Ipod model a318 battery - Audio Players & Recorders
Where is the input and output speed sensors for a1991 Dodge ram d-150 with a318 engine
On the outside of the transmission case
Google a picture
Don't throw parts at the unknown, based on
the name of some obd codes
Aug 16, 2014 | Cars & Trucks
Ipod model a318 to PC
download Winamp. it does this for iPod gen4 and older, it is free.
Nov 20, 2013 | Computers & Internet
Ipod wont turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch. Press any button to turn on iPod. Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information. Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost. Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it. Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod. b>
Apr 16, 2013 | Apple iPod touch
How do you get into the battery on my apple ipod model A1320
You can DIY. This WEB site gives instruction for replacing the battery.
http://www.everymac.com/systems/apple/ipod/ipod-troubleshooting-repair-faq/ipod-nano-how-to-replace-battery-instructions.html
Mar 24, 2012 | Audio Players & Recorders
I need a pic of the firing order for a one ton dodge 1977 van with a318
Try going to www.autozone.com . They have free online repair guides. You will have to set up an account but it is free.
Sep 04, 2010 | Dodge Cargo Cars & Trucks
Forgot password for ipod touch a318
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
Please rate me
Aug 29, 2010 | Audio Players & Recorders
My ipod wont seem to hold a charge
What generation iPod? iPod batteries, like all other lithium ion batteries, will go bad after they have reached their maximum charge cycle limit. If this is an older model iPod, the battery most likely needs replaced. Roughly 50 dollars for most models.
Jan 06, 2010 | Apple iPod nano
On incoming calls all it does is vibrate
social.microsoft.com/.../8306e39b-6e42-4db0-a318-36fd49d59601
Jun 23, 2009 | Motorola Mobility MoroKRZR K1m Cellular...
A1136 model battery problem
Hi! Don't open the ipod as you won't be able to figure out weather the battery is working or not. iPod's battery life is around 2yrs. Get it replaced if it is in warranty period or if you have extended warranty.
Dec 29, 2008 | Apple iPod MA446LL/A MP3 Player
63 people viewed this question
 Grubhead
Grubhead
