Question about Home Fencing
5fbe18 af error code ..what check? - Home Fencing
What does code AF stand for?
AF is an air flow error check lint screen and exit hose
Apr 05, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
It will not dry it say the lettrs af
The airflow is restricted as indicated by the AF code. Check for clog lint filter and/or restricted vent system as lint build up in these areas cause airflow restriction and hence the AF code. Another possible reason is a faulty exhaust thermistor located on the blower housing. It is likely a thermistor fault if the lint filter including the vent system are all clear from lint built up but the AF code persists.
Disconnect power then remove the rear access panel and locate the thermistor on the blower housing. Disconnecting the thermistor and running the dryer will cause E1 to appear on the display to indicate an open circuit thermistor and E2 if the thermistor wires are connected together. Replace the thermistor if this is the case. Click on the links below for additional troubleshooting information.
Error Code E1
Error Code E2
Error Code AF
Jun 18, 2011 | Whirlpool Dryers
AF error will not go away after cleaning vent and lint filters
Thank you for contacting Fixya.com.
AF is an error that will flash if a restricted air flow is sensed by the dryer control. If three consecutive cycles have low airflow the control will flash the AF error.
The AF error code can be cleared by pressing the Drying Temp pad for 5 seconds while in stand-by mode. AF will flash in the display for 1 second then "on" will appear in the display. If you press Drying Temp again and "of" will appear in the display indicating the AF error display has been turned off. Try this procedure and see if the "of" error goes away. If the "of" came up in the display by itself then the keypad may be stuck. However After cleaning the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Please get back to us if you have any further query.
Nov 29, 2010 | Kenmore 67062 Dryer
My AF-S120FX sharp air conditioner will work for about 15 minutes and then stop and the error/problem code E1 shows up. Do you know what this code means and/or how to correct the problem?
Check the outside fan and condenser . condenser must be really clean and fan must operate. Make sure the fan on the evaporator in the house is working as well. Pressures exceed rated running values if not.
Aug 04, 2010 | Sharp AF-S120FX Air Conditioner
AF Error Code
If thats not it, then you nay have a faulty sensor.
AF Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Mar 18, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a whirlpool cabrio dryer and it is showing AF on the display and it isn't drying. what could be the problem?
AF Error Code for the Whirlpool Cabrio Dryer is a Air Flow problem. Check your dryer vent and the outside exhast vent.
Jan 13, 2010 | Dryers
Mfc 440cn touble msg: unable to init af on the screen,
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with thearrow down (round) key. You'll find an entry listed as purge count.If number is over 6000, enter 2 7 8 3.
This will reset thepurge count value. Then the printer will restart, hopefully withoutthe annoying cannot clean message.
Oct 21, 2009 | Office Equipment & Supplies
When steering forklift 5FBE18 want move
you have a welded directional contact . You need to change all directional contact tips.
Mar 18, 2009 | Home Fencing
A17 wont boot
ok what board is it
#then check the manual for error post code error af
if not try another card liek a pci one
or agp one
Jun 06, 2008 | Abit AI7 Motherboard
Home Fencing Logo
79 people viewed this question
Top Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
