Question about Exercise & Fitness
Fast trak treadmill 7700
The treadmill seems to smell of burning after 5 mins in use, then the e1 comes onto the display. can stop and then restart again. can you give me a solution please
  • 64 Answers
SOURCE: Treadmill runs then stops. E1 error and sometimes works fine.
Yes if speed sensor is too far from magnet it will not pick up belt movement. This confuses the computer and as a safety precaution it shuts the machine off. Find speed sensor and check for proper alighment with magnet.
Posted on Jun 08, 2009
  • 3 Answers
SOURCE: kettler treadmill "silikon wartung"
Hi eirik,
Your treadmill needs lubricating.
Get a an aerosol with silicone lubricant and spray it under the belt & on top of the ground board.
Then turn the belt by hand (treadmill switched off!) until you've lubricated the whole belt.
Next leave the machine running for 5 minutes at 5 KM/H (3 M/H) without any load on it.
That should do the trick.
Posted on Aug 30, 2009
maxtreadmill
  • 832 Answers
SOURCE: my tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
Posted on May 17, 2010
Testimonial: "very helpful thanks saved me lots of money "
  • 33 Answers
SOURCE: I have a Tunturi j770 treadmill with error code E1...
Your problem could be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
  • 33 Answers
SOURCE: Tuturi J661F stopped working - Error E1
Your problem might be that a magnet has fallen off. Here's an illustrated tutorial that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
My tredmill works but after few mins I get burnt smell?
Treadmills are relatively simple machines, which means a burning smell can be quickly determined.
Check your treadmill belt for wear. Try to find where on the treadmill feels hot when you smell the burning. It could possibly be the electric motor or wiring giving out under load.
Oct 01, 2015 | Cars & Trucks
My Horizon T80 treadmill is emitting a smell after operating a while not an electric smell but a rubber chemical smell
How old is the walking belt? When was it last replaced? How many miles are on the belt. Seem like your belt and deck is worn.
Jan 01, 2014 | Horizon T92 - Treadmill
Cardiotech x7 e1 code
test the input terminal motor, if there are the motor is faulty, see my personal TIPS 2) test the output voltage from control board, if there ARE NOT for input voltage motor, the board is faulty. see the diagram attached. 3) the error coming from speed sensor, Run the software calibration for easy diagnostic and fix it. However you must LUBE the deck belt,+rollers bearing front +back see the video attached.
God bless you
Nov 27, 2013 | Exercise & Fitness
Error E1 on star trak treadmill
please test the speed sensor. see the diagram attached .This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board test the output voltage for input voltage terminal power if there are NOT the board is faulty . The error codes will differ between makes and models but could be e1.
See my personal TIPS for help.
Nov 13, 2013 | Spirit Weslo FREE SPIRIT 815 Treadmill...
I have an E1 error on my Cardiozone Light commercial fast track elite 2 treadmill
1) adjust the speed sensor, and clean it, and tight the connector very well.see the diagram
2) test the main board output , for input voltage motor, if there are NOT the board is faulty see the block.
3) test the motor for input voltage, if there are the motor is faulty
God blesss you
Sep 19, 2012 | Exercise & Fitness
WAs using treadmill with 2 minutes left it stopped and there was a E1 in the display... Now it wont work...
the E-1 means motor lost speed signal their a number of things the can cause this problem:
1) Motor brushes worn down to less than 3/8" in length REPACE BRUSHES
2) Motor Control Board : After starting the treadmill was their burning smell REPLACE BOARD. this condition can be caused by a worn running belt and deck Loosen belt and with a good light and inspect the weave of the belt , it should not be smooth and deck should have a dark mirror gloss with no ridges. is so they also need to be replaced.
3 Ribbon connector may defective so if the Motor Controll Board is operating the red L E D are lit one is 11 v dc and the other is 5 v dc check voltage on the upper console then if one of these voltage are missing between the boards then replace the ribbon.
Uplug unit open motor shroud and begin with # 1 plug unit back in at wall socket and due the rest Good Luck!!
Mar 01, 2010 | Exercise & Fitness
My NordicTrack EXP 1000 stops in the middle of a workout. Before it stops, I smell a rubber smell. 1) Does the tread need lubrication? 2) Is the motoer burning out?
my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
Jan 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
23 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
