Question about Dryers
Harbor breeze ceiling fan relay switch
Wiring sckematic
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
SOURCE: installation of wall remote for harbor breeze ceiling fans
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
Posted on Nov 25, 2008
  • 10 Answers
SOURCE: Remote fans quit working during a thunderstorm-lots of lightning
I've been having the same problem with my remote not working. I actually just checked the dipswitches in the remote against the ones in the ceiling fan, and they somehow were not the same. It seems that the 4th dipswitch may have inadvertently been altered due to the battery either being changed or just moving. I advise you all check out the settings on the actual fan to see whether or not they match up.
Twist the cap covering the wiring above the fan (make sure the power is off, just in case), and you will see a black box like thing straddled towards the top. There is a little rubber square cap guarding the dipswitches. Take that off and note the setting of the 4 switches (on/off). Compare it with the remote by taking the batter pack off and looking at the 4 switches there.
I noticed that the 4th switch on my remote was turned on when it should have been off. I changed it back, and now it works.
Hopefully this helps you all.
Posted on Jun 15, 2009
kingbrizzle
  • 407 Answers
SOURCE: I need to find a light kit for a harbor breeze
You should be able to pick these up at Lowes if I'm not mistaken. I just bought a Harbor Breeze ceiling fan from there and saw the light kits around the same area. I also believe that, you dont necessarily have to get a Harbor Breeze light kit and that some are interchangeable.Hope this helps some.
Posted on Dec 31, 2009
walesarumi
  • 6993 Answers
SOURCE: Installed new ceiling fan with
the spark was as a result to a bridge. Positive and negative wire has touched each other, that's why the circuit breaker tripped off.
Before you turn the circuit breaker back on, make sure you disassemble the fan, to avoid another spark.
Check the area that sparked, it must have turned to black, or has a burnt odor. Make sure that wires and metal in the box and fan are distinct/separated from each other. After that, switch it on again.
Good luck.
Posted on Oct 30, 2010
Need sckematic for realistic sta-820
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given.
Jun 09, 2016 | Audio Players & Recorders
I broke a shade on my harbor breeze lighthouse II ceiling fan, will you find the model number so I can order one?
Wrong way round, YOU tell us the model number and type and we tell you where to get the shade. You can see the fan in your house, but we can't. That makes it really difficult for us. Some shades are plain, some are fluted, some have patterns.
All is not lost though. Go here and take your pick. They all sell them including Harbour Breeze themselves..
  1. The Home Depot® - homedepot.ca‎
    Adwww.homedepot.ca/fans This ad is based on your:
    • current search terms
    • recent searches on Google
    Visit Google's Why This Ad page to learn more or opt out.
    Discover Canada's Online Source for Ceiling Fans & Lights. Shop Today!
.spell{font-size:18px}.spell_orig{font-size:15px}#mss p{margin:0;padding-top:5px}
Search Results
    Shop Ceiling Fan Parts & Accessories at Lowes.com
    www.lowes.com/Lighting-Ceiling-Fans/Ceiling-Fan-Parts.../_/N.../pl Harbor Breeze 2-Light Bronze Ceiling Fan Light Kit with Frosted ... Harbor Breeze Opal Round Frosted Glass ShadeHarbor Breeze Opal Round Frosted Glass ... Missing: lighthouse
    Shop Ceiling Fan Light Kits at Lowes.com
    www.lowes.com/...Ceiling-Fans/Ceiling-Fan.../Ceiling-Fan-Light.../pl Harbor Breeze 2-Light Bronze Ceiling Fan Light Kit with Frosted .... Harbor Breeze 4-Light Antique Brass Ceiling Fan Light Kit with Shade Not Included Glass or ... Missing: lighthouse
    Shop Ceiling Fan Globes & Shades at Lowes.com
    www.lowes.com/...Ceiling-Fans/Ceiling-Fan.../Ceiling-Fan-Globes-Shade... Shop a variety of quality Ceiling Fan Globes & Shades and Ceiling Fan Globes & Shades that are available for ... Sea Gull Lighting (2) ... Harbor Breeze Opal Round Frosted Glass ShadeHarbor Breeze Opal Round Frosted Glass Shade. Missing: lighthouse
    Amazon.com: Harbor Breeze - Ceiling Fan Light Kits ...
    www.amazon.com > ... > Ceiling Fan Light Kits Lighting & Ceiling Fans All Home Improvement Best Sellers Lamps & Shades Ceiling Lights ... Harbor Breeze Springfield II 52-in Antique Bronze Downrod or Flush Mount Ceiling ... Harbor Breeze 52-in Springfield Brushed Nickel Ceiling Fan with Light Kit ... Harbor Breeze Outdoor/indoor Lighthouse Kit Weathered Copper.
    harbor breeze light kit parts - Harbor Breeze Shop
    harborbreezeshop.com/tag/harbor-breeze-light-kit-parts/ Jul 25, 2012 - You can also have the option of choosing different lamp shades, or if in case ... The 52? Harbor Breeze Avian ceiling fan with a built-in light kit from .... has a style inspired by the clean, strong lines of a welcoming lighthouse.
Feb 01, 2016 | Dryers
How to change bulb on a harbor breeze ceiling fan. Model LGF-1
Harbor Breeze website is pretty sketchy, however...
Q - What is the Lowe's Customer Service phone number for Harbor Breeze Ceiling Fan questions?
A - 1.800.555.1212
Can't be that difficult, screw that ring, pull that ring downwards or look above it for three screws.
Oct 24, 2015 | Dryers
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
Harbor breeze ceiling fan w/lights&remote
Did the fan have a remote when it was purchased? If so, you already have a receiver in the fan somewhere. You'll have to find it to see if you can set the new transmitter to the same frequency.
Jul 23, 2013 | Dryers
Color code wiring for radio
1996 Chevrolet Suburban Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange
Radio Ignition Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Oct 11, 2012 | 1996 Chevrolet Suburban
How do i correctly install the radio in a 2000 kia sephia
Here are the radio connector wiring colors and what they do.
2000 Kia Sephia Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/Red
Car Radio Ignition Switched 12V+ Wire: Blue/Black
Car Radio Ground Wire: Black
Car Stereo Illumination Wire: Red/Black
Left Front Speaker Wire (+): Black/Yellow
Left Front Speaker Wire (-): Blue/Orange
Right Front Speaker Wire (+): Blue/Green
Right Front Speaker Wire (-): Light Green
Left Rear Speaker Wire (+): Green/Red
Left Rear Speaker Wire (-): Green/Black
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Red/Blue
Jun 28, 2012 | 2000 Kia Sephia
Wiring diagram for harbor breeze celing fan
The colors of the wires in the Harbor Breeze ceiling fan kits tell you what their functions are. The black wire is hot for the fan, the white is a common wire for both the fan and the light kit, green is ground and blue is hot for the light kit. locate the black and blue wires from the ceiling fan and connect them to the black wire inside the electrical junction box by twisting an orange wire connector onto all three wires. Locate the white wire from the ceiling fan and the white wire from the junction box and attach the two wires together with a wire connector. Connect the bare copper wire onto the green wire from the ceiling fan mounting bracket by twisting an orange wire connector onto the two wires. Push all wiring inside the electrical box. good-day !
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
53 people viewed this question
Top Dryers Experts
