Question about SanDisk Sansa e260 MP3 Player
Sansa 260 I cant get the player to down load more then 62 songs it bumps the others off. If I HOOK TO COMPUTER THE FILES APEAR TO BE THERE BUT CANT FIND THEM ON SANSA
    Problem Solver:
  • 10 Answers
Check how much memory you have left. if you don't have a lot, than you have to plug it into your computer and right click on the my computer sign and go to manage. next go to disk management on the left hand column. right click on the sansa icon and go to format. make sure that the file system is under FAT32.
Posted on Sep 05, 2007
SOURCE:
Everytime i plug the mp3 into my computer it freezes up or i cant delete any songs on it
Try this way
BE SURE NOT TO DELETE YOUR FIRWARE, ONLY THE SONGS,FILES,ETC.
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
BE CAREFUL and do not delete files needed to operate your MP3 player.
This is a FREE answer, Please rate me
Apr 13, 2011 | SanDisk Sansa e200 MP3 Player
I cant delete songs because all of the songs are not showing up. what do i do
Deleting Files,Pictures,Videos,Audio Books, etc. from MP3 Player
release, right click and then click on "Delete"
Now your mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Please rate me
Dec 05, 2010 | SanDisk Sansa m250 MP3 Player
Cant delete songs from sansa m240. tried the most common solutions.
Try this way...Deleting Files,Pictures,Videos,Audio
Please rate me
Aug 22, 2010 | SanDisk Sansa m240 MP3 Player
I cant erase items
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Be careful and do not delete files needed to operate your MP3 player. Good Luck, I hope this helps Please rate me, Thank You
Dec 15, 2009 | SanDisk Sansa e250 MP3 Player
Cant add songs after i made space
Have u checked if the songs u put in have extensions that are supported by the player............in ur case check if some of the songs are .rm or something and not .mp3...........only files with .mp3 extensions will be supported
Aug 28, 2008 | SanDisk Sansa e250 MP3 Player
E-260 freezes when computer is trying to read it in Rhapsody program
I read some of the other post and found that I needed to use Windows Media Player. I had the Rhapsody program on my computer as well. Once I downloaded Windows Media Player I was able to access the files and add and delete songs.
My husband is not a big fan of Media Player. Lets hope I haven't done anything that he will have to fix. :)
Good Luck.
Aug 10, 2008 | SanDisk Sansa e260 MP3 Player
I can't load no more than 60 songs
You have auto-sync enabled - disable it
Disable auto-sync in Windows Media Player - Microsoft's website explains it far better than I can
Open Windows Media Player WITH the mp3 player connected
Highlight Sync, click on the arrow to bring down drop-dow menu
Select Set Up Sync
Uncheck box that says "automatically sync files to device"
Jun 20, 2008 | SanDisk Sansa E280 MP3 Player
Cant remove songs
try opening it up in rhapsody or windows media player and delete the songs through there.:
  1. open either rhap or wmp
  2. the devices should be in a tab to the left (rhap) or on the top (wmp)
    1. for wmp, it might be in a tab in a tab
  3. click on the music "+"
  4. and from there delete the music
Apr 23, 2008 | SanDisk Sansa e250 MP3 Player
Cant load songs
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
How Do I take music off my mp3?
Princess, you can remove the songs by going to "my computer" then open the sansa drive and delete files you don't want. If this doesn't work format it by right clicking on the sansa icon and then pick Format. Good luck. Let me know if it helped (and please rate this). Best, D.
Mar 27, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
48 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
