When i power on my HT C350, message PROT will be display
When i power on my Samsung HT C350, message PROT will be display.please help
ginko
  • 19396 Answers
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
  • 56 Answers
SOURCE: No disc error fo HT-TXQ120
try to clean the lens of the unit
use a lens cleaner (disc) or compressed air
Posted on Jul 02, 2009
SOURCE: HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
Posted on Apr 08, 2010
SOURCE: samsung ht c550, enciende, saluda,
when i turn on my Samsung HT-C550 IT showing PROT and DVD turn off. What this is mean PROT?
Posted on Jan 10, 2011
  • 55 Answers
SOURCE: when i turn on my
PROT means that the AMP is protecting itself from damage due to bad or incorrect wiring or damaged and or incorrect speakers. Check your wiring and speakers.
If you find no problem then, DISCONNECT YOUR SYSTEM FROM THE POWER, disconnect your speaker wires...all of them, then reconnect the power ONLY, turn on the system and see if it still says PROT. If it does then your amp is damaged.
Posted on Feb 20, 2011
Samsung dvd player display says "protection" . Wont turn on.
Swtch off and disconnect and reconnect all the wiring especially speaker wires.
Also try resetting as per manual.
If that doesn't work then could be capacitor blown on motherboard.
Aug 06, 2014 | Samsung Ht-c650w 5.1 Home Theater System -...
I have a samsung HT-Z120 it show a PROT error
This error means that you are trying to play a region-protected disc that is not in the same region as your player.
It is possible to "hack" the region on your DVD player by following these instructions:
http://www.videohelp.com/dvdhacks/samsung-ht-z120/10244
Please rate my answer.
Thanks,
Chris
Mar 05, 2011 | Samsung HTP-1200 System
When i turn on my Samsung HT-C550 IT showing PROT and DVD turn off. What this is mean PROT?
Feb 20, 2011 | Samsung HTC550 Theater System
When i turn on my cinema system 'Protection' come's up then it turns off. Help please
Its the ic audio amp board.......disconect the board and u will see the power turns on.....i have the same problem .......cant be repaired the cost is to expensive....i have put 2 fan on the ic board it keeps the unit cold and can play it about 5 hours daily
Nov 13, 2010 | Samsung HT-TZ215R Theater System
Samsung ht c550, enciende, saluda, lee y aparece el mensaje PROT y se apaga.
Oct 11, 2010 | Samsung HTC550 Theater System
Dec 29, 2009 | Samsung HT-DB120 System
Jun 01, 2009 | Samsung HT-TXQ120 Home Theater System...
54 people viewed this question
 Grubhead
Grubhead
