Eletrolux ews 700 fabriguard
The washing machine some times switched on properly and some times remains dead
4 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: I have a GE washing
Hello there:
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Posted on Sep 28, 2010
  • 6277 Answers
SOURCE: Hi, I have and Electrolux
(pre-typed to save time- common problem!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 24, 2011
  • 69 Answers
SOURCE: problem with electrolux washing machine
draining pipe its too low. check this link:
http://applianceguru.com/washers/drain-min.jpg
Posted on Aug 27, 2012
I have a semi automatic Washing machine electrolux fabriguard turbo.the spin motor of machine rpm get too much slow in load while without load it runs fine.what is the problem behind this.
Probably you overloaded this machine and with to much load in it it Will run slower and probably shaking pretty heavy, try-out a little, but you also can look up the heaviest possible weight to load in this type of machine but more then five or six kilogram dry clothing is pretty heavy when wet..
Aug 19, 2015 | Electrolux Washing Machines
I have an Electrolux EW Aqualux 1200. Two weeks ago a sock was stuck into filter. I removed it, switch off/on machine a few times, ran machine empty. However since then machine is spinning only if it is...
9 years a good life for Washing Machine, I can't see why you have this problen , since you cleared it by taking sock out of filter, but expensive to get repairer to look at it , as 9 years old , get a new one . Better than spending money on a repair,
Mar 14, 2015 | Electrolux Washing Machines
I want to know what error code E70 on my Electrolux EWS 1050 washing machine means.
error code e 70 the control board is not seeing the proper water supply amount in this case check the pressure switch as well as the water valve assure that you are getting hot and cold out f the water valve one from each side if the valve is ok then you would move on to checking the pressure switch how much water is fillinig on the inside of the machine when this error happens? if you have any further questions message me back Thanks again Rick
Jan 23, 2011 | Washing Machines
Washer will not drain or fill. it is only 2.5 years old.
the pipe must broken or it is blocked by a cloth or something rate : )
Aug 23, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Essential 1600 front load washing machine - it has now stopped taking the fabric conditioner ?
Eletrolux Essential 1600 front load washing machine
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
May 10, 2010 | Electrolux Washing Machines
We have a Kenmore 700 washing machine. It will
Lid switch is not sensing lid down. Try pushing down further with screwdriver, but it will need to be replaced.
Aug 26, 2009 | Kenmore Washing Machines
The wash cycle starts with a 5 second delivery of water then stop
SOUNDS LIKE YOURE INLET VALVE HAS FAILED IF YOURE MACHINE IS COLD FILL ONLY IT WILL ONLY WORK ON ONE PART OF THE CYCLE ALTHOUGH IT HAS ONLY COLD FILL THERE ARE 2 VALVES SHARING SAME BODY,WILL NEED CHANGING
Aug 11, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Washing Machines Logo
Top Washing Machines Experts
