Question about Cyberhome CH-DVD 300 DVD Player
Dvd player wont open
Cyberhome dvd player wont open the red light is on but the tray wont open watched one movie and than when we was going to watch another the tray would not open can you help me figure out what is wrong?
  • Anonymous Jan 21, 2009
    the tray wont open
  • Anonymous Jan 23, 2009
    CH DVD300 - seldom used but now drawer is part way open but doesn't close all the way or open all the way. Button doesn't move drawer either way. Light is very light orange and when button is pressed, it turns light green. Will not run - makes no noise, as it might if it was trying to start. Help!
Look on the bottom of your player. Between the two front feet you should see a narrow slot that is about 1 1/2" long (it should say "emergency hole". Shine a light into the slot, you should see a black pin about as big around as a pencil lead. Carefully push this pin in the direction of the arrow. It should release the drawer and allow you to open it.
Posted on Aug 28, 2007
SOURCE:
How do I watch a movie?
You should be able to put the DVD in the tray and should automatically recognize it and go into the movie.
What type of media are you trying to watch. PS2's cannot play blu-ray movies.
Mar 09, 2011 | Sony PlayStation 2 (PS2) Console
Cyberhome 300 not stuck on main blue Cyberhome screen
It may not be able to read the DVD because the laser is dirty. First try to reset the system ( with no disc inserted, open then close the disc tray and hold the stop switch on the UNIT NOT THE REMOTE for six seconds). Then with the disc tray open using a can of "AIR DUSTER" - dry air in an aerosol can, insert the can nozzle into the disc tray cavity and spray away. That may blow off any dust on your laser eye. Try it again and if it still wont work,unplug the unit and remove the six small Philips screws that hold the cover on( it pivots up and off from under a lip in the front panel), plug it back in and open the disc tray exposing the laser and clean the lenses with Isopropyl alcohol and a q-tip. Do this GENTLY you don;t want to disturb the laser alignment. Dry with another Q-tip or the Airduster and re-assemble. Note well the unit will be POWERED with the cover off so BE CAREFUL. Just did this with mine and it now works like a charm again.
Dec 05, 2009 | Cyberhome CH-DVD 300 DVD Player
When we play DVDs, the picture is very dark and is
Check your dvd settings, read the manual that came with it. Or you can just pump up the brightness on the tv when watching movies.
Anyways, hope this helps.
Jul 14, 2009 | Cyberhome CH-DVD 300 DVD Player
Need code to adapt to Toshiba HD flat screen TV
If it's a regional code that you're looking for
Switch player on and make sure there is no disc in the tray.
CLose tray and press menu,1,9.
A menu should appear with the region option at about the third line from the bottom. Press enter and enter the region you want. Press enter again to memorize the code. Next press open/close. Put in your movie and enjoy.
if your movie starts playing in black and white:
To always watch in color if you do not have a Multisystem TV set Video output to Your TV system USA TVs- NTSC, Europe TVs PAL. This way You should always get color on Your TV
Hope it's what you were looking for. Good luck!
Mar 30, 2009 | Cyberhome CH-DVD 300 DVD Player
Pioneer dvd r/rw wont play a dvd
If your computer recognizes a disc in the drive and operates normally, Id assume you would need a DVD player or codec to be able to actually watch the DVD. PowerDVD rings a bell.
Have you tired that? I know Windows Media Player by default wont let you watch a movie without first downloading a codec.
Mar 19, 2009 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD problem
I have a cyberhome CH-300 my player running 50mins and next stuck the move .
Feb 12, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome 300 dvd player
try to pull the tray all way out by hand 1st knda resets it then hit close
Feb 03, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome DVR 1600 DVD Recorder
open the cover of dvr, clean the tray or replace the belt
Aug 16, 2007 | Cyberhome DVR 1600 DVD Recorder
DVD tray won't open
Hi kjflynn06 let your DVD player stand for about 2 days then you plug it in back if that does not work call a tech could be a faulty power supply good luck.
Apr 25, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
685 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
