Just had virgin media fitted.Put the TiVo box in a cupboard next to tv.Cannot operate controls with remote with door closed.Is there a magic eye I could place top of cupboard,please
SOURCE: virgin media tv remote control
what you have to do is ring virgin and ask then to send the code.
this code is done stight to your set top box
Posted on Feb 08, 2008
  • 138 Answers
SOURCE: virgin remote control code
Contact universal remote 919-573-7854
Posted on Aug 20, 2008
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Posted on Mar 13, 2009
  • 34 Answers
SOURCE: Polaroid TV remote control codes for Tivo
As I understand it, Polaroid TV's sometimes work with the Mitsubishi codes. You may give this a try. You may also e-mail Polaroid direct at www.polaroidelectronics.com contact page to find out what codes should be used (may match a different manufacturer)
Posted on Jun 02, 2009
SOURCE: commtel control freak 4in1 remote
have a 4 control freak uni remote lost booklet would like to down load one pls also have u code for remote media windows pc
Posted on Jan 21, 2010
The how to clear Configuration screen on Bush LTD TV, cannot get channels
Sounds like main system control memory IC fault. Contact any service technician to replace it.
Jul 14, 2016 | Bush Televison & Video
How to change volume on vm202 virgin media alcatel
Virgin Media Remote Control Codes
www.virginmedia.com/.../vplus-remote-control-codes.php
Virgin MediaYou can set-up your Virgin Remote Control to operate the Volume and Mute functions on your TV so you only need one remote to watch TV. Firstly, please select ...Missing: vm202 ‎alcatel
Customise your TiVo remote to control your TV - Virgin Media
www.virginmedia.com/tivoremotesetup/
Virgin MediaTo clear your changes and reset your remote to its original settings: Press and hold down and on the remote at the same time until the light on the top of the remote flashes green twice. Press three times, then press. The LED will flash green four times and exit programming mode.Missing: vm202 ‎alcatel
Virgin Media VM202 review by 3G.co.uk
Dec 27, 2015 | Alcatel Cell Phones
I need a code for my Hitachi 50HYT62U tv for virgin tivo remote
2610,2663,2681. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 28, 2014 | Hitachi Televison & Video
Sky Magic Eye not working over SLX 8 way booster/spliter
have you got it set on second out put on the sky box as number one is just normal. all cables have to be set to second output using a splitter box . so its like this.
arial in booster.
out booster to sky box.
out to tv/etc on first output on sky box.
second out put to spliter linc. ( eg 4 rooms out four way splitter)
each room with sky eye fitted to end of the aerial from number feed from sky box.
with each room with Eye sky can be controlled
also check that RF outlet power supply is set on sky+ or HD in settings menu.
access this.
settings
select ( remote)
type 01 (select on remote)
RF outlets.
RF outlet Power Supply ON
RF channel 25 ( is best for most areas)
Feb 01, 2014 | Televison & Video
How do I record off my Virginmedia Tivo box
You need to connect the cable signal into the TiVo, activate the TiVo with Virgin Media and then you can record using the record button on your TiVo peanut-shaped remote control.
Aug 30, 2013 | Televison & Video
Virgin tvvo box
Not sure about about the transmitter but the magic eye thing is possible however you wouldn't be able to change channel unless your pointing your remote at your box because a sky box has power going through the magic eye but a virgin box doesn't
Jun 06, 2013 | Televison & Video
Why wont my pillow remote work on my virgin tivo box?
Oh boy. here is the problem. i have also a 106240 IR/UHF receiver/transmitter that changes the channels in the satellite box from another room so i can watch them in a second tv at channel 4. the original remote for the 106240 is broken and i bought another UHF remote #153638. So i need to program the new remote to work and link with the 106240 receiver, NOT the satellite box or the tv. Is there any expert here to enlighten us how can be done ? Very simple question :how to program the remote 153638 to link with the 106240. Thank you in advance
Dec 22, 2012 | Tivo Televison & Video
My Virgin Media Tivo Remote is not working with my Easy Touch 42 inch TV, I have not been able to find the Code on the Database, can anyone help ?
Since you haven't mentioned the EXACT model of your remote, I can't exactly tell you the instructions. BUT you may choose your EXACT remote and refer to the instruction / codes from this link:
Virgin Media Remotes
I hope this helped you.
You can rate my answer if you appreciate my help.
Thanks!
-damneddle
Oct 14, 2011 | Tivo Series 2 Remote Control
Using a magic eye with an onkyo av reciever
Logitech's Harmony 900 is an RF remote that works through doors or walls. I think that it may be what you are looking for.
May 20, 2010 | Onkyo TX-SR607 Receiver
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
