Question about Blanco Meridian Single Handle Single Hole Semi-Professional Spray Kitchen Faucet
Diverter valve problems
Is a faulty diverter valve the cause of the spray not working?
Only have hot water when heat is on
A stuck divert-er valve yes replace head, and know this will not cause leaks leaks,leaks are caused by o seals worn and getting old ..and olives on connections replace the above as needed some times a quick tighten with rench will do it leaks that is
Sep 28, 2013 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
Water pumps out instead of recirculating?
It's not your wires faulty.
Is the valve installed the right way.
When diverter valve is powered will pump water over bowl.
Your motor controller board may be faulty,
And need diverter driver parts replaced.
Set you machine to Traditional wash only to bypass
Eco active filling that users diverter valve.
Jul 08, 2013 | Fisher and Paykel GWL11 Top Load Washer
My f&p washer is leaking when it fills with water then stops an tells me code 51 all other cycles work fine how can i fix this
51.(00110011) Diverter Valve Fault
The motor controller has registered a drop in water level in the recirculation phase of the wash cycle. Water is being drained instead of recirculated.
Primary Source:
Action:
Diverter valve.
Remove the diverter valve and check for blockages as well as checking that the hinge mechanism on the valve hasn't broken. Remove the hinge from the solenoid and check that the flap is free to move. Check that water hasn't been sprayed onto the valve from an external source and caused the solenoid to blow.
Secondary Source: Motor Control Module.
Action: Turn the power off at the machine but leave the power on at the wall,
then measure the voltage across the terminals of the wax actuator. If a reading of 110/230V is achieved, the motor controller has failed due to a valve fault and both will need to be replaced.
Apr 21, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Drain valve orientation
You have got the valve in back to to front.
you would get fault code 51 soon having it like that.
Primary Source:
Action:
Diverter valve.
then measure the voltage across the terminals of the wax actuator. If a reading of 230V is achieved, the motor controller has failed due to a valve fault and both will need to be replaced.
Apr 16, 2013 | Fisher and Paykel IWL12 Top Load Washer
Error code 52
51. (00110011) Phase 5 ECO - Recirculation Fault
The product has detected that it is losing water during recirculation.
Primary Source - Diverter Valve Wiring
Action - Check diverter valve harness is correctly fastened to diverter valve. Check flying lead
in motor controller, and connection to valve next to drain pump.
Secondary Source - Diverter Valve
Action - Check diverter valve resistance. If open circuit (nominal is 1500 ohms) replace
diverter valve. During recirculation, check that water is being recirculated back into the bowl,
and that no water is coming out of drain hose. If there is some water coming from the drain
hose, then the diverter valve could be faulty, or it could be jammed with a foreign object.
Replace diverter valve.
Tertiary Source - Motor Controller
Action - The diverter valve drive circuit may be at fault. If the primary and secondary checks
pass inspection then replace the Motor Controller.
52. (00110100) Phase 5 ECO - Recirculation Fault
See fault code 51.
Apr 02, 2013 | Fisher and Paykel GWL11 Top Load Washer
Water is leaking around base of "spout" and
If you have properly replaced the diverter assembly, there is either a problem with valve or debris was left in the valve from old diverter when new diverter was installed. Disassemble diverter by pulling spout back off. remove new diverter and check valve. Cup your hand over faucet and turn cold water handle on to attempt to flush any debris left behind. Try several times then reassemble. If this doesn't do the trick then replace. Get a quality filtering system and take care of your new faucet by making sure it's dry and polished after use. You won't be replacing your fixtures as often from calcium and corrosion.
Apr 23, 2011 | American Standard 4271S 'The Standard...
Re Delta faucet 172-WHWF The spray assembly has a long delay in getting water to it. Would a new diverter valve fix that problem? If so, what is the part number for the diverter valve for this...
Before you start replacing parts look under the sink and make sure the hose leading to the remote spray is not kinked or starting to kink when pulled out.
Mar 07, 2011 | Delta Faucet Delta 172-WHWF Waterfall...
What does fault code 51 mean?
Error code 51 usually means a faulty diverter valve. Try and run a wash cycle, and observe the drain hose. If water comes out, the diverter valve should be fine, if no water comes out you should take your diverter valve out and check for debris, or continue to read through the following possibilities of why your washing machine is acting up, and the actions to take.
1. Diverter valve
Action - Check diverter valve continuity. If open circuit, replace diverter valve.
2. Motor Controller Board (drive circuitry blown).
Action - Replace Motor Controller Board
3. Diverter valve harness/connectors.
Action - Replace wiring harness
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
The faucet continues to run when using the side spray.
under the neck of the faucet is a small cone in the side of the body.this is your spray diverter,it may be clogged,it may be spring loaded or a presure valve you must remove and clean. then it will work right.
Jul 25, 2009 | Price Pfister Marielle Kitchen Faucet with...
Not cleaning on top rack. Pump, fill tube asm. & spray clean. Has any seen if this issue could be the deverter motor in the pump or the control board?
Just to review, the LG dishwasher family, including the LDS5811 has the Verio motor and the check valve that diverts water from the bottom rack to the top rack.
If the valve is blocked/jammed, this would cause the symptom you describe. The valve is visible from inside the DW after you open it up.
It is also possible that this motor has failed.
Apr 20, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Blanco Meridian Single Handle Single Hole Semi-Professional Spray Kitchen Faucet Logo
26 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
