Question about Samsung Corby 2 GT S3850
Multiloader rsrc1 download - Samsung Corby 2 GT S3850
My corby 2 is always hanging when i turn it on its always stuck in gts3850
For those who asked about phone stuck at the S3850 logo when turned on, it seemed that you have bricked the phone.
What I did was I reflashed the phone into the stock Corby 2 using Multiloader via USB Cable.
Link for the multiloader :
http://www.mediafire.com/download/4wotk6yn6y1h5ux/multiloader+v5.67.rar
Link for the firmware :
http://www.mediafire.com/download/a4a38yf3wz9f8zd/S3850XEKC5.rar
Link for the tutorial on how to do it :
http://www.tsar3000.com/Joomla/index.php?option=com_content&view=article&id=843:how-to-update-samsung-s3850-corby-ii-firmware-using-multiloader-program-and-usb-cable&catid=57:how-to&Itemid=104
Hope that helps...
Sep 23, 2014 | Samsung Corby 2 GT S3850
How to convert samsung corby 2 into android
  • download multiloader v.5.56
  • download usb driver for samsung corby2
  • download firmware for corby 2
  • when you do this turn off your corby2 and turn it in dowload mode
  • connect your corby2 into your computer
  • open multiloader v.5.56
  • click on " brcm2133" then click "full download"
  • open the folder were your firmware is
  • select all the files and click on them to drag them into your multiloader
  • when you do this click on " port search " after that it will appear " READY (FRRAPE)
  • finnaly click on the donload button and wait untill your corby2 automaticly start dont touche anything untill it finish starting
i hope those tips will help you ! good luck :)
Apr 29, 2014 | Samsung Corby 2 GT S3850
How to re format my samsung corby 2 s3850
Dante;
have you tried the hard reset code
*2767*3855#
Mar 28, 2012 | Samsung Corby 2 GT S3850
I have a samsung gt- S5230 star its doensn't work after i change the level of debug.And my phone it says upload data to pc. What can i do?
Easy steps to follow 1. DOWNLOAD THE LATEST FIRMWARE (AROUND 80 MB IN SIZE) and MULTILOADER
http://firmware.sgh.ru/files/S5230XEIG4.rar 2. Make sure Samsung PC Studio is installed and communicates with your phone 3. Unrar the firmware in a folder you can easily find it.Also unrar the Multiloader in another folder. 4. BACKUP YOUR PHONEBOOK AND MESSG USING PC STUDIO.
Remove the Sim and MicroSD from your phone and replace the battery.
5. Now press vol top button+camera key+powerbutton at the same time in switch off mode without attaching the datacable.
6. Soon u will see a new screen which says Download.
7. Now attach the datacable to the phone and open Multiloader which u donwloaded earlier.
8. Select the radio button that includes MSM6250/MSM6250A or BRCM2133
9. Select Boot Change,Full Download and master rom boxes.
10. Then click Boot, and select the boot files from the unpacked firmware folder.(........\S5230XEIG4\S5230XEIG4\BOOTFILES)
11. Click the Amss, Rsrc1, and Rsrc2. and select files apps_compressed.bin and Rsrc_S5230_Open_Europe_Slav.rc1 and Rsrc2_S5230(Low)_RU.rc2 respectively.
12. Note: Select (Low).r2c NOT (Mid).r2c. (Phone may not restart if you select mid)
13. Then press the Factory FS tab, and select the appropriate files from the firmware folder also(FactoryFs_S5230_Open_Europe_Slav_RU.ffs).
14. FOTA and ETC fields are left blank.
15. Click the Port Search button, it will find your phone and show the com Port is ready
( Make sure that following options are checked "right" symbol in the check box against them before you click downlaod
Boot Change
Full Download
Master rom
Boot
Amss
Rsrc1
Rsrc2
Factory FS tab )
16. Click the download button and be patient, this will take a few minutes to complete.
17. When it's finished, it will show "All files complete".
18. Unplug the phone from the USB cable, reinstall the sim, MicroSD, and power up the the phone.
19. Now with every thing complete, You can perform a hard reset by typing *2767*3855# into the hand set (but not necessary.)
20. When the phone resets type *#1234# into your handset to check your new firmware ver.
your new Firmware is updated and ready to use.
