Question about Dishwashers
Bosch sms 5012 dishwasher
Heating element seems to have overheated, melted some plastic parts. hi-temp thermostat tests OK, heating element also tests OK. what could be the problem?
SOURCE: Zanussi DE540X Dishwasher
I have the same problem. First fault was caused by poor workmanship on the assembly of the PCB. There is a relay (the largest component on the board) which was badly soldered and caused some arcing resulting in solder splattered around the plastic casing and a lost electrical connection. This relay switches the mains voltage on to the heater i.e. 240V around 8.5A for a 2kW heater. (26 ohms suggests a 2215W heater for the case mentioned). Re-soldering this connection solved the problem for about a year. Now the dishwasher is showing the same problem. I have tested the relay and it is operational, but does not seem to be turning on during a wash cycle. A new board costs around £100. Zanussi will not even provide the technical details to allow a home fix. I will post my finding if I get to the bottom of this problem. It may be to do with electrical temperature sensor. My hunch is the controlling PCB is cheaply made and will not last a reasonable lifetime. A dishwasher is in itself a very simple piece of equipment with only a few valves, a pump and a heater so should not give problems in its first five years of life subject to normal usage. I will not consider purchasing any Zanussi appliances in the future.
Posted on Jun 20, 2007
  • 213 Answers
SOURCE: test bosch heating element
remove the kick plate at bottom of dishwasher, at the left leg there will be a wiring diagram. remove console and test element from there. diagram will show which wires to test
Posted on Nov 20, 2007
THENTHEREWER
  • 131 Answers
SOURCE: ge pdw7880j10ss dishwasher lower roller
(http://www.geappliances.com/service_and_support/parts/)
the correct # for your unit is pdw7880n10ss
just enter your model #(under repair or replacment parts)the site will walk you thru the rest.when you get to the parts list make sure you use the diagram to match your part exactly(click the red box at top of page)hope this helps.thanx for using fix-ya!!!
Posted on Nov 29, 2008
SOURCE: plastic melted on Dishwasher heating element
you can also use blow dryer to heat up plastic
Posted on Feb 04, 2009
SOURCE: dishwasher element and thermostat
Did anyone get this sorted, mines doing the same. It stops at position 12, no power at the heater, so it stalls. I have replaced the dual thermostats, and the heater element is returning 25ohms resistance.
Its doing my head in!
Posted on Dec 04, 2009
Bosch dishwasher sms 4012 stuck in the wash cycle and goes on for hours without moving forward
Check the temp of the water in the machine. It could be too low and the machine is trying to heat it and cannot. If that is the case, it is either a sensor or the heating element.
Aug 11, 2013 | Dishwashers
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
I have read about problems with the cycle not advancing or getting stuck on an SHU303 Bosh dishwasher. I have this problem intermittently. Usually when the dial is at the 6pm position, and lately during...
Hello Brien, First let me start by apologizing for the difficulty you've had here at FixYa. It is unfortunate the assistance (or lack of) was not helpful or specific to your inquiry, but I'd like to attempt to make amends. I am quite familiar with your model and in fact have serviced Bosch for around 15yrs. When you receive the timer (It is very rare to need one in a Bosch, more likely stat on the inside door panel) I'd be more than willing to guide you through the process and I will even send you a complimentary service manual if you provide an email address. I will understand if you have closed the door on any further input from "experts" here at FixYa but will do what I can to help if you're open. Sorry once again and good luck going forward. Regards, Macmarkus :)
May 20, 2011 | Bosch 23 in. SHU303 Built-in Dishwasher
Heating element replaced. Worked one load and back or dryer seemed very hot. Turned off and later ran on low. Next load no heat.
Hi.
There is either a problem with the thermostats that turn off the heating element, or the heating element is plugged (elements has contact to ground and stays always on).
Heating element and thermostats are tested reading Ohms with a multimeter set at Rx1. If the circuit is open (Ohms stay infinite), then the part is defective.
If the machine overheated, then the element may be gone again. Test reading Ohms.
Also replace the thermostats (there should be two or three of them), unless the element had a contact, the most common cause for overheating is a shorted thermostat.
Aug 04, 2010 | EuroTech EDC158 Electric Dryer
Hello I am getting error code E3 on my Baumatic dishwahser- how may I resolve this? Thank you
its "malfunction of temp sensor or heating element"so it is either the heating element or temp senser.is faulty test and replace the faulty part
Nov 09, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Cycle doesnt stop
STUCK TIMER MANUALLY ADVANCE TIMER THEY HAVE NOT MADE THE SMU MACHINE FOR OVER 12 YRS MIGHT BE TIME TO REPLACE MACHINE OR GET A QUALIFIED TECH TO LOOK AT
Jul 20, 2009 | Bosch Dishwashers
Bosch Exxcel Type S9N61B
IF YOUR DISHWASHER IS OVER 3 YEARS OLD IT HAS PROBABLY BLOWN THE HEATER IF THEY ARE USED ON REPEATEDLY LOW TEMP WASHES FAT CAN BUILD UP AND DESTROY THE ELEMENT ON A 35 QUICK WASH IT SHOULD HEAT UP WITHIN 12 MINS OF STARTING IF NOT HEATING APPLIANCE WILL WASH FOR UP TO 3 HOURS IN COLD WATER IF CYCLE TIMES ARE NORMAL BUT NO HEAT IS EITHER A THERMOSTAT OR PCB FAULT THE FORMER IS LESS LIKELY,YOU SHOULD GET AREADING OF AROUND 25 TO 30 OHMS ACROSS LIVE AND NEUTRAL AND INFINITY ACROSS LIVE TO EARTH AND NEUTRAL TO EARTH.
HOPE THIS HELPS
Jul 12, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Regular cycle took 3 hours then would not shut off. Stopped at 1 min. soapy water still filled the bottom, dishes had soap on them. water finally drained almost out but I am afraid too run another cycle. ...
There is a heating element in the dishwasher that heats the water to about 155F at which point a thermostat closes and sends power to the timer to advance. If the water does not reach this temp, the dishwasher will not advance. Often the problem lies in a faulty part in the heating circuit like the heating element or the thermostat faulty but you will need a technician to verify.
http://tclaundryrepair.com/home
Feb 20, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Jul 08, 2008 | Ovens
    Hygena Dishwasher doesn't fill with water
    Sorry that is a UK model and wont have any access on how it works.. but you can check the water level probe (if Equipted) clean it off.......... the elements should only come on once the probe tells the board it has water dont let the element dry fire they will burn out fast when not in water
    Feb 04, 2008 | Dishwashers
    Dishwashers Logo
    18 people viewed this question
    Top Dishwashers Experts
