Idylis 12000 btu manual
Need the user/instruction manual for the Idylis 12000 BTU portable ac jnit, model 416710
    New Friend:
  • 85 Answers
Find more information on this link:
http://pdf.lowes.com/useandcareguides/840206110031_use.pdf
Posted on Jun 07, 2015
  • Susan Mikol Jul 21, 2017
    Have you looked at those manuals? They tell you nothing about maintenance or repair of these a.c. units. I am researching the same problem with the casing so I can replace the blower wheel.
  • Anonymous Sep 10, 2017
    Stand alone a.c. exhaust fan removal:https://www.youtube.com/watch?v=pFxwdrk0...
5 Suggested Answers
SOURCE: User manual
I have the same unit, we've used it most days in our office since beginning of April and it's just cut out. I removed the drain plug at the base of the back and drained out about 1 litre of water. It's now working perfectly again. My guess is depending on the humidity it should run about 1 full month before emptying
Hope this helps
azzymodo
Posted on Jun 03, 2009
SOURCE: DeLonghi PAC A120E Pinguino 12,000-BTU Portable Air Conditioner - Water Leakage Problem
I had the same problem and found a fairly simple solution. UNPLUG THE UNIT FIRST. All left and right reference below is as view from the BACK of the unit (NOT from the front). Open the right side panel (right as view from the back), by removing six screws (remove screw covers first) and pull down on the panel to remove. Towards the UPPER-back of the unit, there is a cold air evaporator(?)(bunch of tubes and fins) you can only see the edge of it after removing the right panel. Below it is a white plastic drip tray with a hole at the end allowing water to pass down to the lower warm air radiator(?) (another bunch of tubes and fins) to evaporate. If this hole is obstructed, water will over flow and leak. I cleaned out the hole with a vacuum attached to a drinking straw, you might have a better way. After cleaning, I poured a little water through to make sure it drains. There is a lower drip tray at the bottom of the unit which catches the water and you can drain it out the bottom drain hole by unplugging the rubber stopper at the back bottom of the unit. The lower drip tray has a float switch (you can only see it by removing the back panel, which you don't have to do for this procedure) which turns off the unit when the lower tray is full. So, theoretically, even if the evaporation is not working properly, as long as the upper drain hole is not obstructed, there should not be any leakage, because the water will drain into the lower drip tray and turn the unit off when it is full. The upper drain hole obstruction might be causing most of the leakage problem. Also make sure the unit is level left to right. If the left side (left as viewed from the back) is lower than the right side (as view from the back) the water in the upper drip tray might not flow to the drain hole properly and might overflow. You should also vacuum and clean the upper plastis filter screen (pull it out from the top back of the unit). Before closing the right side panel, you might want to vacuum and clean the lower warm air radiator, be careful not to damage the fins. Again before you start any of this, UNPLUG THE UNIT FIRST. This might be easier than packing and sending the over 90 pounds unit to an out of town service center. I understand some service centers might charge $100 for a simple cleaning. Consult a trained technician if you don't have the skill to do this. Do this procedure at your own risk because I am not sure if it might void you warranty. Again UNPLUG THE UNIT FIRST before you start.
Posted on Feb 23, 2009
nitrospawn
  • 290 Answers
SOURCE: instruction manuals for Everstar 11000 btu portable AC needed
here is it http://bit.ly/aXbebF
Posted on Apr 30, 2010
  • 45 Answers
SOURCE: frigidaire fac127p1a 12000 btu compressor
The compressor is probably going out on either a pressure related or heat related overload. Both are a result of low refrigerant. There may be a low pressure safety swich that protects the compressor. Otherwise it may be an internal thermal overload that is tripping. It resets itself and comes back on. The thermal overload heats up and shuts off the compressor to protect it from too much heat which is gernerated by not enough refrigerant in the system to keep the compressor cool. It may be cheaper to replace the unit than have someone try and fix it. It is pretty time consuming and you cannot try it yourself unless you have an EPA Certificate to buy the refrigerant. Check with your local appliance repair man to see if he will tackle it.
Posted on Jun 05, 2010
RE: IDYLIS Model #0625616 Portable Air Conditioner - what are the BTUs for this model? Thank you
Just get the tonnage and multiply by 12000 .That will give you your BTU
Jun 03, 2017 | Heating & Cooling
Do you have a user manual for an idylis air purifier model IAP-10-200?
Idylis IAP-10-280 C & D Filter Change for Part # IAF-H-200C ...
? 2:16
www.youtube.com/watch?v=rZApdO6gSM4
Apr 16, 2014 - Uploaded by Crucial Air
http://www.crucialair.com Replacing your Idylis IAP-10-280 C & D ... As the air filter accumulates more debris over time, the air purifier's filtration capacity lessens. ... Lowe's Idylis 10,000 BTU A/C Instructions (Model: 0146709)
Sep 17, 2015 | Air Air Purifiers
My kenmore 12000 btu portable air conditioner keeps switching to DH mode out of AC mode
That means that it is dehumidifying. Is the air coming out still cold? I assume you have tried using the mode button to switch it back? Is the air extremely humid? Perhaps it is humid enough that the machine needs to dry the air before safely operating as an AC. The manual is available here:
http://www.sears.com/kenmore-portable-room-air-conditioner/p-04272012000P
Jul 05, 2015 | Kenmore Portable Air Conditioner 10000 BTU...
I need the user manual for an Idylis 416710 portable air conditioner unit.
go to danby products not the same model but still the same operation
Feb 23, 2015 | Heating & Cooling
How do I get a manual for idylis 416710
Go to Idylis website and search fro model 416710. Or use Google Search and enter Idylis 416710
Oct 01, 2014 | Heating & Cooling
How to know the tons of old ac unit from the model no?
36 is equal to 36000 btu. To find the ton divide by 12000 btu. 12000 BTU is a ton of refrigeration. This is a 3 ton unit.
Jun 17, 2014 | Weather King 10AJA6001AH Air Conditioner
What extension cord should i use on window ac unit model number ASW12ALS1 12000 btu
http://www.appliancefactoryparts.com/search/part/1042383/116404 this is a link formthe extension cord you need.
Jun 20, 2012 | GE 12000 Btu Room Air Conditioner EnerStar...
Window kit dimentions i have a window 18 inch wide
The portable AC units generally have a customizable, exhaust hose window, termination kit that comes with the unit.. In other words it can be cut to fit. The one that comes with the unit will fit casement windows, as well as sash windows.
To further assist you, I have included a link to the Owner's/Installation Manual for the model you referenced. You may download and print it if you like.
http://www.air-conditioner-home.com/manuals/ac-12000.pdf
Hope this helped you. Please let me know. Thanks.
Jun 13, 2011 | NewAir AC-12000E Portable Air Conditioner
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
Heating & Cooling Logo
14,204 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