Oct 20, 2010 | Cell Phones
I've forgotten the password to my phone and now i can't unlock the phone lock code .. is there any other way to reset the phone where can reset everything in my phone
hi,you will have to format the phone,OK this is the start and l hope that you all will consider and post any newer information.
First thing to always remember, is BACK UP YOUR PHONE, Pictures,wallpapers,music, and any contacts you have saved on your phone. I am not responsible for any damage to you, your phone, computer, or lost of data in this process. This is a guideline intended for professional technicians.
USE AT YOUR OWN RISK!!!
1. USB cable that came with your phone.
2. Samsung PC Studio 3 witch can be found here:
http://www.samsung.com/uk/support/d..._ia_cd=01011800
Install this software first, it contains the drivers for your phone, and has every thing you need for backup.
3. Multiloader v5,50 http://www.4shared.com/file/75565159/e43d163c/MultiLoader_V550.html
5. Newest unbrranded firmware http://www.megaupload.com/?d=B5CXDIOZ
Now you are ready to begin,
1. Make sure Samsung PC Studio is installed and communicates with your phone. And unpack the firmware in a folder you can easily find it.
2. Remove the Sim and MicroSD from your phone and replace the battery.
3. With the phone OFF connect the phone and computer with the USB cable.
4. While holding the no. 9 button on the phones key pad, tap the power button, the phone screen will come on black with a red stripe that says "Download" ( For Tocco and Pixon users : Hold down the "Volume -" button on the left side, and the "Camera" button on the right, then press the "Power" button = all three buttons need to be pressed together. Your phone should start up into a red\blue on black bootloader screen.)
5. Now run MultiLoader v5.33
6. Select the radio button that includes MSM6275/MSM6280.
7. Select Boot Change and Full Download.
8. Then click Boot, and select the boot files from the unpacked firmware folder.
9. Click the Amss, Rsrc1, and Rsrc2.
10. Then press the Factory FS tab, and select the appropriate files from the firmware folder also.
11. Select (Low).r2c NOT (Mid).r2c. (Phone may not restart if you select mid)
12. FOTA and ETC fields are left blank.
13. Click the Port Search button, it will find your phone and show the com port is ready.
14.Click the download button and be patient, this will take a few minutes to complete.
15.When it's finished, it will show "ok complete".
16.Unplug the phone from the USB cable, reinstall the sim, MicroSD, and power up the the phone.
17. Now with every thing complete, perform a hard reset by typing *2767*3855# into the hand set.
18. When the phone resets type *#1234# into your handset to check your new firmware version.
wish you good luck,
take care.
Aug 15, 2010 | Samsung M8800 Pixon - Unlocked QuadBand...
I replaced screen on samsung eyernity. i put it back together and a message densbl boot loader for msm6290 poped up. how to fix
Sound like your phone is in bootloader mode. This is for updating the firmware. Pull the battery and try turning the phone on.
If this does not work you will need to update the firmware to send the reset signal to your phone
Check out Howardforums for firmware and updating instructions
or Samsung flash world
If the bootloader is damaged your phone may be cooked
Dec 04, 2009 | Samsung Eternity Cell Phone
I am trying to remove my o2 operators logo from my samsung toccolite
Hi,you can do this by installing a new software version on your tocco,
You will need a usb cable to connect phone to pc
Download multiloader
http://tinyurl.com/mxl7xl
Download firmware for a tocco lite such as
http://tinyurl.com/n6nwa9
Connect tocco via usb cable & put in download mode (Hold down the 'Volume down' key,hold in camera & power on) screen should then say download,
Open multiloader ,select the 2nd box MSN2675...,then select full download,select boot and search for bootfiles from the firmware files you downloaded,do the same fof amss,rsrc1,rsrc2 and factory fs,leave the rest as they are,then port search,then download,DO NOT TOUCH AGAIN THE PHONE UNTIL ALL COMPLETE
Download will begin
Ensure your tocco has good charge in battery before starting as its important it doesn't power off during download,keep it connectes until message appears saying all files complete and phone reboots,
You should now have a phone running the newest samsung firmware and no network branding logos
Sep 08, 2009 | Cell Phones
Blackberry
1, Download the Firmware, Drivers and Desktop Manager for your handset from Blackberry.com. The firmware will be for AT&T and the Desktop Manager without Automatic Updates.
