Question about Bosch Refrigerators
Bosch intelligent frost free 40
Our fridge fan is not cooling on, what do i do? sometimes it cools on but sometimes it's doesn't...
2 Suggested Answers
SOURCE: bosch intelligent frost free 40
The small drain pipe on the back of the fridge gets clogged, hence no drainage when defrosting, hence ice blocks the airflow between the freezer compartment and the fridge compartment.
Remove the rubber stop from the drain pipe and clean (can be found above the motor)
Defrost the fridge for a few days (it takes at least 48 hours). During this time, if you are not brave enough to remove the internal panels of the freezer and continually clean the water, check for water coming out and clean.
If during the defrost there is no water coming out the drain pipe, use about 2m of flexible and strong wire to clean the pipe.
The aim is to unblock the pipe once the ice has melted.
Posted on May 12, 2009
I live in York WA and require a Bosch Intelligent Frost Free 40 fridge/freezer.. fridge door seal. Would like to know how much... and where to purchase? Gail
you can go online and search for the part using make and model their are 100s of appliance parts suppliers or go to bosch site and either order or request a supplier by you
Apr 23, 2017 | Bosch Refrigerators
Bosch intelligent frost free 44
the fridge might have iced up in the coil due to a defrost problem. one way to check it is to leave the fridge off for a few hours and leave the door open. turn the fridge back on after the few hours and see if the performance is any better. Let me know how it goes
May 22, 2014 | Refrigerators
THE REFRIGERATOR IS NOT COOLING EVEN WHEN ON 9 ALSO THE FREEZER IS THE SAME
Insufficient Cooling
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly. Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly. * Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches). * Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section. * Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working. * Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover. Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer. Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hoping this will help to solve the problem....
Aug 09, 2011 | Refrigerators
My refrigerator is not get cold its cool but not cool enough for milk
Step 4 - Volt Test
Hoping this will help in solving the problem......
Aug 04, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
The fridge part of my style Amercian whirlpool 6th sense fridge freezer is not keeping the food cool
Step 4 - Volt Test
Jul 03, 2011 | Whirlpool Refrigerators
Amana arb8057csr freezer works fine, but refrigirator not cooling fully.
Step 4 - Volt Test
Good luck in solving
Jun 19, 2011 | Refrigerators
Refrigerator not cooling
Step 4 - Volt Test
Hope this will help out....
May 10, 2011 | LG Side By Side Refrigerator 25.5 Cu. Ft....
The fridge is not cooling, the fridge temperature is 9 degrees and the freezer temperature is -16 degrees. All this on the coolest settings.
Step 4 - Volt Test
Hope this will help in solving the problem....
May 07, 2011 | Refrigerators
Freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Nov 08, 2009 | GE PSS25MGN Side by Side Refrigerator
Jul 27, 2008 | Bosch Refrigerators
Refrigerators Logo
15 people viewed this question
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
