Question about Sony KV-36XBR400 36" TV
Sony 32XBR400 Wont Power On
About a month ago my set started having a hard time turning on. It was taking longer and longer for the picture and sound to come on until last night when it just stopped working. I can hear the relays clicking as it attempts to power on but after about 30 seconds it goes back to standby. I have read about the blinking standby light diagnostics, but it blinks about 10-11 (not sure if the first power on blink counts) times and the previous messages only talked about problems up to 8 blinks. I removed the rear cover and looked for burned resistors and loose or cold solder joints. There was nothing obvious found. Do you believe the set is too far gone or might there be an easy fix?
  • 398 Answers
I do not believe the set is too far gone. The standby light blinks codes up to 7. If the standby light blinks more than 7 times it usually means that there is a short on the clock or data line. There are several small zener diodes connected to the clock and data lines in a couple of different places on the main board. Many times I have seen one of the zener diodes become very leaky, usually along the back of the board, loading down the clock or data line which produces the symptoms you are seeing. If you have no experience locating shorted zener diodes and unsoldering and soldering small parts, allow a qualified tech to service the set for you.
Posted on Aug 29, 2007
I have a Samsung UF55F9000AFXZA television and about a month ago it started taking a little time turn on and seemed to take longer each time i turned it on. Now it wont come on at all, but it tries. when...
with the fault worsening slowly it points to failing capacitors on the power supply Board which is not uncommon for this brand, there are many repair kits available for this brands power supply boards if you feel you are capable of fitting them try Here:
TV Repair Kits MBTV Electronics
or you could consider replacing the whole panel, a bit more expensive but less technical expertise required, shop Jimmy is the largest supplier of replacement boards:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 12, 2016 | Samsung Televison & Video
Sony wega kv-32xbr400
My sony is doing the same thing. but mine blinks 11 times. each time it goes to turn on i hear the clicking then nothing.
Jun 12, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
20" Trinitron Wega
Good day.
First, Have your tv 's circuitry be resoldered. this might be a case of loose contacts particularly along the crt circuitry. the longer you operate the unit at this condition, the faster you are counting the possibility of shortening the lifespan of your tube. 9 years is quite a young age for a unit which has an average of 18years.
response is highly appreciated.
Mar 29, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
Hello, You have a high voltage section problem I would not suggest fixing this set on your own. You will need to take this set to the shop. Because there are no user repairable parts inside of the set.
Sep 10, 2007 | Sony KV-36XBR400 36" TV
Sound but no picture
The only time I have seen a Sony set with absolutely no picture and no on-screen menu but no error codes from the front LED, the main signal CXA jungle IC was bad and needed to be replaced. This is something that should only be attempted by a qualified tech familiar with Sont sets.
Aug 23, 2007 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony KV-36XBR400 36" TV Logo
200 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