2, Install the above and make a backup of the items you need from your phone.
3, Download and install MFIMultiloader
http://www.mediafire.com/?y2vmtmjhjmj and its other parts from http://www.mininova.org/tor/2125273
4, Delete vendors.xml from Program Files > Common Files > Research in motion > Apploader
5, Disconnect from the internet.
6, Plug in your phone and run MFI Multiloader, when it has finished your phone will display "1" and the MFI Multiloader will show "PASS"
7, Disconnect phone from PC and type START on the phone and you should get an error 507 message, with the phone failing to start.
8, Connect it backup to the PC and run Desktop Manager, goto Add/Remove applications and reinstall the phones firmware.
9, Once this is done the phone should be unlocked, it takes a while to startup, you can then restore whatever you backed up :)
May 09, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Software update
Downloading the software:
First off you need to download the firmware you want and then Multiloader V5.33 which is the program you're going to be using to flash your phone.
F480 / F488 / DOWNLOADER
F480XEHE1
http://www.mediafire.com/download.php?uykac2jjusd
F480XEHE2
http://www.mediafire.com/?ylcthnu0tyy
F480XEHF2
http://www.mediafire.com/?9w2u40e9m4z
F480XEHF3
http://rapidshare.com/files/12658213...XEHF3.rar.html (http://rapidshare.com/files/126582139/F480XEHF3.rar.html)
F480XXHD9
http://www.mediafire.com/?ttg0mybtzie
F480BOHE3 (branded FW t-mobile) deutsch,english,french
http://www.file-upload.net/download-...BOHE3.zip.html (http://www.file-upload.net/download-910195/F480BOHE3.zip.html)
http://rapidshare.com/files/124143899/F480BOHE3.zip
http://www.dongnamass.com/Samsung/Fl.../F480BOHE3.zip (http://www.dongnamass.com/Samsung/Flash_Files/F_Series/F480/F480BOHE3.zip)
F488ZHHE8 (chinese)
http://rapidshare.com/files/12588987...ZHHE8.rar.html (http://rapidshare.com/files/125889871/F488ZHHE8.rar.html)
MultiLoader_V5.33.exe
http://www.mediafire.com/?czizm9zg32w
Make sure you remmeber where you've put these files as you'll need to browse to them when using multiloader.
Preparing your phone:
I am assuming here that you've already installed Samsung PC Studio and it works fine with your supplied USB cable.
NOTE: Flashing your phone will delete all your contacts, calender, settings ringtones etc.
You probably want to back up all your files and contacts. I recommend syncing your contacts etc. with Samsung PC Studio and copying over your files on your phone to your memory card or PC (your memory card will not be touched).
Once that's done remove any memory card you may have and then remove the SIM card. Put you battery back in. Your phone shoul be off at this point. Hold down the 'Volume down' key (The bottom rocker button on the left side of your phone) and the camera button and press the power on button. Your phone should start up into a wierd screen with downloader v.5.32 or something and some boxes. It's now ready to be flashed.
Using Multiloader:
Open multiloader. It should look something like this without all the settings selected (The middle section should be blank!):
http://www.mobisphones.com/F480.JPG
Ok, Morpheus originally selected the wrong option in the top box, you should select the second option from the top (MSM6275/MSM6280).
Then press the AMSS button on the left side and browse to the firmware files you want to flash (unzip/rar them as necessary). Go to the binary folder and then select amss_compressed. Do the same for Rsrc1,Rsrc2 and FSS selecting the appropiate files as shown in the above pic.
You should now be ready to flash. Connect your phone to your comp and then click download in multiloader. AT THIS POINT DO NOT TOUCH YOUR PHONE/DETATCH THE CABLE/SWITCH OFF YOUR COMP. Your phone should have a status indicator with percentages and this should be reflected in multiloader. The process should tkae about 5 minutes thgouh I'm not sure about that. Once it's done your phone will restart twice by itself. Once this is done it should start up as normal into the widgets page. It's now complete.
Congratulations on flashing your phone. You can now repalce your SIM and Memory card and set up your phone the way you like it.
Hope this helped. :)
Feel free to steal this tutorial/post it on another website etc., I made it in a few minutes and couldn't care less if you take credit for it.
Oct 27, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung Corby 2 GT S3850 Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
