Question about Refrigerators
Neff How To defrost the freezer on a K4664X4GB. Door wouldn't close for a couple of days and it's thick. Do I just bash it out??????
IFIXALL
  • 868 Answers
SOURCE: Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Posted on Jun 06, 2008
jumptrout51
  • 3361 Answers
SOURCE: freezer not defrosting
Your defrost drain line is frozen over.Remove everything from the fridge and turn it off for 24 hours with the doors standing open.
The drain line will thaw and you will return to normal operation.
You could also turn the fridge off, remove the freezer floor panel and back panel. Take a hair dryer and thaw out the drain hole. Takes about 2 hours.
You decide which procedure to use.
Posted on Apr 23, 2009
  • 3 Answers
SOURCE: Neff fridge freezer K4664 broken door handle
Go and find your frig paper work there are areas with parts and how to order them
Posted on May 13, 2009
garing
  • 998 Answers
SOURCE: freezer door closing problem
to keep freezer door from popping open close main door more gently try extending front legs a little to help the door swing shut
Posted on Aug 04, 2009
miket756
  • 2702 Answers
SOURCE: I have a beaumark refrigerator with a freezer at
this could be one of two things,,, the thermostat has failed or it could be the door is not shuting up tight if the door seal is letting warm air in that will cause the ice build up you getting, ,so will that thermostat if its running flat out all day, look at the door first, then try turning down the stat,
Posted on Nov 10, 2009
GE TBX25R refrigerator not cooling. Found thick ice on freezer coils on the mid to upper half. The defrost heater is working, no ice closest to coils and tested the element. Help!
You say the defrost heater is working, but does it switch off at the end of the defrost cycle?
A refrigerator is a closed box and the only water vapour to condense and freeze to produce ice should be from the food and the opening of the door. Remember the days before auto defrost when a fridge in good order needed defrosting only a couple or three of times each year? That is a normal ice build up.
A freezer needed less deicing than that.
Excessive ice signals the possibility of an insulation failure (search for cold areas on the outer casing) a bad door seal, an auto defrost malfunction or possibly a general decline in the efficiency of the cooling system due to a worn compressor or lack of refrigerant - an ice build up in the freezer only means the temperature is below freezing, you didn't mention what the freezer temperature actually is but I wager it is far above the minus 18 - 27 degrees C of an efficient freezer.
One method of judging the efficiency of a refrigeration system - the purpose of which is to move heat from the inside of the cabinet to the outside where it is dispersed by the condenser which will naturally become quite warm. If the condenser isn't as warm or even almost hot as usual while the compressor is running then it isn't efficiently moving heat from inside the cabinet.
Generally a lack of efficiency tends towards longer than usual compressor cycling and even constant running.
Oct 25, 2017 | GE Refrigerators
Neff K3965 side-by-side American: Freezer works but Fridge doesn't any more, 3 days after defrost
Can you remove the freezer rear panel again and take some photos of the frost pattern so I may see what is stopping the cold airflow to the fresh food section?I'm here on Fixya if you have questions
Contact Me Here
Appliance 911 Sea Breeze
Nov 23, 2015 | Neff Refrigerators
The temperature keeps on rising. everything inside is melting. does not freeze anything. fan and light is working.
Turn it off, defrost it for a couple of days """""with the door open""""", restart it with door closed and see if it starts freezing again after about 2-3 hours, if so, then the draw unit works, that indicates the defrost cycle needs to be reset or one of the defrost elements has failed causing the rest no to do anything. Any probs call me on 08 9523 0552 Russ
Feb 27, 2011 | True 31 cu. ft. / 878 liter Upright...
My freezer has ice building up on the bottom
Defrost freezer, and make sure the door close well each time
Mar 07, 2010 | Frigidaire Freezers
I have a beaumark refrigerator with a freezer at the bottom. The freezer keeps filling with a thick layer of ice on the bottom of it. I defrosted it 10 days ago and the build up is already so bad that...
Nov 10, 2009 | Refrigerators
HOW DO I DEFROST FREEZER
Most modern freezers don't need to be defrosted, but should be washed out and cleaned periodically. Following are steps for defrosting freezers that need it -generally when ice builds up to a thickness between 1/4 inch and 1/2 inch.
  1. Step 1 Turn the freezer off. Controls may be inside the refrigerator.
  2. Step 2 Remove all food from the freezer and store in an ice chest while you are defrosting.
  3. Step 3 Remove ice in the freezer compartment. This can be done by: a) letting the freezer door stand open until ice melts; b) putting a pan of hot water in the freezer compartment and closing the door, then checking for melting ice and reheating the water every 10 to 15 minutes; c) using a hair dryer by aiming warm air at ice in freezer until it melts.
  4. Step 4 Pick up ice and water as it melts with a dishcloth or sponge and deposit into sink.
  5. Step 5 Use a sponge or dishcloth and a bowl of warm water to thoroughly wipe out inside of freezer once the freezer is cleared of ice.
  6. Step 6 Turn the freezer back on, close the door and let run for 10 to 15 minutes before returning food to the freezer.
  7. Step 7 Put food back into freezer and close the door.
You can also look at the Video :-
http://www.videojug.com/film/how-to-defrost-a-freezer
Hope i helped you.
KINDLY RATE THE SOLUTION IF 100% SATISFIED.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | GE GSS25JF Side by Side Refrigerator
May 13, 2009 | Neff K4664 Top Freezer Refrigerator
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Mar 04, 2009 | LG LFX25971ST Bottom Freezer French Door...
Neff side by side
Someone left the door slightly open. Cold weather has nothing to do with it. To check the seal take a dollar bill and place it in the jam hanging onto part of it close the door on the bill and then pull it. It should be tightly fit when you pull on the bill. Is the unit a refer or freezer? Is it inside or out.
Dec 18, 2007 | Neff K3965XO Side by Side Refrigerator
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
