Panasonic inverter r410a error code 36 - Heating & Cooling
3 Suggested Answers
  • 25 Answers
SOURCE: I have a panasonic r410a inverter and I can not
The remote most likely takes batteries. If this remote has a cover that slides down to access buttons underneath, try popping that cover off.
Posted on Dec 06, 2009
SOURCE: My Ac wont turn on
use the remote to retrieve error code,on the bottom of the remote you will see a CHECK bottom,use a pointed pin to press it for 5 seconds the display of the remote will change to two underscore, then scroll the arrow beside the time,r press until you hear beep sound, then jot down the error code..there's a error code you will see inside the panel of the indoor unit,for quitting press again for 5 seconds the Check bottom
Posted on Aug 31, 2010
My panasonic inverter 410a has remote control problem. we already change indoor unit pcb . but doesn't work.so what to do?
SERVICE MANUAL Inverter Split system Air - Thermospace ...
www.thermospace.com/shinco/Inverter_Service_Manual.PDF Panasonic(rotary type. DC INVERTER). Refrigerant. R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). Cooling. Capacity.
Jul 12, 2015 | Panasonic Heating & Cooling
How much r410a need for goodman air conditioners
data plate on side of outside unit gives you the amount. 410a is a blend & you have to charge with a inverted bottle.
Jun 14, 2014 | Goodman Heating & Cooling
Hi, I want to know the meaning of the error code of an air conditioner panasonic s91 inverter.Grazie
Grazie, your question is rather confusing, because you listed to different model numbers for to different types of appliances. The "panasonic s91 inverter" is a cooking appliance. Whereas, the CW-X-C243HU is an air conditioner. So, which appliance are you inquiring about? And you didn't even say what the Error Code is.
Perhaps you can be bit more specific.
Jul 13, 2011 | Panasonic CW-XC243HU Air Conditioner
My Ac wont turn on becauser the timer light is blinking Panasonic inverter R410A
Aug 22, 2010 | Panasonic CW-1006FU Air Conditioner
I have a panasonic r410a inverter and I can not get the remote to work at all, i dont see where any batteries could go? any ideas?
Dec 06, 2009 | Heating & Cooling
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
Error Code E03-36
pull out toner bottle from machine
shake it well
reinstall it
power off then on
code will bi reset
May 01, 2009 | Panasonic DP-C322 Copier
Error code H-98
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Dec 01, 2008 | Panasonic NN-P794SF Microwave Oven
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
