Unable to install Adobe Reader in Ubuntu 13.04
When I tried to install and then remove Adobe Reader on Ubuntu 13.04 I got the following error report: (Reading database ... 226163 files and directories currently installed.) Unpacking acroread-bin (from .../acroread-bin_9.5.5-1raring1_i386.deb) ... dpkg: error processing /var/cache/apt/archives/acroread-bin_9.5.5-1raring1_i386.deb (--unpack): trying to overwrite '/opt/Adobe/Reader9/bin/acroread', which is also in package adobereader-enu 9.5.5 No apport report written because MaxReports is reached already dpkg-deb: error: subprocess paste was killed by signal (Broken pipe) Processing triggers for bamfdaemon ... Rebuilding /usr/share/applications/bamf-2.index... Processing triggers for desktop-file-utils ... Processing triggers for gnome-menus ... Processing triggers for man-db ... Errors were encountered while processing: /var/cache/apt/archives/acroread-bin_9.5.5-1raring1_i386.deb dpkg: dependency problems prevent configuration of acroread: acroread depends on acroread-bin; however: Package acroread-bin is not installed. dpkg: error processing acroread (--configure): dependency problems - leaving unconfigured I cannot install any other software. How do I solve this problem?
In trying to install various versions of Adobe Reader on Windows XP SP3, I get the following error message: "Installation encountered errors; failed to initialize." I get this message on...
Yo! I will have to direct you to a website where you can download anything for your computer.i advice you download another one from here. please follow the link below..
www.download.com
Jul 27, 2011 | Computers & Internet
Need an Adobe Reader up-date. My computer refuses to install it, giving me Error code 800B0100. I keep trying whenever their offer appears on screen, but no luck. Perhaps this is not a valid offer....
If you are unable to install the automatic update, you can download the latest version of Adobe Reader from: http://get.adobe.com/reader/
On the page which opens, click on the "Download Now" button to start the download process.
Then follow the download and installation instructions on the next page to complete the installation.
Hope this solves your problem. Thanks for using FixYa.
May 27, 2011 | Computers & Internet
Adobe reader wont work i get error 1402
file:///C:/Documents and Settings/ACER/My Documents/My Pictures/error 1.bmp
Aug 02, 2010 | Adobe Computers & Internet
I keep getting error 1612 when I try to update Adobe Reader
Hi, if you keep getting a "error code" from the Adobe Reader; do the following. First, click on the [Start Button], select to open the "Control Panel {shortcut}." In the next window, select the [Uninstall a Program ] applet, next scroll to find the "Adobe Reader" highlight it to "Uninstall." Next, follow the instructions to complete the removal of the program. Once the Adobe Reader, is removed "restart the computer." The next thing to do is "Reinstall the Adobe Reader," click on this site to get the "Download" of the New Software. Once the installation of Adobe is completed; "restart the computer again!" "Let me know if all went well by giving a "helpful rating, and thanks for using Fix'Ya. http://get.adobe.com/reader/
Jul 08, 2010 | Adobe Computers & Internet
Cant install adobe reader on my pc as error
You can read adobe reader new version and install that...If your OS is XP, it will support all adobe readeer....I think your download is not perfect.please try the above way...Hope you will succeed....
Nov 23, 2009 | Adobe Acrobat 7.0 for PC
Adobe Reader version 8
Try this fix,
1.dowload windows installer cleanup utility from the following link.
http://support.microsoft.com/kb/290301
Under more information, tab
2. Install and run the same from Start> All programs>windows installer cleanup utility.
3. In the box keep on selecting all items that say adobe and click remove. If you have multiple enteries might need to select them one by one.
4. Click on Start >My computer>Local Disk C:>Program files and delete the adobe folder
5. Restart your computer and again download and install adobe reader , it should work fine .
In case it still does not work and you need to open pdf files download
foxit reader from the following link
http://www.download.com/Foxit-PDF-Reader/3000-2079_4-10313206.html
Thanks
Mandeep
Jun 07, 2008 | Adobe Acrobat 7.0 for PC
Adobe installation
Hooray! Found the solution. Seems the problem is you must have the Adobe Reader 7.0.9 installer on your system to be able to install 8.1.1. You can d/l version 7.0.9 (which includes the installer) here:
http://www.adobe.com/products/acrobat/read...llversions.html
Install the whole thing, then you should be able to install your 8.1.1, which will remove the 7.0.9 version in the process, but will use its installer.
Oct 20, 2007 | Tiny Computers B1996 19" CRT Monitor
Computers & Internet Logo
119 people viewed this question
David Payne
David Payne
