Question about Carrier 38CKC036 Air Conditioner
Fv4anf005 puron txv
What is the tonnage
Puron leak
not all electronic leak detectors pick up r410a-puron. Evaporator coils are notorious for leaking puron. your coil should be under warranty.
Sep 20, 2013 | Goodman CKL42AR42 Air Conditioner
I replaced my whole heat pump system 3 years ago with a Carrier Puron unit. The installer called me this week and told me that I needed to replace the puron after the third year at a approx cost of...
Tell him you already had it done. lol. Unless you misunderstood what he told you no! You don't need to replace the Refrigerant weather it's Puron or Freon. It doesn't wear out. Ever. If your system develops a leak and you loose the Refrigerant it will have to be replaced but you will know you lost it because the system won't cool and heat like it's supposed to. I would report the installer to the better business bureau.
Aug 31, 2010 | Carrier Heating & Cooling
I have a Lennox CH23.51 series coil unit using R22 freon installed one year ago. Compressor is 9 years old. Down the road when replacing compressor (R410A ), will CH23.51 unit be compatible after changing...
This evaporator core is R-22 / R-410A compatible. The Thermostatic Expansion Valve (TXV) is for R-22. If retrofitting to R-410A, a new TXV metering device would be required, but the evap. core itself could be re-used (as long as you stick with the same Tonnage you have now). If upgrading to a higher tonnage system (like going from 4-Ton to 5-Ton), then you would need a totally new evaporator core.
Jun 08, 2010 | Heating & Cooling
Central A/C unit
That would be a 2 ton 24000 BTU unit
heatman101
Apr 23, 2010 | Heating & Cooling
Have a 5ton straight cool ac system. It's a Payne puron split sytem. metering device,txv. It will run for about 5 miutes during that time u can feel some cool back on the suction line. after that run time...
Brand new systems won't require cleaning. Debris could get trapped inside the internal parts/lineset and break loose and cause a blockage which could cause high head pressure, hissing and over amp. It is possible that the charge requires readjustment. It could be overcharged.
Apr 07, 2010 | Heating & Cooling
What ton is good man ckl 49 il where is the model number onthe furnace
ok ready for this? To find the tonnage look at the serial # Tonnage is related to 12's If there, on the serial # there is say 0062490 the tonnage is 24 or two tons 24 divided by 12 equals 2 Say the serial # contains 0063090 then the tonnage is 2 1/2 because of the 30 hopefully you see what I am saying the number in the serial # if it can be divided by 12 or 6 this is the tonnage. If you will send me the serial number I will tell you the tonnage. The serial number is on the outside unit at the copper connections where the electrical lines go in.
Good luck on your repairs hope this helped send me a note online here and if you need I will give you tonnage if you send the model # and serial number with your response> I will check online around 1500 hours on 1/9/10 central time. Remember to look for the numbers that are divisible by either 12 or 6 on the serial number
Dave
Jan 08, 2010 | Goodman CKL60AR60 Air Conditioner
Need to verify tonnage of unit
In almost every case, most manufacturers put the tonnage in the model number. Look for something that is divisible by either 6 or 12. Something like, 24, 30, 36, and so on. Cfm has to match the tonnage. Usually in the neighborhood of 450 cfm per 12,000 btu's of cooling for the inside of the structure.
Hope this helps.
May 08, 2009 | Heating & Cooling
Carrier indoor coil replacement
yup, entire system needs to be drained, and leak needs to be repaired first before charging with freon.
after sealing the leak and test it is ok, evacuate the system for about 30 mins before charging it.
you may need a qualified tech to do that because you can not buy freon now a days.
you need to weld the leak also. you will need portable torch to weld copper pipes.
you will need vacuum pump to evacuate the system before charging with freon 22.
tnx 4 using fixya,
drcool
Sep 18, 2008 | Carrier Heating & Cooling
Carrier 38CKC036 Air Conditioner Logo
125 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
