Question about Scotts Company Scotts& Accugreeen 2000 Drop Spreader 3 Pack
What setting do I use on my spreader
Using Jirdon heat and drought stress fertilizer 8-12-10 4lbs.per 1000 sq. feet.
SOURCE: Model 300 runs out of fertilizer
Since I didn't have a manul, I downloaded one from Scott's and used that to calibrate the spreader which was out of calibration.
Posted on Apr 09, 2009
SOURCE: Please tell me how to set my Scotts Accugreen 2000
I emailed the nursery that sold me the two products that I wanted to apply: Luscious Lawn and Garden and Luscious Lawn Corn Gluten. The owner emailed right back, telling me to use the highest setting because these products have large particles. Anyway, they are organic products, and an overdose will not burn my grass. Thank you. Nancy Packard
Posted on Jul 09, 2009
  • 125 Answers
SOURCE: need to apply lawn fertilizer at a rate of 5 lbs,
http://www.gardentech.com/spreadersettings.asp
this is a link which will help you. Your setting should be on 7-8 using a criss-cross distribution pattern
Posted on Sep 07, 2009
Testimonial: "thanks pal, worked great"
SOURCE: need spreader settings for Scotts Speedy Green 3000
I found this:
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
Posted on Oct 24, 2010
  • 25 Answers
SOURCE: I need spreader setting to do 2.3 pounds per 1000
If the product you are planning on applying has a spreader setting for a Scotts SpeedyGreen, or specifically for the SpeedyGreen 3000; you can that recommendation in your Edgeguard Deluxe Spreader. If they do not have a suggested spreader setting for the SpeedyGreen, or SpeedyGreen 3000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
We do have a general rule, called the 50 by 20 rule which will allow you to use any product in any spreader, but there is some work that will need to be done.
* Weigh out and Place enough material in the hopper to cover 1,000 sq. ft. (In your case 2.3 pounds)
* Place the spreader setting on a low setting (Usually one-fourth of the spreader setting range or less. In your case i would suggest about 2.75 or 3)
* Spread the material over a 50 x 20 ft. area (This is 1,000 sq. ft.).
* If material is left over, you will need to increase the setting accordingly
* If they you up short, you will need to decrease the setting.
Posted on Feb 23, 2011
What is the spreader setting for 2.8 lbs per 1000 feet?
Hi Tom:
It will depend on the size of the particles being spread.
Usually the package that the material comes in will have a table showing the settings.
Some of the fertilizers that have oyster shell can obstruct the opening and prevent the gate from closing. Gotta watch that.
You could also google the make of your spreader for information.
Here's a link to sites for Scott Spreaders.
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=scott%20spreaders
Hope it helps
Cheers
Apr 26, 2016 | Garden
What setting do I use on a turf king drop spreader to cover 8,140 sq ft?
http://plantscience.psu.edu/research/centers/turf/extension/factsheets/calibrating-spreader
You have given the area you want to spread, but you also need the rate per square foot of the fertilizer. The link above tells you how to calibrate and check the rate of application.
Or you could ask Turf King direct.
http://www.turfking-lawn-care.ca/index.php?option=com_content&view=article&id=107&Itemid=328
Apr 09, 2016 | Garden
Best setting for fertilizer (2.6 lbs/1000 sq. ft.)
The info will be in the spreader setup handbook as the settings for each spreader are different
Mar 23, 2016 | Cars & Trucks
I have a scots edge guard spreader and need to put on weed and feed at 4 lbs per 1000 sq feet what setting on spreader should I use
Hi Mike:
The setting will depend on the size of the weed & Feed pellets.
The package usually has setting instructions on it.
If all else fails, the rate is 1 lb per 250 square feet.
Mark out an area about 10 ft by 25 ft long.
The spreader cast is about 5 ft, so down and back should use 1 lb.
Set the spreader at a minimal rate and see how far 1 lb goes, then adjust the setting accordingly.
May 22, 2015 | Scotts Garden
Ez republic broadcast setting for expert gardener St Augustine Weed and feed for southern lawns
The bag should have a phone number for customer support. They would be the ones to give you the conversion rate for your spreader. How many square feet are you treating?
www.naturewestinc.com
Mar 04, 2012 | Earthway Ev - N - Spred Model 2050p Estate...
I have lost my instructions for my hand held spreader. The numbers on the side that control the outlet of whatever is in the spreader--do these indicate the number of pounds per 100 sq. ft?
Below is a list of spreader settings. You may want to call Scotts at 800-543-8873 and verify the product you are using is able to be used in a hand held spreader.
  • For fine grass seed (blue, rye, fescue) use setting 1
  • For coarser seed (tall fescue) use setting 2
  • For light fertilizer (Scotts fertilizers at a regular rate) use setting 3
  • For heavy fertilizer (Scotts fertilizers at a heavy setting) use setting 4
  • For pelletized fertilizer and ice melt products use setting 5
Hilary @Scotts
May 16, 2011 | Scotts 71133 Handgreen II Hand Held...
Republic EZ broadcast spreader...what number to use when lining up the mark to calibrate the spreader...lost the instruction book
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Apr 02, 2011 | Garden
I have a speedy green 2000 broadcast spreader and need to know what setting I need to use to spread 40 lbs per 2000 sq ft dolomite peletized lime? Thanks.
first 40lbs per 2k of lime will do nothing, rate to chemnge ph 1 point is 50lbs per 500k which would be all the way open slow walk. for your application you should be about half to 3/4 open normal walk
Feb 06, 2011 | Scotts Company Garden
I have a Scotts Speedy Green 2000 rotary spreader and want to know the proper setting for your Milky Spore 20 lb. bag (granular carrier). I have been keeping it about 50% open (Setting # 9 to 9.5) but it...
I have the same question, but have not found a direct answer. I have calculated an estimate setting of 4 or 5 for the speedygreen 2000. The Milky Spore is very simular to the fertilizer that I use. Milky spore says that 1lb covers a little over 300 square feet. My fertilizer says that at a setting of 4 it is spreading 2.6 lb per 1000 square feet (almost 3 lb per 1000 sq ft or 1 lb per 333 sq ft).
Now I may be totally off, but just bought the Milky Spore today and will apply tomorrow. I may look some more tonight to see if I can find an answer. I felt it was kind of bad that the back of the Milky Spore suggested only using a drop spreader!?
Sep 06, 2010 | St Gabriel Laboratories Milky Spore Lawn...
Need to apply lawn fertilizer at a rate of 5 lbs, per 1000 sqare feet, what setting do i need on my scott's speedygreen 3000 broadcast spreader.
Sep 07, 2009 | Scotts Company Scotts& Accugreeen 2000...
Scotts Company Scotts& Accugreeen 2000 Drop Spreader  3 Pack Logo
115 people viewed this question
Top Scotts Company Garden Experts
john h
Nick Olsen
lnbn1975
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
