Question about Electrical Supplies
Quietpact 75d Generator runs for a few seconds then shuts off.
4 Suggested Answers
deme-tri
  • 90 Answers
SOURCE: New NorthStar generator with Honda GX620 runs only a few seconds.
caborator needs cleaning
Posted on Aug 02, 2009
  • 73 Answers
SOURCE: 40G quietpact rv generator shuts off the instant
the fact that it's tripping the breaker on the genset would suggest the the problem is not at the generator but rather on the load side of the genny before anything else I would seperate the generator from the rvs electrical system and apply some other load some thing fairly heavy toaster heater ect.. the fact that it's stopping the generator is a little unusual but it could just mean that the electriacl panel has a relay that keeps the generator running when the power dies so does the generator .load test should point you in the right direction I,ve owned 4 motor homes and when I wish you luck I realy mean it.
Good Luck
Posted on Oct 09, 2009
Testimonial: "Thanks a million. New discoveries- appliance turned on, throttle flips wide open,shuts down.If you manually keep it at its position,it continues."
  • 760 Answers
SOURCE: Code UU
Here is the code explained direct from Kohler's manual. I'd disconnect the generator load first.
UU Undervoltage Shutdown occurs if the voltage falls below 80% of the nominal system voltage for more than seconds. Check wiring and connections.
Reduce the load and restart the generator set. —
Check wiring and Check controller configuration, system voltage
and frequency (parameter UU).
Check AC voltage and adjust, if necessary. 5.7
Replace the SCR module and test voltage again. 4.9
Separately excite unit. 5.2
Check stator continuity
See web site for manual :http://www.kohlerpower.com/onlinecatalog/pdf/tp6196.pdf
Posted on Jul 11, 2010
How to change the fuel filter on guardian quietpact rv generator
Dec 05, 2015 | Generac Electrical Supplies
Generator will not stay running
The toggle switch automatically resets all faults when it is turned to the off position. I would turn the toggle switch off, turn off the breaker on the generator and then turn off all the loads in the house except a few lights. Turn the generator breaker back on, then turn the toggle switch back to automatic. If it starts and stays running, you were overloading the generator. Turn on other loads slowly and keep track of what is on so you don't overload it again. If it still does not stay on, you may have a problem with the panel. Let me know what happens.
Nov 20, 2013 | Briggs & Stratton 15,000 Watt Home Standby...
It back fires
If it backfires, check for manifold leaks, fuel mixture is too lean, timing is off, make sure it isn't spitting liquid into the cylinders and the LP is the right pressure, and the vapour coil is working
Oct 05, 2013 | Generac Guardian RV Generac RV Generator -...
I have a Guardian RV 3600 watt generator than wont run more than a few seconds. I have to hold my hand over the breather to get it to fire then as soon as it revs up it shuts off.
carburetor restricted due to long time storage drop carb fuel bowl unscrew the jet and pull down the fuel tube clean them and your generator should run much much better
Aug 16, 2013 | Guardian Rv Generator 4800 Watt, Gasoline,...
40G quietpact rv generator shuts off the instant something is powered on. Sometimes it does run for about a minute before shutting down. Sometimes it's running and shuts down the instant the appliance is...
Good Luck
Oct 09, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
Electrical Supplies Logo
29 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
