Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Frigidaire side model frs20wnf
Ice and water dispenser button does not work,neither does the light,seems like no power to compartment but everything else is fine
roadbird383
  • 40 Answers
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Posted on Dec 05, 2007
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
SOURCE: Frigidaire model FRS6LE4FW0 water dispenser does not work.
I DONT GET WATER OR CUBES
Posted on Jan 11, 2009
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
My Frigidaire model FRS24ZGE leaks water from the bottom of the freezer door after using the water/ice dispenser. Any ideas on a fix?
Posted on Jul 18, 2009
SOURCE: FRIGIDAIRE SIDE BY SIDE ICE DISPENSER
Have same or similar problem. MY problem turns out to be that the Auger turns fine, but there is a little metal blade that attaches to the end of the auger and transfers the spin action into this auger "hopper" (for lack of a better term) which actually accepts the ice that has been moved from the back of the ice bucket by the metal auger and then dispenses the ice into the hopper which falls into the glass. the issue is one of crappy design. It turns out that this little blade has a rectangular opening in the middle that the rectangular end of the auger fits into. If this rectangle opening gets stripped (as mine has done, and ALL are likely to do) then the auger spins, the ice is moved forward but none are picked up by the hopper, and none (or very few) fall into the glass.
Everyone should check to see if this is the case. If so you may need to order a new blade, or a new auger, or a new refrigerator.
Good Luck!
Posted on Jun 10, 2010
What stop the compressor, water spilled on the freezer fan though the vent by the ice maker. help
Most likely the=> 5303918476 Defrost Control Board will need to be replaced. This board can be found inside the control panel inside the fresh food compartment. Unplug power and lets examine the board. Here is another source for the board 5303918476 Defrost Control Board Here is a photo of the inside of the control panel HERE and item location 23 is that board. I am here should you have questions, Sea Breeze
Soemtimes the defrost control board will show signs of failure with burn marks and heat damage but not always. It is likely this board is the problem and in some cases the start relay and run capacitor can cause these same symptons.
Jul 03, 2013 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire model PHSC239DSBO has no power to ice and water dispenser
I have the same problem. Also no power to the water valves or the connection at the top hinge of the freezer door. Also, nothing at the wire going to the freezer light switch. The switch is good as is the bulb. Everything else seem to be working ok. Wondering where to check next.
Mar 17, 2013 | Frigidaire PHSC239DSB Side by Side...
My 7-button Frigidaire Gallery ice/water module is not lighting up and not functioning. No ice or water is being dispensed. Wiring harnesses seem to be all intact.
Hi
If freezer door switch is not working, dispenser won't work. Does the freezer light go off & on when door is opened & closed? If you have a voltmeter, check that water valve is getting 120 volts when dispenser is pushed in. If no voltage, I would suspect the micro-switch that you hear clicking when you push in with a glass. Even though it clicks, the contacts could still be bad in it. However other than that loose/off wire, ribbon cable for front buttons off/loose, bad board, child lock are something that can make the dispenser dead.
Please check the bellow link if it helps:-
http://www.ehow.com/how_6494535_troubleshoot-frigidaire-icemaker.html
http://www.ehow.com/how_6557721_troubleshoot-frigidaire-refrigerator-icemakers.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 29, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Power to the ice maker/water dispenser seemed to have shut off. Ice maker is still making ice, but the dispenser is not working. Is there a fuse or something?
frigidare 36' side by side. makes ice, nothing comes out of the door dispenser, auger truns. prior to this it would only give crushed ice even if set on cubes
Dec 06, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Side by side refrig - ice maker and water don't work after replacing the filters. is there a re-set?
Removing a water filter from the inside of your Frigidaire brand refrigerator:
Removing and replacing a water filter - upper right hand corner inside location
Filters situated up front in the refrigerator compartment of Frigidaire-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Open the door of the refrigerator compartment of your Frigidaire brand side-by-side refrigerator. The filter is located in the upper right hand corner. It has a push button for quick release just to the right of the filter.
  2. Locate the icemaker On/Off power switch and place it in the OFF (o) position.
  3. Push in on the filter release button and pull the filter all the way out to remove it. Remove new filter from its packaging and remove the protective plastic caps. Insert the new filter in the same manner it was removed. Make sure to push in firmly on the filter until you hear the filter cartridge click in place.
  4. Return the icemaker's power switch to the On (l) position.
  5. Condition the filter by running water through the dispenser for about three minutes. This will flush the filter of all fine carbon particles.
  6. In some models, you will have to reset the filter status light. It is located on the ice and water dispenser control panel. Push in on it for ten to fifteen seconds until the green, red, and amber lights flash. If your refrigerator model does not have a filter status light, you should make a note on a calendar, or place a month sticker on your filter to remind you to replace the filter again in six month's time.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator or shut off the water supply when replacing it. Also, this filter should be replaced every six months.
Oct 31, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Frigidaire side by side FRS24ZSG. Door Dispenser doesn't work
click on the wiring diagram and look at the circuit which powers the dispenser...it looks like the safety switch would be a problem to all the functions you listed above..such as the light not working.. no ice... no water
i would look for power to that safety switch..and if its getting power.. then i would check continuity through that switch.
also another possibility maybe its the wiring harness that leads to the dispenser.
Oct 05, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
