SOURCE: how to connect jawbone bluetooth device to htc evo
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
SOURCE: My htc evo 4g keeps freezing on me
Re-install the firmware (http://androidforums.com/htc-hero-sprint/45596-how-reinstall-os.html) if that fails, there may be a hardware issue. If HTC doesn't help you, here's a guide on how to disassemble an HTC Evo. Maybe a tech savy friend can do it for you. If you want to pay to have a service do it for you there are third party HTC Repair Services.
SOURCE: how to connect sprint htc evo 4g on boost mobile
Sorry but you cannot connect it to boast mobile. That phone is a sprint exclusive phone.
I hope this helps. If you need more help just reply.
SOURCE: my HTC inspire 4G won't turn on or charge. the
Was going through this article. It might help:
http://community.htc.com/na/htc-forums/android/f/113/p/9281/40043.aspx
SOURCE: How can I flash my HTC Evo Shift 4G from Verizon
Either you have to flash the mobile or get a unlock code you have to
take it to the service center, because to flash and get unlock code (both) the
mobile has to be connected to the computer with a cable.
hope this
helps,thanks!
