the thermistor would need replaced, the resistance of the thermistor should be about 10K ohms at room temperature.
The part number for the thermistor is 35001191 and is located on the blower housing in front of the motor.
Oct 02, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
My dryer shows hE code what does it mean its a samsung
Samsung Dryer Fault Codes ts Thermistor short Check for restricted vent. Replace thermistor to Thermistor open Check for restricted vent Replace Thermistor do Door Open Check connections. Replace door switch. FE Power Source Frequency error Check power source dF Door circuit failure Check wiring to door switch. Replace door switch hE Heater error Restricted vent. Replace thermistor. bE Button Error Check and / or replace PCB od Over dry Sensor Bar open. Adjust time up excessively. Et eeprom failure Replace Eeprom
hE Heater error Restricted vent. Replace thermistor. Heater error
Clean vent and replace thermistor.
Clean all vents from outside all the way to the blwer housing. If you dont get all the lint it will cause this to happen again.
If you need further assistance please feel free to contact.
Jul 24, 2011 | Samsung WF203ANW Front Load Washer
TS error unresolved on ned7200tw
I have a gas model but this is what I found on the sight and it helped :
dt63 2 Solutions February 27, 2010
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Jul 12, 2010 | Amana NED7200TW Electric Dryer
Samsung DV218AEW Electric Dryer Logo
37 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
