Question about Kitchen Ranges
Regulating gas on Kenmore gas range 790.70402012
I bought a used kenmore gas range, not used much. I use propane and it was set up for natural gas. We swithed it over to lp, and closed the hoods on the coaxles but the flame is still too big. What else can we do to fix this?
catriver
  • 878 Answers
SOURCE: Kenmore Gas Range Oven not Working Properly
greg, sounds like your needle valve is not seated. Remove the bottom drawer. Look back to the base of the burner where the shutter air adjustment is. Right under there is the valve which should have a 1/2 inch or 7/16 nut. (I Forgot what size). Turn this nut clockwise until the flame is adjusted to the correct size, should be a nice blue flame. The nut maybe hard to turn because you are seating the needle. Catriver..post back
Posted on Dec 23, 2006
fridgetech
  • 473 Answers
SOURCE: kenmore 78618 gas range
Yes, the orifice will is in the center of each burner and will unscrew.  Make sure new orifices get installed in the correct burner or it won't work properly.  I think you will use a 6mm nut driver to unscrew the orifices.  Can use a ratchet and socket also.
Posted on Oct 11, 2007
  • 95 Answers
SOURCE: Kenmore gas stove. Oven burns big flame which soots
The manifold needs to be cleaned and adjusted could have rust etc in it Not a good thing to do yourself unless you know what you are doing
Posted on Jan 24, 2009
  • 2976 Answers
SOURCE: Natural gas to LP converters
Your Tappan dealer can help you with this. You have a good named unit so it shouldn't be a problem. You could also check with your gas company as to where to get the conversion parts.
Posted on Feb 05, 2009
SOURCE: LP gas conversion oven flame to big
I did all this and the flames are still huge inside the oven...
Posted on Nov 27, 2009
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
Convert maxitrol regulator#rv47cl natural to propane gas
Some gas ranges cannot be converted. If your model can be converted it normally requires flipping over the regulator diaphragm and also changing orifices for all burners, surface and oven. Most modern new appliances come with the LP orifices located on a card attached to the regulator.
Nov 18, 2013 | Kenmore 72132 / 72134 Gas Kitchen Range
Problem with Kenmore 970-334780 Gas Kitchen Range / propane gas /to natural gas
hello Lorraine,
Most gascookers heve the possibility to change from LPG to natural gas.
You need to change the injectors. The holes in the injectors for LPG are smaller that the ones for natural gas.
I send you a link of Ebay where you can see what you need to look for.
Sometimes the oven can give a problem when it is gas too.
Kind regards, Dik
14results for natural gas cooker nozzles
Nov 20, 2017 | Kenmore Kitchen Ranges
I have a Sears Kenmore Elite 790 hooked up to propane .. is it ok to have it hooked up to propane or is this over for natural gas only?
Kenmore Gas ranges can be used with Natural gas or Lp. They come from the factory set up for Natural gas so if you want to use Lp it needs to be converted by you or your gas company. There are several adjustments that have to be made and some ranges require orifices to be changed. Your installation manual tells how to convert it but if you're not sure about doing it you would be better off the call the gas man.
Aug 28, 2011 | Ovens
I have a kenmore gas stove 790-75711890. my oven ignitor was only glowing. so i thought not enough gas i removed pressure regulator and blow thur it then reassemble. still not liting. i bought new oven...
On the top of pressure regulater is a removalable piece that fits one way for nautral gas and the other way for propane i am wondering it was installed upside down afer ya reassambled it, accidenttly setting it to propane which defeintly will cause that
Aug 22, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Gas pressure is low and also oven not lighting
You problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 31, 2010 | Kenmore 72132 / 72134 Gas Kitchen Range
I just bought a newer "Kenmore" Gas range. my probem is it is set up for natural gas and i use LP gas. Well it came with the LP gas conversion kit. I followed the directions carefully and the range-top...
Remember this: Crank down and flip. You must tighten down all the top and the oven valve orifices and open all the hutters and flip the nut on the regulator. crank down and flip.
Jan 14, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Switched from natural gas to propane now oven flames up sides how do I fix? Model#362.75571691
Propane and natural gas are two different fuels and require adjustments to the appliances to which theye are connected. Typically, when converting to propane from natural gas, a pressure regulator and a change in gas jets are required. This is because propane has a different heating value (hotter) and behaves differently.
Also, propane doesn't burn as cleanly as natural gas so after you have made the hardware changes, if you start to smell something in the kitchen, you may need to crack a window slightly to provide for better venting.
Please be careful
Jan 01, 2010 | Kenmore Kitchen Ranges
Propane coversion of kenmore 790 gas range
Most gas stoves are shipped for natural gas .You need to check the orifice on each burner to see if they are for natural gas or propane.If you ordered propane the stove should have been shipped with the orifices.They may be in a bag with your stove documents.
tk46
Jul 13, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Nat gas to propane conversion
With the gas turned OFF, you will need to find the gas regulator on the range. It will located in the back of the oven along the bottom somewhere. It's usually a square shaped valve with a nut on top of it. The gas valve orifice is located under the nut. All you need to do is remove the nut, take the orifice out, flip the orifice over and re-install to convert from one type of gas to the other. It should be marked which side is LP (propane) and which side is for Natural Gas. LP will have a smaller orifice opening than Natural. You will want to make sure the orifice size you are using is facing UP, then screw the nut back on the regulator. You will also have to do this for all the surface burners (if you haven't done so already). You will know if you have the orifice turned the wrong way because the flames will be too high, the oven will get way too hot and there will be soot everywhere. Hope this helps you.
Aug 11, 2007 | Sears 61301 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
