Question about Craftsman Garden
Craftsman Trimmer anti-afterfire solenoid
What powers the anti-afterfire solenoid on a Craftsman trimmer (316.711200)using a Walbro (WT 1029)carburetor?
slohry
  • 87 Answers
SOURCE: need parts for craftsman edger/trimmer 275.796432
Here's a link to sears parts website
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 10, 2009
SOURCE: have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
Posted on May 10, 2009
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
  • 52 Answers
SOURCE: String trimmer, fuel lines disintegrated, I need routing.
The Walbro has two connections on it for the fuel line. My Walbro has one connection on the side of the idle screw and main fuel adjusting screw. This connection hooks up to the suction side of the primer bulb. Usually the shorter stem. (You actually **** fuel through the carb instead of pushing it through.) On the other side of the carb is the other hook up. It draws fuel from the tank. This line will connect to the side of the tank that has the filter. The other side of the tank is your return and it hooks to the other connection on the primer bulb. Usually the longer stem.
Posted on Apr 19, 2010
panilling9
  • 284 Answers
SOURCE: Which fuel line "port/inlet" on the Walbro wt-380
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Posted on Jun 25, 2010
Cant find walbro wa219b carb rebuid kit
Hi stamile3
Try www.jackssmallengines.com, they will have your parts and you can contact them by phone if you want.
Bud
Apr 11, 2013 | Craftsman 25cc Gas Line Trimmer
Need a diagram for fuel line placement on Stihl FS36 line trimmer
Hi Lee Miller
Hope this is what you need
Please take time to rate me
Bud
Oct 18, 2012 | Stihl Walbro Wt-160b Carburater For An...
Hi, I have a craftsman 25cc weed wreck. always starts in first time(cold) then couldn't start second time; If starts in first time, after 2-3 minutes (engine warms up) engine automatic stops.
the warmth to the carburetor will cause dirt to expand inside causing this to happen. Usually after 2 to 3 years these caburetors are no longer good to use. A new one will be better to have to run your trimmer
Walbro makes these caburetors and nobody likes to service them for their size is small and the cost is far cheaper to replace than fix
Jul 07, 2011 | Craftsman 25cc Gas Line Trimmer
Which fuel line "port/inlet" on the Walbro wt-380 goes to the fuel tank? It's on a Craftsman 25cc Gas "Weed Wacker" Line Trimmer purchased in 2002. It has Walbro WT-380 carburetor with external primer...
Jun 25, 2010 | Craftsman 25cc Gas Line Trimmer
Apr 17, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Walbro WA219b carb
Go to www.searspartsdirect.com and with your model number you should be able to find explode parts views of that trimmer. Filtered line to primer, primer to straight inlet on carb, angled outlet on carb back to tank. That might work. Not sure without part number.
Aug 02, 2009 | Craftsman 25cc Gas Line Trimmer
Parts number
You need to know if it is a walbro or a zama carb. to start with.
then look closely at the carb. and find #`s
very small
walbro will be wt or wa then some #`s
zama will be c1q or c1u and some #`s on the opposite side of carb.
Walbro will be on the same side
you need to know the carb. #`s so a kit can be found for that particular carb. IE: complete kit or diaphram kit
May 20, 2009 | Homelite Consumer Products MightyLite...
Garden Logo
185 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
