Question about Dryers
Dryer timer not Advancing
The timer will not advance on my dryer I have already replaced the Timer, Cycling Thermostat, Thermal fuse, High Limit Thermostat and the Thermal Cut-Off Fuse. The wiring at the wiring block is goo and there is the correct voltage to the dryer. The door switch is good and the start button is functioning. The dryer works on all cycles, heats, etc.
    Problem Solver:
  • 18 Answers
Does it get almost to off but doestn go off or does it not move at all?
Posted on Jul 14, 2013
  • tdwjdwbcw Jul 14, 2013
    No, it does not move at all.
  • 56 Answers
SOURCE: wiring
You are missing over $150 in parts. You can buy a working unit out of the newspaper for that or less.
All of the wires on those models have letters and numbers on them near the connectors at each end.
Go to the Sears Parts Direct website with your Model Number and you may be able to print out a wiring diagram, because that is what you will need.
Posted on Jul 13, 2009
aasc
  • 1606 Answers
SOURCE: LER8648LW0 Dryer. Not heating, runs continuously
One side of the element powers from the timer and the other side from the motor . Remove one wire from the element , and check which wire is not getting 120 V . Trace the wire NOT getting 120V and it will lead either to the timer or the motor , providing that the small t-stat looking piece (thermal cut-off) located close to the top of the heater box , shows continuity . If it does not , then pt # 3392519 is for it and the hi-limit t-stat . If you replace it , then replace both that come in the kit .
Posted on Jul 19, 2009
  • 523 Answers
SOURCE: Kenmore Dryer - No Heat
110 comes from the motor 110 comes from the timer remove the wire that comes from the motor see if you have 110 if you do the timer is bad if not the motor is. even if the motor is turning its bad
Posted on Jun 08, 2010
heatman101
  • 43501 Answers
SOURCE: My electric whirlpool dryer IS heating but not
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Apr 20, 2011
MY REPAIRMAN
  • 61 Answers
SOURCE: have a roper dryer model red444ovq1 that will not start. have checked door switch element,thermofuse,cycling thermostat high limit fuse the 249 volt circuit and every thing else that would normally ca
BE SHUR TO CK FOR 240 VOLT UNDER A LOUD PUT YOUR LEED ON LINE 1 AND LIND 2 AND PUSH STAR TO SEE IF THE 240 STAY. IF YES THEN YOU CK THE FUSE FOR CONTENUTRY AFTHER TAKING 1 WIRE OFF IF YES CK TO SEE IF YOU GET 120 VOLT TO THE MOTOR ON WAITE WIRE AND BLK OR BLUE IF YES THE MOTOR IS OUT IF NOT THE CK TIMER .
Posted on Feb 22, 2012
Testimonial: "thanks ver much. "
When I set the timer it doesn't move therefore the dryer never shuts off do I need to replace the timer, cycling thermostat, or the thermal fuse
IF THE TIMER IS NOT ADVANCING THE POINTS INSIDE MAY HAVE SEIZED AND ARE STICKING THUS NO ADVANCING? THE FUSES WILL NOT EFFECT THE ADVANCING OR STICKING ON 1 CYCLE? IF U HAVE A DIGITAL CONTROL BOARD TYPE, THEN U HAVE A WHOLE DIFF BALL PARK AND THE BOARD MAY BE BAD?
Feb 27, 2015 | Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
I recently installed a thermal cut off and high limit thermostat on a whirlpool ler5636kq1 dryer. It was the kit that you had to cut and crimp the wires to the thermostat and I followed some step by step...
I have the exact same problem. Would not heat so I replaced the thermal cut off and high limit thermostat . Now the timer won't work properly. Did you find a solution?
Feb 05, 2011 | Whirlpool LER5636P Electric Dryer
My kenmore dryer is blowing only cold air. What is wroge? We already checked the heating element and timer...???? This dryer is only 4 years old.
The heating circuit is composed not only by the heating element and the timer but also with a high-limit thermostat, a thermal cut-off, and a cycling thermostat. The high-limit thermostat and the thermal cut-off are both mounted on the heater housing to monitor and regulate the heater temperature while the cycling thermostat is mounted on the blower housing to monitor and regulate the temperature of the exhaust air.
All of these components are wired in series and a failure in any of them results in the dryer not heating. The proper troubleshooting is by checking the continuity of each of these components with a volt-ohmmeter and replacing the ones found without continuity (open).
A continuity check can also be done by bypassing each of the three components, never the heating element, and then starting the dryer. The dryer should heat, otherwise the problem is somewhere in the timer, the heating element, or the centrifugal switch within the motor. When the dryer heats up, unplug it then un-bypass one of the bypassed components and start the dryer. If the dryer stops heating then you have found the failed component; replace it. If the dryer does not stop heating, do the same to the remaining components until you find the failed one. Just make sure the dryer is unplugged before touching the components.
Replace both the high-limit thermostat and the thermal cut-off if any of them has failed. Indicate the exact model number of the dryer if you need further or more specific advice.
Jun 12, 2010 | Kenmore 63942 Dryer
The timer on my Kenmore dryer is not advancing. The dryer turns on but is not heating and it is not advancing so it stays on. What it wrong?
In the automatic cycle the timer will not advance if the dryer does not heat.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Unplug unit and turn off gas if gas model. Check to be sure you have 240 Volts at wall outlet.
Most parts likely to fail in electric dryers are inside the rear cover. Heater is on right inside can, safety thermostat on lower left of can, High limit thermostat (non-resettable) higher left of can. On the blower housing to the left are the operating thermostat and a thermal fuse (white plastic). ALL can be continuity checked easily. Always disconnect wire on one side of what you are testing. One will likely be open
. Replace it.
Aug 30, 2009 | Dryers
LER8648LW0 Dryer. Not heating, runs continuously (stops w/ door opened). Timer not advancing. Checked fuse(0 ohms), thermostats (0 ohms) and coil (10 ohms). Timer was at 10-11 K ohms,(high end). So...
Jul 16, 2009 | Whirlpool LER8648L Electric Dryer
Dryer will not heat
the limit switches are known to go bad on dryers
Feb 13, 2009 | Crosley CDE6000 Electric Dryer
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
71 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
