Pioneer sx-550 reciever
No sound, and blows fuses.
robotek
  • 1512 Answers
SOURCE: Pioneer model sx-315 shuts off
if you are hearing noises from inside the amp,then something is burning up. Your sense of smell may be a guide here too. I suggest taking the amp to a tech to repair it unless you have had some experience with repairing amps
Posted on Jan 30, 2008
  • 236 Answers
SOURCE: pioneer stereo reciever model
please give more info of your problem. on what source are you not having sound? in all sources like your tuner, auxilary, tape CD etc...?
Posted on Apr 25, 2008
SOURCE: Looking for replacement remote for Pioneer sx-205
The Pioneer SX-205 does not have remote control capabilities.
Posted on Nov 05, 2009
  • 336 Answers
SOURCE: Pioneer SX-2300 powers up, but no sound.
Does the output relay click about 5 sec. after powering on? If it does check if the tape2/tape monitor is on. Check speakers and wiring. Try headphones.
There aren't any fuses for the output.
If no relay then it probably needs output transistors and a few resistors.
Posted on Dec 17, 2009
  • 961 Answers
SOURCE: I would like to set
http://www.vinylengine.com/library/pioneer/pl-514.shtml
http://www.hifiengine.com/manuals/pioneer/sx-550.shtml
The upper link is for the turntable, the lower is for the receiver. they want you to create an account tu dowlnload so just create an account with them. In my expierience turntables had hook upeads out the back(wires connected) that would hook to phono in on receiver and speakers would hook to receiver via speaker wires(may not be included) by pos and neg. The speaker wire usually either has a rib or a line or writing on on leg so you can identify which wire you would want to be pos or neg.
Posted on Mar 10, 2011
Pioneer SX-315 Speaker Problem
The bump may have broken or disconnected speaker wires.
May 17, 2017 | Pioneer SX-315
Put to big of a fuse in my pioneer sx-203 and burt out a cucit
Using a higher voltage fuse is not a problem, but if the fuse you used amps are to high, that is a problem. Sounds like a resister burnt. You have a short somewhere in that particular circuit, which is what took out your original fuse. . .your fuse did it's job by blowing and saving the circuit. If you can get your hands on a schematic, you can trace the circuit and find the short.
Jul 12, 2012 | Pioneer SX-205 Receiver
When turn on it blows the fuse
There must be a diode that is faulty in the power supply section mainly on of the rectifying diodes.
If you look closely at your board you will see four diodes that just after the fuse and befroe the Big capaictor(filter cap.) One of these four diodes must be faulty as the fuse keeps blowing. the diodes are responsible of current limitation drawback. So there must be current flowing back to the fuse that makes it keep blowing.
Check and replace. Good luck
Thanks for using Fixya.
G.
Jun 27, 2011 | Pioneer SX-205 Receiver
I would like to set up my old Pioneer PL-514 turntable and my Pioneer SX-550 sterio reciever to listen to some old LPs. I seem to have lost the instructions and connection diagrams. Could you please...
Mar 10, 2011 | Pioneer Audio Players & Recorders
Blown Fuse / SX - 205 / Pioneer reciever
Check the area where the fuse was...it's usually marked on the board or next to the fuse holder. Check the size also, 2 types 5x20mm or 1/4x1 1/4 in. Usually slow blow.
Mar 30, 2010 | Pioneer SX-205 Receiver
Busted Fuse that continues to burn out on our Pioneer Stereo Reciever SX-1900. We have changed it (the one cylinder one) and swapped outlets but it still doesn't work.. Please help.
disconnect all speaker wires at the receiver and turn back on. If the fuse still blows, the receiver needs to be serviced. If it stays on, reconnect speakers one by one and power up to test. If you need further troubleshooting help, post a comment and I will help.
Nov 19, 2009 | Audio Players & Recorders
Speakers not playing correct on a Pioneer SX-550
It could be the speaker output or the amp input. If you have a headphone socket on the amp try headphones and hear if it's the same problem.
If it's the amp's power output then this can be repaired. It's a case of unsoldering the blown transistor or integrated amp chip and soldering in a new one. It's not hard but you need to find someone competent.
Apr 28, 2017 | Pioneer Audio Players & Recorders
Jan 30, 2008 | Pioneer SX-315
18 people viewed this question
 Grubhead
Grubhead
