Question about Video Game Consoles & Games
2002 jaguar xk8 convertible passenger door light stays on even tho the door is closed?
Passenger door closes but the light on the dash indicates the door did not close
SOURCE: 2002 Jahuar xk8 -convertible- Driver's
If you disconnect the battery you must reprogram both windows by holding the button down until you hear it chime takes about 5 or so seconds. Repeat for the other window and this should solve the problem. This information should be in your owners manual, it is in mine
Posted on Oct 09, 2008
dgjtex
  • 405 Answers
SOURCE: Ford taurus door ajar light stays on
have you had the door panel apart before for anything, the switch is on your latch inside your door. I hope this helps you. I am just trying to be helpful, and will help you all the way through your repair if you like, My compensation is my rating. please be generous..lol
Posted on Dec 19, 2008
ipodfreek
  • 64 Answers
SOURCE: 2002 taurus passenger door lock
Mine did this. I went around to each door and sprayed a liberal amount of WD-40 in the latch, then open and closed each door about five times. It hasn't done it since. I think the switch inside was not moving freely.
Posted on Jan 16, 2009
SOURCE: Jaguar XK8 Window Problem
Same thing has happened on mine!
The solution is to reprogram the window limits. You need to sit in the car with doors shut! Turn the key in ignition in position I or II, roll down the window all the way and keep holding the switch for 5 seconds, then roll the window up and again keep the switch pressed for 5 seconds, repeat same steps for other door.
Reprogramming is also described in the owners manual. I don't know how mine became deprogrammed, should only happen if the battery is disconnected!
Posted on Mar 29, 2009
  • 52 Answers
SOURCE: my convertible top will not close lock and slow to come up
This is a VERY common problem with these xk convertibles. The most common is the fluid thickens up and the motor has trouble moving the top up and down. What you have to do is perform a convertible fluid flush, which is a pretty difficult task. Jaguar has updated fluid for this flush but it cost like 90 buck a quart, luckily you only need one but its pretty labor intensive. If your look at a dealership to perform this repair is pretty expensive.
Posted on May 10, 2009
Where on the 1997 Jaguar XK8 convertible is the cabin air filter located?
It is located under the panel in front of windscreen
Jun 25, 2014 | 1997 Jaguar XK8
The central locking on my 1999 Jaguar XK8 has stopped working. The fob does not work to lock/unlock the doors but does unlock the boot and turn on the lights. The drivers door can only be locked/unlocked...
sounds like one of the switches has failed on the drivers door latch that means a new latch unit is needed or it may be the drivers door module has failed more than likely the latch
Jul 22, 2017 | Jaguar X-Type Cars & Trucks
DOOR PUDDLE LIGHTS WILL NOT COME ON WHEN DOORS ARE OPENED 2002 JAGUAR X- TYPE
DO THE DOME AND UNDER DASH LIGHTS COME ON? IF THEY DO CHECK THE SOCKETS AND THE BULBS, THE DOOR BEING CLOSED OVER THE YEARS TAKES ITS TOLL.
Oct 30, 2012 | 2002 Jaguar X-Type
We have just bought a 2007 jaguar xk convertable and have noticed rust on the inside of the passenger door and by the boot lid badge is this aknown problem?
this could most likely be caused by a faulty seal, this can happen to even the most expensive cars, and even more common if the vehicle is driven in high humdity areas. hope this helps.
Sep 30, 2009 | 1998 Jaguar XK8
X5 - Overhead light not turning off and all doors are closed.
Check and adjust or clean the switch on the back passenger door.
May 26, 2009 | 2002 BMW 5 Series
My convertible top will not close lock and slow to come up
Apr 20, 2009 | 1998 Jaguar XK8
Dec 30, 2008 | 2002 Ford Taurus
Disconected battery in closed trunk, only electronic opening switch
The key hole is located in the middle of the rear XK8 badge on the right rear.
Sep 14, 2008 | 1998 Jaguar XK8
2002 Jahuar xk8 -convertible- Driver's window does not retract back to close position after door closes
Jul 20, 2008 | 1999 Jaguar XK8
Video Game Consoles & Games Logo
310 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
