Hp pavilion slimline s3713w
I unplugged my s3713w last night and this morning when I plugged it back in It will not turn on. There is a little green LED light that comes on in the back next to the power cord port but when the main power button is pushed nothing happens, no sound or anything
  • 66 Answers
SOURCE: getting power but wont boot up or anything
pull out everything in the computer except what's required to boot...so any pci cards or video cards (if you have onboard video). you can also try pulling out the ram (while unpowered AND unplugged) and then booting to hear beeps...if you pull the ram out and the computer doesnt make a sound, its probably a bad motherboard and needs to be replaced. if you hear beeps, try replacing the ram or disconnecting other parts...like harddrives, optical drives, modems and what not.
Posted on Apr 26, 2009
ShreyRuleZ
  • 81 Answers
SOURCE: My hp pavilion a336n will not turn on. When I plug
To resolve this issue you may need to open the chassis (the computer cabinet). You can call HP specialized support for help but they charge you for the support. You can call them at 866-211-5207.
OR - Follow the given steps.
Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure: CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC.
  1. Disconnect everything from the computer, including the power cord.
  2. With the power cord disconnected , press the power button on the front of the computer for five seconds. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps. NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply
  3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America. Performing this step ensures that the voltage switch is engaged and set correctly for your country/region. Figure 4: Voltage selector switchc00517964.jpg Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
  4. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
  5. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it. NOTE: If you find the device that was causing the problem was a surge protector, resetting a breaker or fuse on the surge protector may fix the issue.
  6. Remove all attached devices except for keyboard, mouse, and monitor.
  7. Remove any internal component that was recently added, such as video card, memory, CD, DVD, and hard drives. An added device may take more power than the power supply is rated for. If the problem goes away when the component is removed, the only option is to upgrade the power supply to power supply with a higher wattage rating.
  8. Check the power switch:
    1. With the power cord disconnected, press the power button on the front of the PC. The button should release easily and not stick in the socket.
      • If the button sticks, it should be replaced or serviced.
      • If the power button does not stick and appears to be functioning, continue using these steps.
    2. With the power cord disconnected, remove the case or side panel.
    3. Follow the wires from the power button on the front of the computer to their connection on the motherboard.
    4. Look at the power switch cables connected to the motherboard. If the cable has become disconnected, connect the power switch cable connector to the connector on the motherboard. Figure 5: Power switch connector on Motherboardc00517968.jpg
    5. Replace the side panel, plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
  9. Find the defective part:
    1. With the power cord disconnected, remove the case or side panel.
    2. Disconnect all power cable connectors from their connectors on the motherboard and from the back of internal devices (the back of drives). Make sure to label or remember where each cable connects for future reference. Figure 6: Example of common power connectionsc00540428.jpg
    3. Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
      • If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
      • If the LED is still flashing (it should not flash with all connectors removed), plug the power cable into a different power outlet that is known to be good. If the LED still flashes, the power supply should be replaced.
      • If the LED light is now off, plug the power cable into a different power outlet that is known to be good. If the LED stays off, the power supply should be replaced.
      NOTE: If an electrical storm or power surge has recently occurred, then it is more likely that the power supply, the modem, or motherboard is damaged and requires replacement.
Posted on Oct 06, 2009
  • 366 Answers
SOURCE: I have a HP Pavilion a1140n.
hmmm strange first thing id try is resetting the bios it seems it has been effected . remove case remove battery leave off for 3 minutes and replace try then again, while u have the battery out hold the power button on , oh and make sure the power is plugged out, and yeap hold power button for 3 secounds just to drain last of power from power supply. hope this helps
Posted on Nov 29, 2009
Cool Sam
  • 79 Answers
SOURCE: I have a HP Pavilion s7320n PC, It won't turn on.
open up the chasis and connect the cable coming out of the smps and going to the motherboard properly
Posted on Feb 09, 2010
mrninja
  • 600 Answers
SOURCE: my "hp pavilion a220n" won't
Check all wires for loose connections--- if the memory was wrong or something, it would still attempt to boot but stop during the POST and start to beep
Posted on Dec 23, 2010
Hp pavilion slimline power supply
you bringing a marginal part or connection back up a working state. when it cools or voltage drops it goes to the non working state. hp power supplies are not good to begin with. replacing it will fix it till that one also fails
May 23, 2017 | Computers & Internet
Hp pavilion d4996t
If a power surge didn't fry the mobo or PS, this can work: Unplug the tower from the 110 outlet, wait a couple of minutes, then plug it in again. Also try that with the power strip; unplug.. press its reset button, plug it back in.
Nov 16, 2013 | Computers & Internet
I try to turn my computer on but no luck, the little green light in the back is on, does that mean anything?
The green light indicates that the power supply is standby, if you press power botton and PC doesn't turn on, the simplest failure could be a defective power botton, also at the worst case you could have a defective power supply or motherboard.
Feb 18, 2011 | HP Hewlett Packard Pavilion Slimline...
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
